[PATCH v4 5/5] Change filesystem utime_h handler to utimens_h
Gedare Bloom
gedare at rtems.org
Sat May 15 14:06:28 UTC 2021
On Fri, May 14, 2021 at 11:32 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> Also updated licenses.
> Closes #4400
> bsps/arm/csb337/umon/tfsDriver.c | 2 +-
> cpukit/Makefile.am | 4 +-
> cpukit/include/rtems/confdefs/libio.h | 4 +-
> cpukit/include/rtems/imfs.h | 35 ++++++++++++-----
> cpukit/include/rtems/libio.h | 55 +++++++++++++++++----------
> cpukit/libcsupport/src/__usrenv.c | 39 +++++++++++++------
> cpukit/libcsupport/src/futimens.c | 2 +-
> cpukit/libcsupport/src/utimensat.c | 2 +-
> cpukit/libfs/src/defaults/default_ops.c | 34 ++++++++++++-----
> cpukit/libfs/src/defaults/default_utime.c | 32 ----------------
> cpukit/libfs/src/defaults/default_utimens.c | 49 ++++++++++++++++++++++++
> cpukit/libfs/src/dosfs/msdos_init.c | 48 ++++++++++++++++--------
> cpukit/libfs/src/ftpfs/ftpfs.c | 44 ++++++++++++----------
> cpukit/libfs/src/ftpfs/tftpDriver.c | 28 +++++++++++---
> cpukit/libfs/src/imfs/imfs_init.c | 30 ++++++++++++---
> cpukit/libfs/src/imfs/imfs_utime.c | 41 --------------------
> cpukit/libfs/src/imfs/imfs_utimens.c | 58 +++++++++++++++++++++++++++++
> cpukit/libfs/src/jffs2/src/fs-rtems.c | 11 +++---
> cpukit/libfs/src/rfs/rtems-rfs-rtems.c | 16 ++++----
> spec/build/cpukit/librtemscpu.yml | 4 +-
> 20 files changed, 345 insertions(+), 193 deletions(-)
> delete mode 100644 cpukit/libfs/src/defaults/default_utime.c
> create mode 100644 cpukit/libfs/src/defaults/default_utimens.c
> delete mode 100644 cpukit/libfs/src/imfs/imfs_utime.c
> create mode 100644 cpukit/libfs/src/imfs/imfs_utimens.c
> diff --git a/bsps/arm/csb337/umon/tfsDriver.c b/bsps/arm/csb337/umon/tfsDriver.c
> index 0195346..caf3a4b 100644
> --- a/bsps/arm/csb337/umon/tfsDriver.c
> +++ b/bsps/arm/csb337/umon/tfsDriver.c
> @@ -657,7 +657,7 @@ static const rtems_filesystem_operations_table rtems_tfs_ops = {
> .mount_h = rtems_filesystem_default_mount,
> .unmount_h = rtems_filesystem_default_unmount,
> .fsunmount_me_h = rtems_filesystem_default_fsunmount,
> - .utime_h = rtems_filesystem_default_utime,
> + .utimens_h = rtems_filesystem_default_utimens,
> .symlink_h = rtems_filesystem_default_symlink,
> .readlink_h = rtems_filesystem_default_readlink,
> .rename_h = rtems_filesystem_default_rename,
> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> index 29b4207..c144773 100644
> --- a/cpukit/Makefile.am
> +++ b/cpukit/Makefile.am
> @@ -377,7 +377,7 @@ librtemscpu_a_SOURCES += libfs/src/defaults/default_rmnod.c
> librtemscpu_a_SOURCES += libfs/src/defaults/default_statvfs.c
> librtemscpu_a_SOURCES += libfs/src/defaults/default_symlink.c
> librtemscpu_a_SOURCES += libfs/src/defaults/default_unmount.c
> -librtemscpu_a_SOURCES += libfs/src/defaults/default_utime.c
> +librtemscpu_a_SOURCES += libfs/src/defaults/default_utimens.c
> librtemscpu_a_SOURCES += libfs/src/defaults/default_write.c
> librtemscpu_a_SOURCES += libfs/src/defaults/default_writev.c
> librtemscpu_a_SOURCES += libfs/src/dosfs/fat.c
> @@ -434,7 +434,7 @@ librtemscpu_a_SOURCES += libfs/src/imfs/imfs_stat.c
> librtemscpu_a_SOURCES += libfs/src/imfs/imfs_stat_file.c
> librtemscpu_a_SOURCES += libfs/src/imfs/imfs_symlink.c
> librtemscpu_a_SOURCES += libfs/src/imfs/imfs_unmount.c
> -librtemscpu_a_SOURCES += libfs/src/imfs/imfs_utime.c
> +librtemscpu_a_SOURCES += libfs/src/imfs/imfs_utimens.c
> librtemscpu_a_SOURCES += libfs/src/imfs/ioman.c
> librtemscpu_a_SOURCES += libfs/src/pipe/fifo.c
> librtemscpu_a_SOURCES += libfs/src/pipe/pipe.c
> diff --git a/cpukit/include/rtems/confdefs/libio.h b/cpukit/include/rtems/confdefs/libio.h
> index 16a4fb69..1b84f8c 100644
> --- a/cpukit/include/rtems/confdefs/libio.h
> +++ b/cpukit/include/rtems/confdefs/libio.h
> @@ -231,9 +231,9 @@ static const rtems_filesystem_operations_table IMFS_root_ops = {
> #endif
> #ifdef CONFIGURE_IMFS_DISABLE_UTIME
> - rtems_filesystem_default_utime,
> + rtems_filesystem_default_utimens,
> #else
> - IMFS_utime,
> + IMFS_utimens,
> #endif
> #ifdef CONFIGURE_IMFS_DISABLE_SYMLINK
> diff --git a/cpukit/include/rtems/imfs.h b/cpukit/include/rtems/imfs.h
> index b2a9868..57c498c 100644
> --- a/cpukit/include/rtems/imfs.h
> +++ b/cpukit/include/rtems/imfs.h
> @@ -1,3 +1,5 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> * @file
> @@ -5,12 +7,28 @@
> - * COPYRIGHT (c) 1989-2011.
> - * On-Line Applications Research Corporation (OAR).
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> - * http://www.rtems.org/license/LICENSE.
> + * COPYRIGHT (C) 1989, 2021 On-Line Applications Research Corporation (OAR).
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> #ifndef _RTEMS_IMFS_H
> @@ -954,10 +972,9 @@ extern int device_ftruncate(
> * This routine is the implementation of the utime() system
> * call for the IMFS.
> -extern int IMFS_utime(
> +extern int IMFS_utimens(
> const rtems_filesystem_location_info_t *loc,
> - time_t actime,
> - time_t modtime
> + struct timespec times[2]
> diff --git a/cpukit/include/rtems/libio.h b/cpukit/include/rtems/libio.h
> index 519e797..5379d92 100644
> --- a/cpukit/include/rtems/libio.h
> +++ b/cpukit/include/rtems/libio.h
> @@ -1,3 +1,5 @@
> * @file
> @@ -11,15 +13,31 @@
> - * COPYRIGHT (c) 1989-2008.
> - * Modifications to support reference counting in the file system are
> - * Copyright (c) 2012 embedded brains GmbH.
> + * Modifications to support reference counting in the file system are
> + * Copyright (C) 2012 embedded brains GmbH.
> + * are met:
> #ifndef _RTEMS_RTEMS_LIBIO_H
> @@ -375,18 +393,16 @@ typedef int (*rtems_filesystem_rmnod_t)(
> * @brief Set node access and modification times.
> * @param[in] loc The location of the node.
> - * @param[in] actime Access time for the node.
> - * @param[in] modtime Modification for the node.
> + * @param[in] times Access and modification times for the node
> * @retval 0 Successful operation.
> * @retval -1 An error occurred. The errno is set to indicate the error.
> - * @see rtems_filesystem_default_utime().
> + * @see rtems_filesystem_default_utimens().
> -typedef int (*rtems_filesystem_utime_t)(
> +typedef int (*rtems_filesystem_utimens_t)(
> - time_t actime,
> - time_t modtime
> @@ -484,7 +500,7 @@ struct _rtems_filesystem_operations_table {
> rtems_filesystem_mount_t mount_h;
> rtems_filesystem_unmount_t unmount_h;
> rtems_filesystem_fsunmount_me_t fsunmount_me_h;
> - rtems_filesystem_utime_t utime_h;
> + rtems_filesystem_utimens_t utimens_h;
> rtems_filesystem_symlink_t symlink_h;
> rtems_filesystem_readlink_t readlink_h;
> rtems_filesystem_rename_t rename_h;
> @@ -644,12 +660,11 @@ void rtems_filesystem_default_fsunmount(
> * @retval -1 Always. The errno is set to ENOTSUP.
> - * @see rtems_filesystem_utime_t.
> + * @see rtems_filesystem_utimens_t.
> -int rtems_filesystem_default_utime(
> +int rtems_filesystem_default_utimens(
> - time_t actime,
> - time_t modtime
> diff --git a/cpukit/libcsupport/src/__usrenv.c b/cpukit/libcsupport/src/__usrenv.c
> index 5c25eaa..ebafa9e 100644
> --- a/cpukit/libcsupport/src/__usrenv.c
> +++ b/cpukit/libcsupport/src/__usrenv.c
> @@ -1,3 +1,5 @@
> * @file
> @@ -6,15 +8,31 @@
> + * COPYRIGHT (C) 2021 On-Line Applications Research Corporation (OAR).
> + * Copyright (c) 2012 embedded brains GmbH.
> + * are met:
> #ifdef HAVE_CONFIG_H
> @@ -145,10 +163,9 @@ static void null_op_fsunmount_me(
> /* Do nothing */
> -static int null_op_utime(
> +static int null_op_utimens(
> - time_t actime,
> - time_t modtime
> return -1;
> @@ -207,7 +224,7 @@ static const rtems_filesystem_operations_table null_ops = {
> .mount_h = null_op_mount,
> .unmount_h = null_op_unmount,
> .fsunmount_me_h = null_op_fsunmount_me,
> - .utime_h = null_op_utime,
> + .utimens_h = null_op_utimens,
> .symlink_h = null_op_symlink,
> .readlink_h = null_op_readlink,
> .rename_h = null_op_rename,
> diff --git a/cpukit/libcsupport/src/futimens.c b/cpukit/libcsupport/src/futimens.c
> index f82c782..151e7a1 100644
> --- a/cpukit/libcsupport/src/futimens.c
> +++ b/cpukit/libcsupport/src/futimens.c
> @@ -76,7 +76,7 @@ int futimens(
> return rv;
> - rv = (*currentloc->mt_entry->ops->utime_h)(
> + rv = (*currentloc->mt_entry->ops->utimens_h)(
> currentloc,
> new_times
> diff --git a/cpukit/libcsupport/src/utimensat.c b/cpukit/libcsupport/src/utimensat.c
> index 3e91b65..c053218 100644
> --- a/cpukit/libcsupport/src/utimensat.c
> +++ b/cpukit/libcsupport/src/utimensat.c
> @@ -214,7 +214,7 @@ int utimensat(
> return rv;
> currentloc,
> new_times
> diff --git a/cpukit/libfs/src/defaults/default_ops.c b/cpukit/libfs/src/defaults/default_ops.c
> index 63ad2ce..45069e7 100644
> --- a/cpukit/libfs/src/defaults/default_ops.c
> +++ b/cpukit/libfs/src/defaults/default_ops.c
> @@ -1,3 +1,5 @@
> * @file
> @@ -7,16 +9,28 @@
> - * Copyright (c) 2010
> - * embedded brains GmbH
> - * Obere Lagerstr. 30
> - * D-82178 Puchheim
> - * Germany
> - * <rtems at embedded-brains.de>
> + * Copyright (C) 2010 embedded brains GmbH
> + * are met:
> #include <rtems/libio.h>
> @@ -36,7 +50,7 @@ const rtems_filesystem_operations_table rtems_filesystem_operations_default = {
> diff --git a/cpukit/libfs/src/defaults/default_utime.c b/cpukit/libfs/src/defaults/default_utime.c
> deleted file mode 100644
> index aaf4e44..0000000
> --- a/cpukit/libfs/src/defaults/default_utime.c
> +++ /dev/null
> @@ -1,32 +0,0 @@
> - * @file
> - * @ingroup LibIOFSOps File System Operations
> - * @brief RTEMS Default File System sets file access and modification times
> - * COPYRIGHT (c) 2010.
> -#ifdef HAVE_CONFIG_H
> -#include "config.h"
> -#endif
> -#include <rtems/libio_.h>
> -#include <rtems/seterr.h>
> - const rtems_filesystem_location_info_t *loc,
> - time_t actime,
> - time_t modtime
> - rtems_set_errno_and_return_minus_one( ENOTSUP );
> diff --git a/cpukit/libfs/src/defaults/default_utimens.c b/cpukit/libfs/src/defaults/default_utimens.c
> new file mode 100644
> index 0000000..c2321dc
> --- /dev/null
> +++ b/cpukit/libfs/src/defaults/default_utimens.c
> @@ -0,0 +1,49 @@
> + * @file
> + * @ingroup LibIOFSOps File System Operations
> + * @brief RTEMS Default File System sets file access and modification times
> + * COPYRIGHT (C) 2010, 2021 On-Line Applications Research Corporation (OAR).
> + * are met:
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/libio_.h>
> +#include <rtems/seterr.h>
> + const rtems_filesystem_location_info_t *loc,
> + rtems_set_errno_and_return_minus_one( ENOTSUP );
> diff --git a/cpukit/libfs/src/dosfs/msdos_init.c b/cpukit/libfs/src/dosfs/msdos_init.c
> index 67b16b6..6eacc00 100644
> --- a/cpukit/libfs/src/dosfs/msdos_init.c
> +++ b/cpukit/libfs/src/dosfs/msdos_init.c
> @@ -1,3 +1,5 @@
> * @file
> @@ -7,20 +9,37 @@
> - * Copyright (C) 2001 OKTET Ltd., St.-Petersburg, Russia
> - * Author: Eugeny S. Mints <Eugeny.Mints at oktet.ru>
> + * Copyright (C) 2001 OKTET Ltd.
do we have permission to change this one? Does their original code
still exist here?
> + * Modifications to support UTF-8 in the file system are
> + * Copyright (C) 2013 embedded brains GmbH.
> - * Modifications to support UTF-8 in the file system are
> - * Copyright (c) 2013 embedded brains GmbH.
> + * are met:
> #include "config.h"
> #endif
> @@ -36,18 +55,17 @@ static int msdos_clone_node_info(rtems_filesystem_location_info_t *loc)
> return fat_file_reopen(fat_fd);
> -static int msdos_utime(
> +static int msdos_utimens(
> - time_t actime,
> - time_t modtime
> fat_file_fd_t *fat_fd = loc->node_access;
> - if (actime != modtime)
> + if (times[0].tv_sec != times[1].tv_sec)
> - fat_file_set_mtime(fat_fd, modtime);
> + fat_file_set_mtime(fat_fd, times[1].tv_sec);
> return RC_OK;
> @@ -67,7 +85,7 @@ const rtems_filesystem_operations_table msdos_ops = {
> .fsunmount_me_h = msdos_shut_down,
> - .utime_h = msdos_utime,
> + .utimens_h = msdos_utimens,
> .rename_h = msdos_rename,
> diff --git a/cpukit/libfs/src/ftpfs/ftpfs.c b/cpukit/libfs/src/ftpfs/ftpfs.c
> index 5e0cb95..06d06bc 100644
> --- a/cpukit/libfs/src/ftpfs/ftpfs.c
> +++ b/cpukit/libfs/src/ftpfs/ftpfs.c
> @@ -1,3 +1,5 @@
> * @file
> @@ -5,27 +7,29 @@
> - * Copyright (c) 2009-2012 embedded brains GmbH.
> - * 82178 Puchheim
> - * Germany
> - * (c) Copyright 2002
> - * Thomas Doerfler
> - * IMD Ingenieurbuero fuer Microcomputertechnik
> - * Herbststr. 8
> - * 82178 Puchheim, Germany
> - * <Thomas.Doerfler at imd-systems.de>
> + * COPYRIGHT (C) 2009-2012 embedded brains GmbH.
> + * COPYRIGHT (C) 2002 IMD Ingenieurbuero fuer Microcomputertechnik.
Ask Thomas if this one can be changed.
> - * This code has been created after closly inspecting "tftpdriver.c" from Eric
> - * Norum.
> + * are met:
> @@ -1384,7 +1388,7 @@ static const rtems_filesystem_operations_table rtems_ftpfs_ops = {
> .fsunmount_me_h = rtems_ftpfs_unmount_me,
> diff --git a/cpukit/libfs/src/ftpfs/tftpDriver.c b/cpukit/libfs/src/ftpfs/tftpDriver.c
> index 7cbb402..7dc60b2 100644
> --- a/cpukit/libfs/src/ftpfs/tftpDriver.c
> +++ b/cpukit/libfs/src/ftpfs/tftpDriver.c
> @@ -1,8 +1,6 @@
> - * Trivial File Transfer Protocol (RFC 1350)
> - * Transfer file to/from remote host
> * W. Eric Norum
> * Saskatchewan Accelerator Laboratory
> * University of Saskatchewan
> @@ -12,6 +10,26 @@
> + * are met:
> @@ -1039,7 +1057,7 @@ static const rtems_filesystem_operations_table rtems_tftp_ops = {
> .fsunmount_me_h = rtems_tftpfs_shutdown,
> diff --git a/cpukit/libfs/src/imfs/imfs_init.c b/cpukit/libfs/src/imfs/imfs_init.c
> index 1b9b769..8685caa 100644
> --- a/cpukit/libfs/src/imfs/imfs_init.c
> +++ b/cpukit/libfs/src/imfs/imfs_init.c
> @@ -1,3 +1,5 @@
> * @file
> @@ -7,12 +9,28 @@
> - * COPYRIGHT (c) 1989-1999.
> + * are met:
> @@ -40,7 +58,7 @@ static const rtems_filesystem_operations_table IMFS_ops = {
> .mount_h = IMFS_mount,
> .unmount_h = IMFS_unmount,
> .fsunmount_me_h = IMFS_fsunmount,
> - .utime_h = IMFS_utime,
> + .utimens_h = IMFS_utimens,
> .symlink_h = IMFS_symlink,
> .readlink_h = IMFS_readlink,
> .rename_h = IMFS_rename,
> diff --git a/cpukit/libfs/src/imfs/imfs_utime.c b/cpukit/libfs/src/imfs/imfs_utime.c
> index 21e5139..0000000
> --- a/cpukit/libfs/src/imfs/imfs_utime.c
> +++ /dev/null
> @@ -1,41 +0,0 @@
> - * @file
> - * @ingroup IMFS
> - * @brief Set IMFS File Access and Modification Times
> -#endif
> -#include <rtems/imfs.h>
> -#include <sys/time.h>
> -int IMFS_utime(
> - time_t actime,
> - time_t modtime
> - IMFS_jnode_t *the_jnode;
> - the_jnode = (IMFS_jnode_t *) loc->node_access;
> - the_jnode->stat_atime = actime;
> - the_jnode->stat_mtime = modtime;
> - the_jnode->stat_ctime = time( NULL );
> - return 0;
> diff --git a/cpukit/libfs/src/imfs/imfs_utimens.c b/cpukit/libfs/src/imfs/imfs_utimens.c
> index 0000000..e38802c
> --- /dev/null
> +++ b/cpukit/libfs/src/imfs/imfs_utimens.c
> @@ -0,0 +1,58 @@
> + * @file
> + * @ingroup IMFS
> + * @brief Set IMFS File Access and Modification Times
> + * are met:
> +#endif
> +#include <rtems/imfs.h>
> +#include <sys/time.h>
> +int IMFS_utimens(
> + IMFS_jnode_t *the_jnode;
> + the_jnode = (IMFS_jnode_t *) loc->node_access;
> + the_jnode->stat_atime = times[0].tv_sec;
> + the_jnode->stat_mtime = times[1].tv_sec;
> + the_jnode->stat_ctime = time( NULL );
> + return 0;
> diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c b/cpukit/libfs/src/jffs2/src/fs-rtems.c
> index aae208c..8bc3d85 100644
> --- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
> +++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
> @@ -1118,10 +1118,9 @@ static int rtems_jffs2_statvfs(
> return 0;
> -static int rtems_jffs2_utime(
> +static int rtems_jffs2_utimens(
> - time_t actime,
> - time_t modtime
> struct _inode *inode = rtems_jffs2_get_inode_by_location(loc);
> @@ -1129,8 +1128,8 @@ static int rtems_jffs2_utime(
> int eno;
> iattr.ia_valid = ATTR_ATIME | ATTR_MTIME | ATTR_CTIME;
> - iattr.ia_atime = actime;
> - iattr.ia_mtime = modtime;
> + iattr.ia_atime = times[0].tv_sec;
> + iattr.ia_mtime = times[1].tv_sec;
> iattr.ia_ctime = get_seconds();
> eno = -jffs2_do_setattr(inode, &iattr);
> @@ -1186,7 +1185,7 @@ static const rtems_filesystem_operations_table rtems_jffs2_ops = {
> .fsunmount_me_h = rtems_jffs2_fsunmount,
> - .utime_h = rtems_jffs2_utime,
> + .utimens_h = rtems_jffs2_utimens,
> .symlink_h = rtems_jffs2_symlink,
> .readlink_h = rtems_jffs2_readlink,
> .rename_h = rtems_jffs2_rename,
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
> index 35db9ee..0efab2c 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
> @@ -296,16 +296,14 @@ rtems_rfs_rtems_chown (const rtems_filesystem_location_info_t *pathloc,
> * This routine is the implementation of the utime() system call for the
> * RFS.
> - * @param pathloc
> - * @param atime
> - * @param mtime
> + * @param pathloc The path to the file to be modified
> + * @param times The times to update the file to
> * return int
> static int
> -rtems_rfs_rtems_utime(const rtems_filesystem_location_info_t* pathloc,
> - time_t atime,
> - time_t mtime)
> +rtems_rfs_rtems_utimens(const rtems_filesystem_location_info_t* pathloc,
> + struct timespec times[2])
> rtems_rfs_file_system* fs = rtems_rfs_rtems_pathloc_dev (pathloc);
> rtems_rfs_ino ino = rtems_rfs_rtems_get_pathloc_ino (pathloc);
> @@ -318,8 +316,8 @@ rtems_rfs_rtems_utime(const rtems_filesystem_location_info_t* pathloc,
> return rtems_rfs_rtems_error ("utime: read inode", rc);
> - rtems_rfs_inode_set_atime (&inode, atime);
> - rtems_rfs_inode_set_mtime (&inode, mtime);
> + rtems_rfs_inode_set_atime (&inode, times[0].tv_sec);
> + rtems_rfs_inode_set_mtime (&inode, times[1].tv_sec);
> rc = rtems_rfs_inode_close (fs, &inode);
> if (rc)
> @@ -735,7 +733,7 @@ const rtems_filesystem_operations_table rtems_rfs_ops =
> .fsunmount_me_h = rtems_rfs_rtems_shutdown,
> - .utime_h = rtems_rfs_rtems_utime,
> + .utimens_h = rtems_rfs_rtems_utimens,
> .symlink_h = rtems_rfs_rtems_symlink,
> .readlink_h = rtems_rfs_rtems_readlink,
> .rename_h = rtems_rfs_rtems_rename,
> diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
> index 7f36ef7..133c84c 100644
> --- a/spec/build/cpukit/librtemscpu.yml
> +++ b/spec/build/cpukit/librtemscpu.yml
> @@ -804,7 +804,7 @@ source:
> - cpukit/libfs/src/defaults/default_statvfs.c
> - cpukit/libfs/src/defaults/default_symlink.c
> - cpukit/libfs/src/defaults/default_unmount.c
> -- cpukit/libfs/src/defaults/default_utime.c
> +- cpukit/libfs/src/defaults/default_utimens.c
> - cpukit/libfs/src/defaults/default_write.c
> - cpukit/libfs/src/defaults/default_writev.c
> - cpukit/libfs/src/dosfs/fat.c
> @@ -861,7 +861,7 @@ source:
> - cpukit/libfs/src/imfs/imfs_stat_file.c
> - cpukit/libfs/src/imfs/imfs_symlink.c
> - cpukit/libfs/src/imfs/imfs_unmount.c
> -- cpukit/libfs/src/imfs/imfs_utime.c
> +- cpukit/libfs/src/imfs/imfs_utimens.c
> - cpukit/libfs/src/imfs/ioman.c
> - cpukit/libfs/src/pipe/fifo.c
> - cpukit/libfs/src/pipe/pipe.c
> 1.8.3.1
> devel mailing list
> devel at rtems.org
