[PATCH v3 2/5] libcsupport: Implement utime() in terms of utimensat()
Wed May 12 17:37:37 UTC 2021
On Wed, May 12, 2021 at 7:34 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> utime() now calls utimensat() to update file access
> and modification timestamps.
> Updated license.
> Closes #4397
>  cpukit/libcsupport/src/utime.c | 77 +++++++++++++++++++++++-------------------
>  1 file changed, 43 insertions(+), 34 deletions(-)
> diff --git a/cpukit/libcsupport/src/utime.c b/cpukit/libcsupport/src/utime.c
> index e2d8883..884d227 100644
> --- a/cpukit/libcsupport/src/utime.c
> +++ b/cpukit/libcsupport/src/utime.c
> @@ -1,58 +1,67 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
>   *  @file
> - *  @brief Set File Access and Modification Times
>   *  @ingroup libcsupport
> + *  @brief Set file access and modification times in seconds.
> - *  COPYRIGHT (c) 1989-1999.
> - *  On-Line Applications Research Corporation (OAR).
> + * COPYRIGHT (C) 1989, 2021 On-Line Applications Research Corporation (OAR).
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.org/license/LICENSE.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
>  #ifdef HAVE_CONFIG_H
>  #include "config.h"
>  #endif
> -/* FIXME: This include is a workaround for a broken <utime.h> in Newlib */
> -#include <sys/types.h>
> +#include <sys/stat.h>
> +#include <rtems/libio_.h>
> +#include <fcntl.h>
>  #include <utime.h>
> -#include <rtems/libio_.h>
> - *  POSIX 1003.1b 5.5.6 - Set File Access and Modification Times
> + *  https://pubs.opengroup.org/onlinepubs/009604599/functions/utime.html
> + *  Set file access and modification times
> -int utime( const char *path, const struct utimbuf *times )
> +int utime(
> +  const char *path,
> +  const struct utimbuf *times
> -  int rv = 0;
> -  rtems_filesystem_eval_path_context_t ctx;
> -  int eval_flags = RTEMS_FS_FOLLOW_LINK;
> -  const rtems_filesystem_location_info_t *currentloc =
> -    rtems_filesystem_eval_path_start( &ctx, path, eval_flags );
> -  struct utimbuf now_times;
> -  if ( times == NULL ) {
> -    time_t now = time( NULL );
> -    now_times.actime = now;
> -    now_times.modtime = now;
> -    times = &now_times;
> +  struct timespec new_times[2];
> -  rv = (*currentloc->mt_entry->ops->utime_h)(
> -    currentloc,
> -    times->actime,
> -    times->modtime
> +  if ( times == NULL )
add {
> +    return utimensat(AT_FDCWD, path, NULL, 0);
and }
> -  rtems_filesystem_eval_path_cleanup( &ctx );
> +  new_times[0].tv_sec = times->actime;
> +  new_times[0].tv_nsec = 0;
Why not using _Timespec_Set() helper?
> +  new_times[1].tv_sec = times->modtime;
> +  new_times[1].tv_nsec = 0;
> -  return rv;
> +  return utimensat(AT_FDCWD, path, new_times, 0);
> 1.8.3.1
> devel mailing list
> devel at rtems.org
