[PATCH 1/3] _TOD_Validate(): Fix incorrect return code
Tue May 11 20:00:45 UTC 2021
On Tue, May 11, 2021 at 9:38 AM Sebastian Huber
> From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
> This patch fixes bug #4403. Directives
> * rtems_timer_fire_when()
> * rtems_timer_server_fire_when()
> * rtems_task_wake_when()
> are documented to return RTEMS_INVALID_ADDRESS when their time-of-day
> argument is NULL. But actually they return RTEMS_INVALID_CLOCK. To fix
> the issue this patch changes _TOD_Validate() to return a
> status code instead of just true/false.
> Close #4403
>  bsps/arm/altera-cyclone-v/rtc/rtc.c    | 10 ++++----
>  bsps/shared/dev/rtc/rtc-support.c      |  2 +-
>  cpukit/include/rtems/rtems/clockimpl.h | 14 +++++------
>  cpukit/rtems/src/clockset.c            | 33 +++++++++++++-------------
>  cpukit/rtems/src/clocktodvalidate.c    | 21 +++++++++-------
>  cpukit/rtems/src/taskwakewhen.c        | 13 ++++++----
>  cpukit/rtems/src/timercreate.c         | 10 +++++---
>  testsuites/sptests/sp2038/init.c       |  6 ++---
>  8 files changed, 59 insertions(+), 50 deletions(-)
> diff --git a/bsps/arm/altera-cyclone-v/rtc/rtc.c b/bsps/arm/altera-cyclone-v/rtc/rtc.c
> index 3e8c68e789..fb30da8d66 100644
> --- a/bsps/arm/altera-cyclone-v/rtc/rtc.c
> +++ b/bsps/arm/altera-cyclone-v/rtc/rtc.c
> @@ -353,10 +353,9 @@ static int altera_cyclone_v_ds1339_get_time(int minor, rtems_time_of_day* tod)
>      temp_tod.month  = ds1339_get_month(&time);
>      temp_tod.year   = ds1339_get_year(&time);
> -    if (_TOD_Validate(&temp_tod))
> +    sc = _TOD_Validate(&temp_tod)
> +    if (sc == RTEMS_SUCCESSFUL)
>        memcpy(tod, &temp_tod, sizeof(temp_tod));
> -    else
> -      sc = RTEMS_INVALID_CLOCK;
>    return -sc;
> @@ -737,10 +736,9 @@ static int  altera_cyclone_v_m41st87_get_time(int minor, rtems_time_of_day* tod)
>    temp_tod.month  = m41st87_get_month(&time);
>    temp_tod.year   = m41st87_get_year(&time);
> +  sc = _TOD_Validate(&temp_tod);
> -  else
>    return -sc;
> diff --git a/bsps/shared/dev/rtc/rtc-support.c b/bsps/shared/dev/rtc/rtc-support.c
> index 765bfe1d6b..04b8f0c847 100644
> --- a/bsps/shared/dev/rtc/rtc-support.c
> +++ b/bsps/shared/dev/rtc/rtc-support.c
> @@ -255,7 +255,7 @@ int setRealTime(
>    if (!RTC_Is_present())
>      return -1;
> -  if ( !_TOD_Validate(tod) )
> +  if (_TOD_Validate(tod) != RTEMS_SUCCESSFUL)
These three files in bsps/ should not be calling score functions
directly, unless they implement part of the score CPU port. These
don't seem to be doing that. This issue exists before this patch, but
a ticket should be opened to fix this. A new API should be added for
application/BSP layers to validate an rtems_time_of_day value.
>      return -1;
>    RTC_Table[RTC_Minor].pDeviceFns->deviceSetTime(RTC_Minor, tod);
> diff --git a/cpukit/include/rtems/rtems/clockimpl.h b/cpukit/include/rtems/rtems/clockimpl.h
> index c13c158410..8ec4f0f6e3 100644
> --- a/cpukit/include/rtems/rtems/clockimpl.h
> +++ b/cpukit/include/rtems/rtems/clockimpl.h
> @@ -37,16 +37,16 @@ extern "C" {
>   * @brief TOD Validate
> - * This support function returns true if @a the_tod contains
> - * a valid time of day, and false otherwise.
> + * This support function tests whether @a the_tod references
> + * a valid time of day.
> - * @param[in] the_tod is the TOD structure to validate
> + * @param the_tod A reference to the time of day structure to validate.
> - * @retval This method returns true if the TOD is valid and false otherwise.
> - * @note This routine only works for leap-years through 2099.
> + * @retval RTEMS_SUCCESSFUL @a the_tod references a valid time of day.
> + * @retval RTEMS_INVALID_CLOCK @a the_tod references an invalid time of day.
> + * @retval RTEMS_INVALID_ADDRESS @a the_tod reference is @c NULL.
> -bool _TOD_Validate(
> +rtems_status_code _TOD_Validate(
>    const rtems_time_of_day *the_tod
> diff --git a/cpukit/rtems/src/clockset.c b/cpukit/rtems/src/clockset.c
> index 7a085ada69..df163531a7 100644
> --- a/cpukit/rtems/src/clockset.c
> +++ b/cpukit/rtems/src/clockset.c
> @@ -29,26 +29,25 @@ rtems_status_code rtems_clock_set(
>    const rtems_time_of_day *tod
> -  Status_Control status;
> +  rtems_status_code status;
> +  Status_Control    score_status;
> +  struct timespec   tod_as_timespec;
> +  ISR_lock_Context  lock_context;
> -  if ( !tod )
> -    return RTEMS_INVALID_ADDRESS;
> +  status = _TOD_Validate( tod );
> -  if ( _TOD_Validate( tod ) ) {
> -    struct timespec  tod_as_timespec;
> -    ISR_lock_Context lock_context;
> -    tod_as_timespec.tv_sec = _TOD_To_seconds( tod );
> -    tod_as_timespec.tv_nsec = tod->ticks
> -      * rtems_configuration_get_nanoseconds_per_tick();
> +  if ( status != RTEMS_SUCCESSFUL ) {
> +    return status;
> -    _TOD_Lock();
> -    _TOD_Acquire( &lock_context );
> -    status = _TOD_Set( &tod_as_timespec, &lock_context );
> -    _TOD_Unlock();
> +  tod_as_timespec.tv_sec = _TOD_To_seconds( tod );
> +  tod_as_timespec.tv_nsec = tod->ticks
> +    * rtems_configuration_get_nanoseconds_per_tick();
> -    return _Status_Get( status );
> +  _TOD_Lock();
> +  _TOD_Acquire( &lock_context );
> +  score_status = _TOD_Set( &tod_as_timespec, &lock_context );
> +  _TOD_Unlock();
> -  return RTEMS_INVALID_CLOCK;
> +  return _Status_Get( score_status );
> diff --git a/cpukit/rtems/src/clocktodvalidate.c b/cpukit/rtems/src/clocktodvalidate.c
> index 2685bfd6e7..d8e9d01382 100644
> --- a/cpukit/rtems/src/clocktodvalidate.c
> +++ b/cpukit/rtems/src/clocktodvalidate.c
> @@ -35,17 +35,20 @@ const uint32_t   _TOD_Days_per_month[ 2 ][ 13 ] = {
>    { 0, 31, 29, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 }
>    uint32_t   days_in_month;
>    uint32_t   ticks_per_second;
> +  if ( the_tod == NULL ) {
> +    return RTEMS_INVALID_ADDRESS;
>    ticks_per_second = TOD_MICROSECONDS_PER_SECOND /
>             rtems_configuration_get_microseconds_per_tick();
> -  if ((!the_tod)                                  ||
> -      (the_tod->ticks  >= ticks_per_second)       ||
> +  if ((the_tod->ticks  >= ticks_per_second)       ||
>        (the_tod->second >= TOD_SECONDS_PER_MINUTE) ||
>        (the_tod->minute >= TOD_MINUTES_PER_HOUR)   ||
>        (the_tod->hour   >= TOD_HOURS_PER_DAY)      ||
> @@ -53,8 +56,9 @@ bool _TOD_Validate(
>        (the_tod->month  >  TOD_MONTHS_PER_YEAR)    ||
>        (the_tod->year   <  TOD_BASE_YEAR)          ||
>        (the_tod->year   >  TOD_LATEST_YEAR)        ||
> -      (the_tod->day    == 0) )
> -     return false;
> +      (the_tod->day    == 0) ) {
> +    return RTEMS_INVALID_CLOCK;
>    if (((the_tod->year % 4) == 0 && (the_tod->year % 100 != 0)) ||
>       (the_tod->year % 400 == 0))
> @@ -62,8 +66,9 @@ bool _TOD_Validate(
>    else
>      days_in_month = _TOD_Days_per_month[ 0 ][ the_tod->month ];
> -  if ( the_tod->day > days_in_month )
> -    return false;
> +  if ( the_tod->day > days_in_month ) {
> -  return true;
> +  return RTEMS_SUCCESSFUL;
> diff --git a/cpukit/rtems/src/taskwakewhen.c b/cpukit/rtems/src/taskwakewhen.c
> index 5f6a5795fc..a25204ad01 100644
> --- a/cpukit/rtems/src/taskwakewhen.c
> +++ b/cpukit/rtems/src/taskwakewhen.c
> @@ -30,9 +30,10 @@ rtems_status_code rtems_task_wake_when(
>    rtems_time_of_day *time_buffer
> -  uint32_t         seconds;
> -  Thread_Control  *executing;
> -  Per_CPU_Control *cpu_self;
> +  uint32_t          seconds;
> +  Thread_Control   *executing;
> +  Per_CPU_Control  *cpu_self;
>    if ( !_TOD_Is_set() )
>      return RTEMS_NOT_DEFINED;
> @@ -41,9 +42,11 @@ rtems_status_code rtems_task_wake_when(
>    time_buffer->ticks = 0;
> +  status = _TOD_Validate( time_buffer );
> -  if ( !_TOD_Validate( time_buffer ) )
> +    return status;
>    seconds = _TOD_To_seconds( time_buffer );
> diff --git a/cpukit/rtems/src/timercreate.c b/cpukit/rtems/src/timercreate.c
> index a3ece5cc4d..bd9421c440 100644
> --- a/cpukit/rtems/src/timercreate.c
> +++ b/cpukit/rtems/src/timercreate.c
> @@ -132,7 +132,8 @@ rtems_status_code _Timer_Fire_when(
>    Watchdog_Service_routine_entry     adaptor
> -  rtems_interval seconds;
> +  rtems_interval    seconds;
> @@ -140,8 +141,11 @@ rtems_status_code _Timer_Fire_when(
>    if ( !routine )
> -  if ( !_TOD_Validate( wall_time ) )
> +  status = _TOD_Validate( wall_time );
> +    return status;
>    seconds = _TOD_To_seconds( wall_time );
>    if ( seconds <= _TOD_Seconds_since_epoch() )
> diff --git a/testsuites/sptests/sp2038/init.c b/testsuites/sptests/sp2038/init.c
> index 10850d9c4d..035b9a9b9b 100644
> --- a/testsuites/sptests/sp2038/init.c
> +++ b/testsuites/sptests/sp2038/init.c
> @@ -277,14 +277,14 @@ static void test_problem_year(void)
>  static void test_leap_year(void)
> -    bool test_status;
> +    rtems_status_code test_status;
>      const rtems_time_of_day *problem = &problem_2100;
>      const rtems_time_of_day *problem2 = &problem_2100_2;
>      // 2100 is not a leap year, so it should have 28 days
>      test_status = _TOD_Validate(problem);
> -    rtems_test_assert(test_status == true);
> +    rtems_test_assert(test_status == RTEMS_SUCCESSFUL);
>      test_status = _TOD_Validate(problem2);
> -    rtems_test_assert(test_status == false);
> +    rtems_test_assert(test_status == RTEMS_INVALID_CLOCK);
>  static bool test_year_is_leap_year(uint32_t year)
> 2.26.2
> devel mailing list
> devel at rtems.org
