[PATCH 3/3] posix: Allow pthread_cancel() from within ISRs
Mon May 17 13:06:55 UTC 2021
Close #4413.
 cpukit/posix/src/cancel.c              | 13 ++---
 testsuites/psxtests/psxcancel01/init.c | 72 +++++++++++++++-----------
 2 files changed, 45 insertions(+), 40 deletions(-)
diff --git a/cpukit/posix/src/cancel.c b/cpukit/posix/src/cancel.c
index f2636e6a97..aa4a434037 100644
--- a/cpukit/posix/src/cancel.c
+++ b/cpukit/posix/src/cancel.c
@@ -38,14 +38,6 @@ int pthread_cancel( pthread_t thread )
   Thread_Control   *executing;
   Per_CPU_Control  *cpu_self;
-   *  Don't even think about deleting a resource from an ISR.
-  if ( _ISR_Is_in_progress() ) {
-    return EPROTO;
   the_thread = _Thread_Get( thread, &lock_context );
   if ( the_thread == NULL ) {
@@ -55,7 +47,10 @@ int pthread_cancel( pthread_t thread )
   cpu_self = _Per_CPU_Get();
   executing = _Per_CPU_Get_executing( cpu_self );
-  if ( the_thread == executing ) {
+  if (
+    the_thread == executing &&
+    !_Per_CPU_Is_ISR_in_progress( cpu_self )
     _ISR_lock_ISR_enable( &lock_context );
     _Thread_Exit( PTHREAD_CANCELED, THREAD_LIFE_TERMINATING );
   } else {
diff --git a/testsuites/psxtests/psxcancel01/init.c b/testsuites/psxtests/psxcancel01/init.c
index d87295ccd1..b0da991bad 100644
--- a/testsuites/psxtests/psxcancel01/init.c
+++ b/testsuites/psxtests/psxcancel01/init.c
@@ -18,38 +18,37 @@ const char rtems_test_name[] = "PSXCANCEL 1";
 /* forward declarations to avoid warnings */
 void *POSIX_Init(void *argument);
-rtems_timer_service_routine Cancel_duringISR_TSR(
-  rtems_id  ignored_id,
-  void     *ignored_address
-rtems_timer_service_routine SetState_duringISR_TSR(
-rtems_timer_service_routine SetType_duringISR_TSR(
-void doit(
-  rtems_timer_service_routine (*TSR)(rtems_id, void *),
-  const char                   *method
-volatile int TSR_occurred;
-volatile int TSR_status;
+static volatile int TSR_occurred;
+static volatile int TSR_status;
+static rtems_id  timer_id;
-rtems_id  timer_id;
+static pthread_t thread;
+static void *suspend_self( void *arg )
+  rtems_status_code status;
+  (void) arg;
+  status = rtems_task_suspend( RTEMS_SELF);
+  rtems_test_assert( status == RTEMS_SUCCESSFUL );
+  return NULL;
+static rtems_timer_service_routine Cancel_duringISR_TSR(
-  TSR_status = pthread_cancel( pthread_self() );
+  TSR_status = pthread_cancel( thread );
   TSR_occurred = 1;
+static rtems_timer_service_routine SetState_duringISR_TSR(
@@ -60,7 +59,7 @@ rtems_timer_service_routine SetState_duringISR_TSR(
   TSR_occurred = 1;
+static rtems_timer_service_routine SetType_duringISR_TSR(
@@ -71,9 +70,10 @@ rtems_timer_service_routine SetType_duringISR_TSR(
   TSR_occurred = 1;
-void doit(
+static void doit(
+  const char                   *method,
+  int                           expected_status
   rtems_interval    start;
@@ -97,11 +97,11 @@ void doit(
     printf( "%s did not occur\n", method );
     rtems_test_exit(0);
-  if ( TSR_status != EPROTO ) {
+  if ( TSR_status != expected_status ) {
     printf( "%s returned %s\n", method, strerror(TSR_status) );
     rtems_test_exit(0);
-  printf( "%s - from ISR returns EPROTO - OK\n", method );
+  printf( "%s - from ISR returns expected status - OK\n", method );
@@ -110,6 +110,8 @@ void *POSIX_Init(
+  int               eno;
+  void             *value;
   TEST_BEGIN();
@@ -119,9 +121,17 @@ void *POSIX_Init(
   rtems_test_assert( !status );
-  doit( Cancel_duringISR_TSR, "pthread_cancel" );
-  doit( SetState_duringISR_TSR, "pthread_setcancelstate" );
-  doit( SetType_duringISR_TSR, "pthread_setcanceltype" );
+  eno = pthread_create( &thread, NULL, suspend_self, NULL );
+  rtems_test_assert( eno == 0 );
+  doit( Cancel_duringISR_TSR, "pthread_cancel", 0 );
+  doit( SetState_duringISR_TSR, "pthread_setcancelstate", EPROTO );
+  doit( SetType_duringISR_TSR, "pthread_setcanceltype", EPROTO );
+  value = NULL;
+  eno = pthread_join( thread, &value );
+  rtems_test_assert( value == PTHREAD_CANCELED );
   TEST_END();
   rtems_test_exit(0);
@@ -137,7 +147,7 @@ void *POSIX_Init(
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_MAXIMUM_POSIX_THREADS        1
+#define CONFIGURE_MAXIMUM_POSIX_THREADS        2
 #define CONFIGURE_POSIX_INIT_THREAD_TABLE
2.26.2
