[PATCH v4] sb: Merge mailer changes from rtems-tools
Alex White
alex.white at oarcorp.com
Tue May 11 15:19:29 UTC 2021
This adds the improved mailer.py script from rtems-tools.
Closes #4388
source-builder/sb/mailer.py | 194 ++++++++++++++++++++++++++------
source-builder/sb/options.py | 26 ++++-
source-builder/sb/setbuilder.py | 2 +
3 files changed, 189 insertions(+), 33 deletions(-)
diff --git a/source-builder/sb/mailer.py b/source-builder/sb/mailer.py
index ff25df5..aafe6d6 100644
--- a/source-builder/sb/mailer.py
+++ b/source-builder/sb/mailer.py
@@ -1,21 +1,33 @@
# RTEMS Tools Project (http://www.rtems.org/)
-# Copyright 2013 Chris Johns (chrisj at rtems.org)
+# Copyright 2013-2016 Chris Johns (chrisj at rtems.org)
+# Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
# All rights reserved.
# This file is part of the RTEMS Tools package in 'rtems-tools'.
-# Permission to use, copy, modify, and/or distribute this software for any
-# purpose with or without fee is hereby granted, provided that the above
-# copyright notice and this permission notice appear in all copies.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
-# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
-# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
-# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
-# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
-# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
-# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
-# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
# Manage emailing results or reports.
@@ -28,18 +40,72 @@ import smtplib
import socket
from . import error
+from . import execute
from . import options
from . import path
+_options = {
+ '--mail' : 'Send email report or results.',
+ '--use-gitconfig': 'Use mail configuration from git config.',
+ '--mail-to' : 'Email address to send the email to.',
+ '--mail-from' : 'Email address the report is from.',
+ '--smtp-host' : 'SMTP host to send via.',
+ '--smtp-port' : 'SMTP port to send via.',
+ '--smtp-user' : 'User for SMTP authentication.',
+ '--smtp-password': 'Password for SMTP authentication.'
def append_options(opts):
- opts['--mail'] = 'Send email report or results.'
- opts['--smtp-host'] = 'SMTP host to send via.'
- opts['--mail-to'] = 'Email address to send the email too.'
- opts['--mail-from'] = 'Email address the report is from.'
+ for o in _options:
+ opts[o] = _options[o]
+def add_arguments(argsp):
+ argsp.add_argument('--mail', help = _options['--mail'], action = 'store_true')
+ argsp.add_argument('--use-gitconfig', help = _options['--use-gitconfig'], action = 'store_true')
+ no_add = ['--mail', '--use-gitconfig']
+ for o in [opt for opt in list(_options) if opt not in no_add]:
+ argsp.add_argument(o, help = _options[o], type = str)
class mail:
def __init__(self, opts):
self.opts = opts
+ self.gitconfig_lines = None
+ if opts.find_arg('--use-gitconfig') is not None:
+ # Read the output of `git config --list` instead of reading the
+ # .gitconfig file directly because Python 2 ConfigParser does not
+ # accept tabs at the beginning of lines.
+ e = execute.capture_execution()
+ exit_code, proc, output = e.open('git config --list', shell=True)
+ if exit_code == 0:
+ self.gitconfig_lines = output.split(os.linesep)
+ def _args_are_macros(self):
+ return isinstance(self.opts, options.command_line)
+ def _get_arg(self, arg):
+ if self._args_are_macros():
+ value = self.opts.find_arg(arg)
+ if value is not None:
+ value = self.opts.find_arg(arg)[1]
+ else:
+ if arg.startswith('--'):
+ arg = arg[2:]
+ arg = arg.replace('-', '_')
+ if arg in vars(self.opts):
+ value = vars(self.opts)[arg]
+ else:
+ value = None
+ return value
+ def _get_from_gitconfig(self, variable_name):
+ if self.gitconfig_lines is None:
+ return None
+ for line in self.gitconfig_lines:
+ if line.startswith(variable_name):
+ ls = line.split('=')
+ if len(ls) >= 2:
+ return ls[1]
def from_address(self):
@@ -52,9 +118,15 @@ class mail:
l = l[:l.index('\n')]
return l.strip()
- addr = self.opts.get_arg('--mail-from')
+ addr = self._get_arg('--mail-from')
if addr is not None:
- return addr[1]
+ return addr
+ addr = self._get_from_gitconfig('user.email')
+ if addr is not None:
+ name = self._get_from_gitconfig('user.name')
+ if name is not None:
+ addr = '%s <%s>' % (name, addr)
+ return addr
mailrc = None
if 'MAILRC' in os.environ:
mailrc = os.environ['MAILRC']
@@ -63,9 +135,8 @@ class mail:
if mailrc is not None and path.exists(mailrc):
# set from="Joe Blow <joe at blow.org>"
try:
- mrc = open(mailrc, 'r')
- lines = mrc.readlines()
- mrc.close()
+ with open(mailrc, 'r') as mrc:
+ lines = mrc.readlines()
except IOError as err:
raise error.general('error reading: %s' % (mailrc))
for l in lines:
@@ -76,40 +147,99 @@ class mail:
addr = fa[fa.index('=') + 1:].replace('"', ' ').strip()
return addr
- addr = self.opts.defaults.get_value('%{_sbgit_mail}')
+ addr = self.opts.defaults.get_value('%{_sbgit_mail}')
+ else:
+ raise error.general('no valid from address for mail')
return addr
def smtp_host(self):
- host = self.opts.get_arg('--smtp-host')
+ host = self._get_arg('--smtp-host')
if host is not None:
- return host[1]
- host = self.opts.defaults.get_value('%{_mail_smtp_host}')
+ return host
+ host = self._get_from_gitconfig('sendemail.smtpserver')
+ if host is not None:
+ return host
+ host = self.opts.defaults.get_value('%{_mail_smtp_host}')
return host
return 'localhost'
+ def smtp_port(self):
+ port = self._get_arg('--smtp-port')
+ if port is not None:
+ return port
+ port = self._get_from_gitconfig('sendemail.smtpserverport')
+ return port
+ port = self.opts.defaults.get_value('%{_mail_smtp_port}')
+ return port
+ def smtp_user(self):
+ user = self._get_arg('--smtp-user')
+ if user is not None:
+ return user
+ user = self._get_from_gitconfig('sendemail.smtpuser')
+ return user
+ def smtp_password(self):
+ password = self._get_arg('--smtp-password')
+ if password is not None:
+ return password
+ password = self._get_from_gitconfig('sendemail.smtppass')
+ return password
def send(self, to_addr, subject, body):
from_addr = self.from_address()
msg = "From: %s\r\nTo: %s\r\nSubject: %s\r\n\r\n" % \
(from_addr, to_addr, subject) + body
- if type(to_addr) is str:
- to_addr = to_addr.split(',')
- if type(to_addr) is not list:
- raise error.general('invalid to_addr type')
+ port = self.smtp_port()
try:
- s = smtplib.SMTP(self.smtp_host())
- s.sendmail(from_addr, to_addr, msg)
+ s = smtplib.SMTP(self.smtp_host(), port, timeout=10)
+ password = self.smtp_password()
+ # If a password is provided, assume that authentication is required.
+ user = self.smtp_user()
+ if user is None:
+ user = from_addr
+ s.starttls()
+ s.login(user, password)
+ s.sendmail(from_addr, [to_addr], msg)
except smtplib.SMTPException as se:
raise error.general('sending mail: %s' % (str(se)))
except socket.error as se:
+ def send_file_as_body(self, to_addr, subject, name, intro = None):
+ try:
+ with open(name, 'r') as f:
+ body = f.readlines()
+ except IOError as err:
+ raise error.general('error reading mail body: %s' % (name))
+ if intro is not None:
+ body = intro + body
+ self.send(to_addr, from_addr, body)
if __name__ == '__main__':
import sys
+ from . import macros
optargs = {}
+ rtdir = 'source-builder'
+ defaults = '%s/defaults.mc' % (rtdir)
append_options(optargs)
- opts = options.load(sys.argv, optargs = optargs, defaults = 'defaults.mc')
+ opts = options.command_line(base_path = '.',
+ argv = sys.argv,
+ optargs = optargs,
+ defaults = macros.macros(name = defaults, rtdir = rtdir),
+ command_path = '.')
+ options.load(opts)
m = mail(opts)
print('From: %s' % (m.from_address()))
print('SMTP Host: %s' % (m.smtp_host()))
- m.send(m.from_address(), 'Test mailer.py', 'This is a test')
+ if '--mail' in sys.argv:
+ m.send(m.from_address(), 'Test mailer.py', 'This is a test')
diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
index d6bffd0..a0f196b 100644
--- a/source-builder/sb/options.py
+++ b/source-builder/sb/options.py
@@ -517,6 +517,15 @@ class command_line:
return None
return self.parse_args(arg)
+ def find_arg(self, arg):
+ if self.optargs is None or arg not in self.optargs:
+ raise error.internal('bad arg: %s' % (arg))
+ for a in self.args:
+ sa = a.split('=')
+ if sa[0].startswith(arg):
+ return sa
+ return None
def with_arg(self, label, default = 'not-found'):
# the default if there is no option for without.
result = default
@@ -582,7 +591,22 @@ class command_line:
self.opts['no-install'] = '1'
def info(self):
- s = ' Command Line: %s%s' % (' '.join(self.argv), os.linesep)
+ # Filter potentially sensitive mail options out.
+ filtered_args = [
+ arg for arg in self.argv
+ if all(
+ smtp_opt not in arg
+ for smtp_opt in [
+ '--smtp-host',
+ '--mail-to',
+ '--mail-from',
+ '--smtp-user',
+ '--smtp-password',
+ '--smtp-port'
+ s = ' Command Line: %s%s' % (' '.join(filtered_args), os.linesep)
s += ' Python: %s' % (sys.version.replace('\n', ''))
return s
diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
index b0e2b23..c8c8fee 100644
--- a/source-builder/sb/setbuilder.py
+++ b/source-builder/sb/setbuilder.py
@@ -695,6 +695,8 @@ def run():
'log' : '',
'reports': [],
'failure': None }
+ # Request this now to generate any errors.
+ smtp_host = mail['mail'].smtp_host()
to_addr = opts.get_arg('--mail-to')
if to_addr is not None:
mail['to'] = to_addr[1]
2.27.0
