[PATCH v5 1/5] libcsupport: Added futimens() and utimensat()
Ryan Long
ryan.long at oarcorp.com
Mon May 17 13:24:49 UTC 2021
Created futimens.c and utimensat.c to add support for the POSIX
methods futimens() and utimensat().
utime() and utimes() are considered obsolote by POSIX, but RTEMS
will continue to support them.
Closes #4396
cpukit/Makefile.am | 2 +
cpukit/include/rtems/libio_.h | 95 +++++++++++--
cpukit/include/rtems/score/timespec.h | 44 +++++-
cpukit/libcsupport/src/futimens.c | 87 ++++++++++++
cpukit/libcsupport/src/utimensat.c | 225 +++++++++++++++++++++++++++++++
cpukit/score/src/timespecisnonnegative.c | 54 ++++++++
spec/build/cpukit/librtemscpu.yml | 3 +
7 files changed, 495 insertions(+), 15 deletions(-)
create mode 100644 cpukit/libcsupport/src/futimens.c
create mode 100644 cpukit/libcsupport/src/utimensat.c
create mode 100644 cpukit/score/src/timespecisnonnegative.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index b0df610..29b4207 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -262,6 +262,8 @@ librtemscpu_a_SOURCES += libcsupport/src/unmount.c
librtemscpu_a_SOURCES += libcsupport/src/__usrenv.c
librtemscpu_a_SOURCES += libcsupport/src/utime.c
librtemscpu_a_SOURCES += libcsupport/src/utimes.c
+librtemscpu_a_SOURCES += libcsupport/src/futimens.c
+librtemscpu_a_SOURCES += libcsupport/src/utimensat.c
librtemscpu_a_SOURCES += libcsupport/src/utsname.c
librtemscpu_a_SOURCES += libcsupport/src/vprintk.c
librtemscpu_a_SOURCES += libcsupport/src/write.c
diff --git a/cpukit/include/rtems/libio_.h b/cpukit/include/rtems/libio_.h
index e9eb462..26d6c1e 100644
--- a/cpukit/include/rtems/libio_.h
+++ b/cpukit/include/rtems/libio_.h
@@ -1,23 +1,42 @@
* @file
* @brief LibIO Internal Interface
* This file is the libio internal interface.
- * COPYRIGHT (c) 1989-2011.
- * On-Line Applications Research Corporation (OAR).
+ * COPYRIGHT (C) 1989, 2021 On-Line Applications Research Corporation (OAR).
- * Modifications to support reference counting in the file system are
- * Copyright (c) 2012 embedded brains GmbH.
+ * Modifications to support reference counting in the file system are
+ * Copyright (c) 2012 embedded brains GmbH.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
#ifndef _RTEMS_RTEMS_LIBIO__H
#define _RTEMS_RTEMS_LIBIO__H
@@ -30,6 +49,7 @@
#include <rtems/libio.h>
#include <rtems/seterr.h>
+#include <rtems/score/timespec.h>
#ifdef __cplusplus
extern "C" {
@@ -357,6 +377,65 @@ static inline void rtems_filesystem_instance_unlock(
(*mt_entry->ops->unlock_h)( mt_entry );
+ * @brief Checks the tv_nsec member of a timespec struct
+ * This function is used with utimensat() and futimens() only. This ensures
+ * that the value in the tv_nsec member is equal to either UTIME_NOW,
+ * UTIME_OMIT, or a value greater-than or equal to zero and less than a
+ * billion.
+ * @param[in] time The timespec struct to be validated
+ * @retval true The tv_nsec member is a valid value.
+ * @retval false The tv_nsec member is not a valid value.
+bool rtems_filesystem_utime_tv_nsec_valid( struct timespec time );
+ * @brief Checks for errors and if the process has write permissions to the file.
+ * This function is only used with utimensat() and futimens().It checks for
+ * EACCES and EPERM errors depending on what values are in @a times and if the
+ * process has write permissions to the file.
+ * @param[in] currentloc The current location to a file
+ * @param[in] times The timespecs used to check for errors. The timespec at
+ * index 0 is the access time, and the timespec at index 1 is
+ * the modification time.
+ * @retval 0 An error was not found.
+ * @retval -1 An error was found.
+int rtems_filesystem_utime_check_permissions(
+ const rtems_filesystem_location_info_t *currentloc,
+ const struct timespec times[2]
+ * @brief Checks @a times and fills @a new_times with the time to be written
+ * This function is only used with utimensat() and futimens(). @a times contains
+ * the constant values passed into utimensat/futimens. @a new_times contains the
+ * values that will be written to the file. These values depend on @a times. If
+ * @a times is NULL, or either of its elements' tv_nsec members are UTIME_NOW,
+ * the current elapsed time in nanoseconds will be saved in the corresponding
+ * location in @a new_times.
+ * For each of the arguments, the timespec at index 0 is the access time, and
+ * the timespec at index 1 is the modification time.
+ * @param[in] times The timespecs to be checked
+ * @param[out] new_times The timespecs containing the time to be written
+ * @retval 0 @a times is valid.
+ * @retval -1 @a times is not valid.
+int rtems_filesystem_utime_update(
+ const struct timespec times[2],
+ struct timespec new_times[2]
* File Descriptor Routine Prototypes
diff --git a/cpukit/include/rtems/score/timespec.h b/cpukit/include/rtems/score/timespec.h
index 314d804..2090f19 100644
--- a/cpukit/include/rtems/score/timespec.h
+++ b/cpukit/include/rtems/score/timespec.h
@@ -1,19 +1,37 @@
* @file
* @ingroup Timespec
* @brief This header file provides the interfaces of the
- * @ref RTEMSScoreTimespec.
+ * @ref RTEMSScoreTimespec.
- * COPYRIGHT (c) 1989-2009.
+ * are met:
#ifndef _RTEMS_SCORE_TIMESPEC_H
@@ -106,6 +124,18 @@ uint64_t _Timespec_Get_as_nanoseconds(
+ * @brief Checks if the values in @a time are non-negative.
+ * @param[in] time is the timespec instance to validate.
+ * @retval true If @a time is filled with non-negative values.
+ * @retval false If @a time is not filled with non-negative values.
+bool _Timespec_Is_non_negative(
+ const struct timespec *time
* @brief Checks if timespec is valid.
* This method determines the validity of a timespec.
diff --git a/cpukit/libcsupport/src/futimens.c b/cpukit/libcsupport/src/futimens.c
new file mode 100644
index 0000000..f82c782
--- /dev/null
+++ b/cpukit/libcsupport/src/futimens.c
@@ -0,0 +1,87 @@
+ * @file
+ * @ingroup libcsupport
+ * @brief Set file access and modification times based on file descriptor in
+ * nanoseconds.
+ * COPYRIGHT (C) 2021 On-Line Applications Research Corporation (OAR).
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <sys/stat.h>
+#include <rtems/libio_.h>
+#include <fcntl.h>
+#include <stdlib.h>
+#include <string.h>
+ * https://pubs.opengroup.org/onlinepubs/9699919799.2008edition/functions/futimens.html
+ * Set file access and modification times
+int futimens(
+ int fd,
+ int rv;
+ rtems_libio_t *iop;
+ struct timespec new_times[2];
+ const rtems_filesystem_location_info_t *currentloc = NULL;
+ LIBIO_GET_IOP_WITH_ACCESS( fd, iop, LIBIO_FLAGS_READ, EBADF );
+ currentloc = &iop->pathinfo;
+ rv = rtems_filesystem_utime_update( times, new_times );
+ if ( rv != 0 ) {
+ rtems_libio_iop_drop( iop );
+ return rv;
+ rv = rtems_filesystem_utime_check_permissions( currentloc, times );
+ if ( rv != 0 ) {
+ return rv;
+ rv = (*currentloc->mt_entry->ops->utime_h)(
+ currentloc,
+ new_times
+ return rv;
diff --git a/cpukit/libcsupport/src/utimensat.c b/cpukit/libcsupport/src/utimensat.c
index 0000000..3e91b65
--- /dev/null
+++ b/cpukit/libcsupport/src/utimensat.c
@@ -0,0 +1,225 @@
+ * @file
+ * @brief Set file access and modification times in nanoseconds.
+ * are met:
+#endif
+#include <rtems/score/todimpl.h>
+#include <fcntl.h>
+ * Make sure that tv_nsec is either UTIME_NOW, UTIME_OMIT, a value
+ * greater than zero, or a value less-than a billion.
+ * These guidelines come from the description of the EINVAL errors on
+ * https://pubs.opengroup.org/onlinepubs/9699919799/functions/futimens.html
+bool rtems_filesystem_utime_tv_nsec_valid(struct timespec time)
+ if ( time.tv_nsec == UTIME_NOW ) {
+ return true;
+ if ( time.tv_nsec == UTIME_OMIT ) {
+ return true;
+ if ( time.tv_nsec < 0 ) {
+ return false;
+ if ( time.tv_nsec >= TOD_NANOSECONDS_PER_SECOND ) {
+ return false;
+ return true;
+/* Determine whether the access and modified timestamps can be updated */
+ const rtems_filesystem_location_info_t * currentloc,
+ struct stat st = {};
+ int rv;
+ bool write_access;
+ rv = (*currentloc->handlers->fstat_h)( currentloc, &st );
+ if ( rv != 0 ) {
+ rtems_set_errno_and_return_minus_one( ENOENT );
+ write_access = rtems_filesystem_check_access(
+ RTEMS_FS_PERMS_WRITE,
+ st.st_mode,
+ st.st_uid,
+ st.st_gid
+ * The logic for the EACCES error is an inverted subset of the EPERM
+ * conditional according to the POSIX standard.
+ if ( (times == NULL) ||
+ ( (times[0].tv_nsec == UTIME_NOW) && (times[1].tv_nsec == UTIME_NOW) )) {
+ if ( !write_access ) {
+ rtems_set_errno_and_return_minus_one( EACCES );
+ } else {
+ if ( times[0].tv_nsec != UTIME_OMIT || times[1].tv_nsec != UTIME_OMIT ) {
+ rtems_set_errno_and_return_minus_one( EPERM );
+ return 0;
+ * Determine if the current time needs to be gotten, and then check
+ * whether the values in times are valid.
+ bool got_time = false;
+ struct timespec now;
+ * If times is NULL, it's equivalent to adding UTIME_NOW in both time
+ * elements
+ if ( times == NULL ) {
+ _Timespec_Set( &new_times[0], 0, UTIME_NOW );
+ _Timespec_Set( &new_times[1], 0, UTIME_NOW );
+ } else {
+ new_times[0] = times[0];
+ new_times[1] = times[1];
+ if ( new_times[0].tv_nsec == UTIME_NOW ) {
+ clock_gettime( CLOCK_REALTIME, &now );
+ new_times[0] = now;
+ got_time = true;
+ if ( new_times[1].tv_nsec == UTIME_NOW ) {
+ if ( !got_time ) {
+ new_times[1] = now;
+ if ( !_Timespec_Is_non_negative( &new_times[0] ) ) {
+ rtems_set_errno_and_return_minus_one( EINVAL );
+ if ( !_Timespec_Is_non_negative( &new_times[1] ) ) {
+ if ( !rtems_filesystem_utime_tv_nsec_valid( new_times[0] ) ) {
+ if ( !rtems_filesystem_utime_tv_nsec_valid( new_times[1] ) ) {
+ return 0;
+int utimensat(
+ int fd,
+ const char *path,
+ int flag
+ int rv = 0;
+ rtems_filesystem_eval_path_context_t ctx;
+ int eval_flags = RTEMS_FS_FOLLOW_LINK;
+ * RTEMS does not currently support operating on a real file descriptor
+ if ( fd != AT_FDCWD ) {
+ rtems_set_errno_and_return_minus_one( ENOSYS );
+ * RTEMS does not currently support AT_SYMLINK_NOFOLLOW
+ if ( flag != 0 ) {
+ if ( rv != 0 ) {
+ return rv;
+ currentloc = rtems_filesystem_eval_path_start( &ctx, path, eval_flags );
+ if ( rv != 0 ) {
+ rtems_filesystem_eval_path_cleanup( &ctx );
+ return rv;
+ currentloc,
+ new_times
+ return rv;
diff --git a/cpukit/score/src/timespecisnonnegative.c b/cpukit/score/src/timespecisnonnegative.c
index 0000000..2945076
--- /dev/null
+++ b/cpukit/score/src/timespecisnonnegative.c
@@ -0,0 +1,54 @@
+ * @file
+ * @ingroup RTEMSScoreTimespec
+ * @brief This source file contains the implementation of
+ * _Timespec_Is_non_negative().
+ * are met:
+#endif
+ if ( time->tv_sec < 0 )
+ return false;
+ if ( time->tv_nsec < 0 )
+ return false;
+ return true;
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index a3a9ee4..7f36ef7 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -761,6 +761,8 @@ source:
- cpukit/libcsupport/src/unmount.c
- cpukit/libcsupport/src/utime.c
- cpukit/libcsupport/src/utimes.c
+- cpukit/libcsupport/src/futimens.c
+- cpukit/libcsupport/src/utimensat.c
- cpukit/libcsupport/src/utsname.c
- cpukit/libcsupport/src/vprintk.c
- cpukit/libcsupport/src/write.c
@@ -1558,6 +1560,7 @@ source:
- cpukit/score/src/threadyield.c
- cpukit/score/src/timespecaddto.c
- cpukit/score/src/timespecdivide.c
+- cpukit/score/src/timespecisnonnegative.c
- cpukit/score/src/timespecdividebyinteger.c
- cpukit/score/src/timespecfromticks.c
- cpukit/score/src/timespecgetasnanoseconds.c
1.8.3.1
