[PATCH 3/3] rtems: Constify rtems_task_wake_when()
Tue May 11 15:38:15 UTC 2021
Add a parameter to _TOD_Validate() to disable the validation of the
ticks member.
Close #4406.
 bsps/arm/altera-cyclone-v/rtc/rtc.c    |  3 +--
 bsps/shared/dev/rtc/rtc-support.c      |  2 +-
 cpukit/include/rtems/rtems/clockimpl.h | 13 ++++++++-----
 cpukit/include/rtems/rtems/tasks.h     |  2 +-
 cpukit/rtems/src/clockset.c            |  2 +-
 cpukit/rtems/src/clocktodvalidate.c    |  5 +++--
 cpukit/rtems/src/taskwakewhen.c        |  8 ++------
 cpukit/rtems/src/timercreate.c         |  2 +-
 testsuites/sptests/sp2038/init.c       |  4 ++--
 9 files changed, 20 insertions(+), 21 deletions(-)
diff --git a/bsps/arm/altera-cyclone-v/rtc/rtc.c b/bsps/arm/altera-cyclone-v/rtc/rtc.c
index fb30da8d66..4edc7c87f6 100644
--- a/bsps/arm/altera-cyclone-v/rtc/rtc.c
+++ b/bsps/arm/altera-cyclone-v/rtc/rtc.c
@@ -345,7 +345,6 @@ static int altera_cyclone_v_ds1339_get_time(int minor, rtems_time_of_day* tod)
   if (sc == RTEMS_SUCCESSFUL)
-    temp_tod.ticks  = 0;
     temp_tod.second = ds1339_get_seconds(&time);
     temp_tod.minute = ds1339_get_minutes(&time);
     temp_tod.hour   = ds1339_get_hours(&time);
@@ -353,7 +352,7 @@ static int altera_cyclone_v_ds1339_get_time(int minor, rtems_time_of_day* tod)
     temp_tod.month  = ds1339_get_month(&time);
     temp_tod.year   = ds1339_get_year(&time);
-    sc = _TOD_Validate(&temp_tod)
+    sc = _TOD_Validate(&temp_tod, 0)
       memcpy(tod, &temp_tod, sizeof(temp_tod));
diff --git a/bsps/shared/dev/rtc/rtc-support.c b/bsps/shared/dev/rtc/rtc-support.c
index 04b8f0c847..1a0f2a3d9a 100644
--- a/bsps/shared/dev/rtc/rtc-support.c
+++ b/bsps/shared/dev/rtc/rtc-support.c
@@ -255,7 +255,7 @@ int setRealTime(
   if (!RTC_Is_present())
     return -1;
-  if (_TOD_Validate(tod) != RTEMS_SUCCESSFUL)
+  if (_TOD_Validate(tod, UINT32_MAX) != RTEMS_SUCCESSFUL)
     return -1;
   RTC_Table[RTC_Minor].pDeviceFns->deviceSetTime(RTC_Minor, tod);
diff --git a/cpukit/include/rtems/rtems/clockimpl.h b/cpukit/include/rtems/rtems/clockimpl.h
index 8ec4f0f6e3..670ea1e3d7 100644
--- a/cpukit/include/rtems/rtems/clockimpl.h
+++ b/cpukit/include/rtems/rtems/clockimpl.h
@@ -35,19 +35,22 @@ extern "C" {
- * @brief TOD Validate
+ * @brief Validates the time of day.
- * This support function tests whether @a the_tod references
- * a valid time of day.
+ * @param the_tod is the reference to the time of day structure to validate or
+ *   NULL.
- * @param the_tod A reference to the time of day structure to validate.
+ * @param ticks_mask is the mask for the ticks member of the time of day.  Use
+ *   UINT32_MAX to validate the ticks member.  Use zero to skip the validation of
+ *   the ticks member.
  * @retval RTEMS_SUCCESSFUL @a the_tod references a valid time of day.
  * @retval RTEMS_INVALID_CLOCK @a the_tod references an invalid time of day.
  * @retval RTEMS_INVALID_ADDRESS @a the_tod reference is @c NULL.
 rtems_status_code _TOD_Validate(
-  const rtems_time_of_day *the_tod
+  const rtems_time_of_day *the_tod,
+  uint32_t                 ticks_mask
diff --git a/cpukit/include/rtems/rtems/tasks.h b/cpukit/include/rtems/rtems/tasks.h
index e6f7696923..841306eaef 100644
--- a/cpukit/include/rtems/rtems/tasks.h
+++ b/cpukit/include/rtems/rtems/tasks.h
@@ -2071,7 +2071,7 @@ rtems_status_code rtems_task_wake_after( rtems_interval ticks );
  *   occur.
  * @endparblock
-rtems_status_code rtems_task_wake_when( rtems_time_of_day *time_buffer );
+rtems_status_code rtems_task_wake_when( const rtems_time_of_day *time_buffer );
 /* Generated from spec:/rtems/task/if/get-scheduler */
diff --git a/cpukit/rtems/src/clockset.c b/cpukit/rtems/src/clockset.c
index df163531a7..d79d7648e8 100644
--- a/cpukit/rtems/src/clockset.c
+++ b/cpukit/rtems/src/clockset.c
@@ -34,7 +34,7 @@ rtems_status_code rtems_clock_set(
   struct timespec   tod_as_timespec;
   ISR_lock_Context  lock_context;
-  status = _TOD_Validate( tod );
+  status = _TOD_Validate( tod, UINT32_MAX );
   if ( status != RTEMS_SUCCESSFUL ) {
     return status;
diff --git a/cpukit/rtems/src/clocktodvalidate.c b/cpukit/rtems/src/clocktodvalidate.c
index 95c8e77c37..41a1167287 100644
--- a/cpukit/rtems/src/clocktodvalidate.c
+++ b/cpukit/rtems/src/clocktodvalidate.c
@@ -36,7 +36,8 @@ const uint32_t   _TOD_Days_per_month[ 2 ][ 13 ] = {
   uint32_t   days_in_month;
@@ -48,7 +49,7 @@ rtems_status_code _TOD_Validate(
   ticks_per_second = rtems_clock_get_ticks_per_second();
-  if ((the_tod->ticks  >= ticks_per_second)       ||
+  if ( ( ( the_tod->ticks & ticks_mask ) >= ticks_per_second ) ||
       (the_tod->second >= TOD_SECONDS_PER_MINUTE) ||
       (the_tod->minute >= TOD_MINUTES_PER_HOUR)   ||
       (the_tod->hour   >= TOD_HOURS_PER_DAY)      ||
diff --git a/cpukit/rtems/src/taskwakewhen.c b/cpukit/rtems/src/taskwakewhen.c
index a25204ad01..110debfec2 100644
--- a/cpukit/rtems/src/taskwakewhen.c
+++ b/cpukit/rtems/src/taskwakewhen.c
@@ -27,7 +27,7 @@
-  rtems_time_of_day *time_buffer
+  const rtems_time_of_day *time_buffer
   uint32_t          seconds;
@@ -38,11 +38,7 @@ rtems_status_code rtems_task_wake_when(
   if ( !_TOD_Is_set() )
     return RTEMS_NOT_DEFINED;
-  if ( !time_buffer )
-    return RTEMS_INVALID_ADDRESS;
-  time_buffer->ticks = 0;
-  status = _TOD_Validate( time_buffer );
+  status = _TOD_Validate( time_buffer, 0 );
     return status;
diff --git a/cpukit/rtems/src/timercreate.c b/cpukit/rtems/src/timercreate.c
index bd9421c440..9624a3ff62 100644
--- a/cpukit/rtems/src/timercreate.c
+++ b/cpukit/rtems/src/timercreate.c
@@ -141,7 +141,7 @@ rtems_status_code _Timer_Fire_when(
   if ( !routine )
-  status = _TOD_Validate( wall_time );
+  status = _TOD_Validate( wall_time, UINT32_MAX );
     return status;
diff --git a/testsuites/sptests/sp2038/init.c b/testsuites/sptests/sp2038/init.c
index 035b9a9b9b..31af29758b 100644
--- a/testsuites/sptests/sp2038/init.c
+++ b/testsuites/sptests/sp2038/init.c
@@ -281,9 +281,9 @@ static void test_leap_year(void)
     const rtems_time_of_day *problem = &problem_2100;
     const rtems_time_of_day *problem2 = &problem_2100_2;
     // 2100 is not a leap year, so it should have 28 days
-    test_status = _TOD_Validate(problem);
+    test_status = _TOD_Validate(problem, UINT32_MAX);
     rtems_test_assert(test_status == RTEMS_SUCCESSFUL);
-    test_status = _TOD_Validate(problem2);
+    test_status = _TOD_Validate(problem2, UINT32_MAX);
     rtems_test_assert(test_status == RTEMS_INVALID_CLOCK);
2.26.2
