Fwd: [PATCH] riscv/console: console-config.c update
somesh deshmukh
someshdeshmukh07 at gmail.com
Tue May 11 06:04:59 UTC 2021
Gentle Reminder.
Hi All,
Can you please review this patch and let me know if there are any
suggestions/comments.
Regards,
Somesh
---------- Forwarded message ---------
From: Somesh Deshmukh <someshdeshmukh07 at gmail.com>
Date: Wed, May 5, 2021 at 11:26 PM
Subject: [PATCH] riscv/console: console-config.c update
To: <devel at rtems.org>
Cc: Somesh Deshmukh <someshdeshmukh07 at gmail.com>
- Parsing the sub-node should be available generic not specific to Freedom
Arty310 board. If we remove the Freedom Arty macro now, it will lose
backward compatibility.The proposed change will retain the backward
compatibility and also adds the necessary fix for parsing sub-node.
bsps/riscv/riscv/console/console-config.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/bsps/riscv/riscv/console/console-config.c
b/bsps/riscv/riscv/console/console-config.c
index d962a5a418..797506a31b 100644
--- a/bsps/riscv/riscv/console/console-config.c
+++ b/bsps/riscv/riscv/console/console-config.c
@@ -91,7 +91,7 @@ static int riscv_get_console_node(const void *fdt)
stdout_path = "";
-#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0
+#if ((RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0) ||
(RISCV_CONSOLE_MAX_NS16550_DEVICES > 0))
int root;
int soc;
root = fdt_path_offset(fdt, "/");
2.25.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210511/f7278b4d/attachment.html>
