[PATCH 3/3] rtems: Constify rtems_task_wake_when()
Wed May 12 04:33:49 UTC 2021
On 11/05/2021 22:07, Gedare Bloom wrote:
> I'm not a big fan of the way this has been implemented. It exposes an
> internal implementation detail (how you mask the ticks). I don't quite
> see why it is being done.
>> diff --git a/cpukit/rtems/src/taskwakewhen.c b/cpukit/rtems/src/taskwakewhen.c
>> index a25204ad01..110debfec2 100644
>> --- a/cpukit/rtems/src/taskwakewhen.c
>> +++ b/cpukit/rtems/src/taskwakewhen.c
>> @@ -27,7 +27,7 @@
>>   #include <rtems/score/watchdogimpl.h>
>>   rtems_status_code rtems_task_wake_when(
>> -  rtems_time_of_day *time_buffer
>> +  const rtems_time_of_day *time_buffer
>>     uint32_t          seconds;
>> @@ -38,11 +38,7 @@ rtems_status_code rtems_task_wake_when(
>>     if ( !_TOD_Is_set() )
>>       return RTEMS_NOT_DEFINED;
>> -  if ( !time_buffer )
>> -    return RTEMS_INVALID_ADDRESS;
>> -  time_buffer->ticks = 0;
>> -  status = _TOD_Validate( time_buffer );
>> +  status = _TOD_Validate( time_buffer, 0 );
The reason for the ticks mask is above. In rtems_task_wake_when(), the
ticks member is ignored. Before the change you had a double check for
time_buffer == NULL (one in rtems_task_wake_when() and one in
_TOD_Validate()). Ignoring the ticks was done with a write to the
structure. Now the structure is no longer modified.  Using a mask
parameter is quite efficient. You just have to load an immediate value
and there are no additional branches in _TOD_Validate(). I can add this
text to the commit message.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
