[PATCH v2 1/5] libcsupport: Added futimens() and utimensat()
Gedare Bloom
gedare at rtems.org
Tue May 11 04:49:49 UTC 2021
On Mon, May 10, 2021 at 3:16 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> Reply is below.
> -----Original Message-----
> From: Gedare Bloom <gedare at rtems.org>
> Sent: Monday, May 10, 2021 12:36 PM
> To: Ryan Long <ryan.long at oarcorp.com>
> Cc: devel at rtems.org
> Subject: Re: [PATCH v2 1/5] libcsupport: Added futimens() and utimensat()
> On Thu, May 6, 2021 at 1:51 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> > Created futimens.c and utimensat.c to add support for the POSIX
> > methods futimens() and utimensat().
> > utime() and utimes() are considered obsolote by POSIX, but RTEMS will
> > continue to support them.
> > Closes #4396
> > cpukit/Makefile.am | 2 +
> > cpukit/include/rtems/libio_.h | 60 +++++++++-
> > cpukit/libcsupport/src/futimens.c | 87 ++++++++++++++
> > cpukit/libcsupport/src/utimensat.c | 239 +++++++++++++++++++++++++++++++++++++
> > spec/build/cpukit/librtemscpu.yml | 2 +
> > 5 files changed, 387 insertions(+), 3 deletions(-) create mode
> > 100644 cpukit/libcsupport/src/futimens.c create mode 100644
> > diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am index
> > b0df610..29b4207 100644
> > --- a/cpukit/Makefile.am
> > +++ b/cpukit/Makefile.am
> > @@ -262,6 +262,8 @@ librtemscpu_a_SOURCES += libcsupport/src/unmount.c
> > librtemscpu_a_SOURCES += libcsupport/src/__usrenv.c
> > librtemscpu_a_SOURCES += libcsupport/src/utime.c
> > librtemscpu_a_SOURCES += libcsupport/src/utimes.c
> > +librtemscpu_a_SOURCES += libcsupport/src/futimens.c
> > +librtemscpu_a_SOURCES += libcsupport/src/utimensat.c
> > librtemscpu_a_SOURCES += libcsupport/src/utsname.c
> > librtemscpu_a_SOURCES += libcsupport/src/vprintk.c
> > librtemscpu_a_SOURCES += libcsupport/src/write.c diff --git
> > a/cpukit/include/rtems/libio_.h b/cpukit/include/rtems/libio_.h index
> > e9eb462..7a0a169 100644
> > --- a/cpukit/include/rtems/libio_.h
> > +++ b/cpukit/include/rtems/libio_.h
> > @@ -2,13 +2,12 @@
> > * @file
> > * @brief LibIO Internal Interface
> > * This file is the libio internal interface.
> > - * COPYRIGHT (c) 1989-2011.
> > - * On-Line Applications Research Corporation (OAR).
> > + * COPYRIGHT (C) 1989, 2021 On-Line Applications Research Corporation (OAR).
> > * Modifications to support reference counting in the file system are
> > * Copyright (c) 2012 embedded brains GmbH.
> > @@ -357,6 +356,61 @@ static inline void rtems_filesystem_instance_unlock(
> > (*mt_entry->ops->unlock_h)( mt_entry ); }
> > +/* Prototypes for functions used between utimensat() and futimens()
> We don't usually have this kind of separator comment.
> > + * @brief Checks the tv_sec member of a timespec struct
> > + * @param[in] time The timespec struct to be validated
> > + * Ensures that the value in the tv_sec member is non-negative.
> > + * @retval Returns true if the tv_sec member is a valid value, otherwise false.
> > +bool rtems_filesystem_utime_tv_sec_valid( struct timespec time );
> Should this be a timespec helper instead? It seems like a straightforward helper.
> [Ryan Long] Do you mean just change the name of the function to "timespec_helper_tv_sec_valid" or what?
I was thinking along the lines of the functions in
include/rtems/score/timespec.h
You might consider whether _Timespec_Is_non_negative() should be added.
Speaking of which, you could probably use those helpers in a few
places to simplify your code, e.g.,
_Timespec_Set( times[0], 0, UTIME_NOW);
> > + * @brief Checks the tv_nsec member of a timespec struct
> > + * Ensures that the value in the tv_nsec member is equal to either
> > + * UTIME_NOW, UTIME_OMIT, or a value greater-than or equal to zero
> > + * and less than a billion.
> > + * @retval Returns true if tv_nsec member is a valid value, otherwise false.
> > +bool rtems_filesystem_utime_tv_nsec_valid( struct timespec time );
> > + * @brief Determines if the process has write permissions to a file
> > + * Checks that the process has the same userID as the file and
> > +whether the
> > + * file has write permissions.
> > + * @param[in] currentloc The current location to a file
> > + * @param[in] fstat_h The file handler of @currentloc
> > + * @retval Returns 0 if the process has write permissions, otherwise -1.
> > +int rtems_filesystem_utime_check_permissions(
> > + const rtems_filesystem_location_info_t *currentloc,
> > + const struct timespec times[2]
> The function name is overly broad. it seems like there should be a filesystem helper that checks for write permission (or ownership).
> I don't know why times[] is passed? What is @param[in] fstat_h?
> Passing an array is a bit unusual.
> [Ryan Long] Forgot to update the Doxygen for that, but I got rid of the ftat_h argument because I can just use currentloc to get what was being passed in.
> The array of timespec structures is passed in to check for the conditions for the EACCES and EPERM errors.
> > + * @brief Checks @times and updates @new_times
> > + * @param[in] times The timespec struct to be checked
> > + * @param[in,out] new_times The timespec struct to contain the
> > +updated time
> > + * @retval Returns 0 if the time was update, otherwise -1.
> > +int rtems_filesystem_utime_check_times(
> > + const struct timespec times[2],
> > + struct timespec new_times[2]
> Updates to what?
> [Ryan Long] It updates to the values in times, or if times is NULL, it fills new_times with the current time. I'll change that in the description.
> It may be simpler internally to explicitly refer to "access" and "modified" times instead of times[0] and times[1]?
> [Ryan Long] That would make it easier to follow. I guess this would need to be changed everywhere it was used?
yes.
> > * File Descriptor Routine Prototypes
> > diff --git a/cpukit/libcsupport/src/futimens.c
> > b/cpukit/libcsupport/src/futimens.c
> > new file mode 100644
> > index 0000000..c2ef9da
> > --- /dev/null
> > +++ b/cpukit/libcsupport/src/futimens.c
> > @@ -0,0 +1,87 @@
> > +/* SPDX-License-Identifier: BSD-2-Clause */
> > + * @file
> > + * @ingroup libcsupport
> > + * @brief Set file access and modification times based on file
> > +descriptor in
> > + * nanoseconds.
> This is a new file. How can it have a copyright starting in 1989?
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + * notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + * notice, this list of conditions and the following disclaimer in the
> > + * documentation and/or other materials provided with the distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> > + TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> > + PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> > + CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
> > + OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
> > + OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> > + BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
> > + WHETHER IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> > + OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
> > + ADVISED OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +#ifdef HAVE_CONFIG_H
> > +#include "config.h"
> > +#endif
> > +#include <sys/stat.h>
> > +#include <rtems/libio_.h>
> > +#include <fcntl.h>
> > +#include <stdlib.h>
> > +#include <string.h>
> > +https://pubs.opengroup.org/onlinepubs/9699919799.2008edition/function
> > +s/futimens.html
> > + * Set file access and modification times */ int futimens(
> > + int fd,
> > + int rv;
> > + rtems_libio_t *iop;
> > + struct timespec new_times[2];
> > + const rtems_filesystem_location_info_t *currentloc = NULL;
> > + LIBIO_GET_IOP_WITH_ACCESS( fd, iop, LIBIO_FLAGS_READ, EBADF );
> > + currentloc = &iop->pathinfo;
> > + rv = rtems_filesystem_utime_check_times( times, new_times ); if (
> > + rv != 0 ) {
> > + rtems_libio_iop_drop( iop );
> > + return rv;
> > + rv = rtems_filesystem_utime_check_permissions( currentloc, times );
> > + if ( rv != 0 ) {
> > + return rv;
> > + rv = (*currentloc->mt_entry->ops->utimens_h)(
> > + currentloc,
> > + new_times
> > + return rv;
> > diff --git a/cpukit/libcsupport/src/utimensat.c
> > b/cpukit/libcsupport/src/utimensat.c
> > index 0000000..1cd42cb
> > --- /dev/null
> > +++ b/cpukit/libcsupport/src/utimensat.c
> > @@ -0,0 +1,239 @@
> > + * @file
> > + * @brief Set file access and modification times in nanoseconds.
> > + * are met:
> > +TO, THE
> > +PURPOSE
> > +CONTRIBUTORS BE
> > +OR
> > +OF
> > +BUSINESS
> > +WHETHER IN
> > +OTHERWISE)
> > +ADVISED OF THE
> > +#endif
> > +#include <fcntl.h>
> > +/* Verify that the seconds value is non-negative */ bool
> > +rtems_filesystem_utime_tv_sec_valid(struct timespec time) {
> > + if ( time.tv_sec < 0 ) {
> > + return false;
> > + return true;
> > + * Make sure that tv_nsec is either UTIME_NOW, UTIME_OMIT, a value
> > + * greater than zero, or a value less-than a billion.
> > + * These guidelines come from the description of the EINVAL errors on
> > +https://pubs.opengroup.org/onlinepubs/9699919799/functions/futimens.h
> > +tml
> > +bool rtems_filesystem_utime_tv_nsec_valid(struct timespec time) {
> > + if ( time.tv_nsec == UTIME_NOW ) {
> > + return true;
> > + if ( time.tv_nsec == UTIME_OMIT ) {
> > + return true;
> > + if ( time.tv_nsec < 0 ) {
> > + return false;
> > + if ( time.tv_nsec > 999999999 ) {
> > + return false;
> > + return true;
> > +/* Determine whether the access and modified timestamps can be
> > +updated */ int rtems_filesystem_utime_check_permissions(
> > + const rtems_filesystem_location_info_t * currentloc,
> > + struct stat st;
> > + int rv;
> > + bool write_access;
> > + memset( &st, 0, sizeof(st) );
> nit: this is not necessary, you can use
> struct stat st = {};
> > + rv = (*currentloc->handlers->fstat_h)( currentloc, &st ); if ( rv
> > + != 0 ) {
> > + rtems_set_errno_and_return_minus_one( ENOENT ); }
> > + write_access = rtems_filesystem_check_access(
> > + RTEMS_FS_PERMS_WRITE,
> > + st.st_mode,
> > + st.st_uid,
> > + st.st_gid
> > + * The logic for the EACCES error is an inverted subset of the EPERM
> > + * conditional according to the POSIX standard.
> > + if ( (times == NULL) ||
> > + ( (times[0].tv_nsec == UTIME_NOW) && (times[1].tv_nsec == UTIME_NOW) )) {
> > + if ( !write_access ) {
> > + rtems_set_errno_and_return_minus_one( EACCES );
> > + } else {
> > + if ( times[0].tv_nsec != UTIME_OMIT || times[1].tv_nsec != UTIME_OMIT ) {
> > + rtems_set_errno_and_return_minus_one( EPERM );
> > + return 0;
> > + * Determine if the current time needs to be gotten, and then check
> > + * whether the values in times are valid.
> > + bool got_time = false;
> > + struct timespec now;
> > + * If times is NULL, it's equivalent to adding UTIME_NOW in both time
> > + * elements
> > + if ( times == NULL ) {
> > + new_times[0].tv_sec = 0;
> > + new_times[0].tv_nsec = UTIME_NOW;
> > + new_times[1].tv_sec = 0;
> > + new_times[1].tv_nsec = UTIME_NOW; } else {
> > + new_times[0] = times[0];
> > + new_times[1] = times[1];
> > + if ( new_times[0].tv_nsec == UTIME_NOW ) {
> > + clock_gettime( CLOCK_REALTIME, &now );
> > + new_times[0] = now;
> > + got_time = true;
> > + if ( new_times[1].tv_nsec == UTIME_NOW ) {
> > + if ( !got_time ) {
> > + new_times[1] = now;
> > + if ( !rtems_filesystem_utime_tv_sec_valid( new_times[0] ) ) {
> > + rtems_set_errno_and_return_minus_one( EINVAL ); }
> > + if ( !rtems_filesystem_utime_tv_sec_valid( new_times[1] ) ) {
> > + if ( !rtems_filesystem_utime_tv_nsec_valid( new_times[0] ) ) {
> > + if ( !rtems_filesystem_utime_tv_nsec_valid( new_times[1] ) ) {
> > + return 0;
> > +s/futimens.html
> > + * Set file access and modification times */ int utimensat(
> > + int fd,
> > + const char *path,
> > + int flag
> > + int rv = 0;
> > + rtems_filesystem_eval_path_context_t ctx;
> > + int eval_flags = RTEMS_FS_FOLLOW_LINK;
> > + * RTEMS does not currently support operating on a real file descriptor
> > + if ( fd != AT_FDCWD ) {
> > + rtems_set_errno_and_return_minus_one( ENOSYS ); }
> > + * RTEMS does not currently support AT_SYMLINK_NOFOLLOW
> > + if ( flag != 0 ) {
> > + currentloc = rtems_filesystem_eval_path_start( &ctx, path,
> > + eval_flags );
> would it be simpler and still correct to put this check before the eval path?
> > + if ( rv != 0 ) {
> > + rtems_filesystem_eval_path_cleanup( &ctx );
> > + return rv;
> > + if ( rv != 0 ) {
> > + return rv;
> > + currentloc,
> > + new_times
> > + return rv;
> > diff --git a/spec/build/cpukit/librtemscpu.yml
> > b/spec/build/cpukit/librtemscpu.yml
> > index a3a9ee4..9639051 100644
> > --- a/spec/build/cpukit/librtemscpu.yml
> > +++ b/spec/build/cpukit/librtemscpu.yml
> > @@ -761,6 +761,8 @@ source:
> > - cpukit/libcsupport/src/unmount.c
> > - cpukit/libcsupport/src/utime.c
> > - cpukit/libcsupport/src/utimes.c
> > +- cpukit/libcsupport/src/futimens.c
> > +- cpukit/libcsupport/src/utimensat.c
> > - cpukit/libcsupport/src/utsname.c
> > - cpukit/libcsupport/src/vprintk.c
> > - cpukit/libcsupport/src/write.c
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
