[PATCH v5 2/5] libcsupport: Implement utime() in terms of utimensat()
Ryan Long ryan.long at oarcorp.com
Mon May 17 13:24:50 UTC 2021
utime() now calls utimensat() to update file access
and modification timestamps.
Updated license.
Closes #4397
 cpukit/libcsupport/src/utime.c | 72 +++++++++++++++++++++++-------------------
 1 file changed, 40 insertions(+), 32 deletions(-)
diff --git a/cpukit/libcsupport/src/utime.c b/cpukit/libcsupport/src/utime.c
index e2d8883..5d80ca3 100644
--- a/cpukit/libcsupport/src/utime.c
+++ b/cpukit/libcsupport/src/utime.c
@@ -1,58 +1,66 @@
  *  @file
- *  @brief Set File Access and Modification Times
  *  @ingroup libcsupport
+ *  @brief Set file access and modification times in seconds.
- *  COPYRIGHT (c) 1989-1999.
- *  On-Line Applications Research Corporation (OAR).
+ * COPYRIGHT (C) 1989, 2021 On-Line Applications Research Corporation (OAR).
+ * are met:
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
 #ifdef HAVE_CONFIG_H
 #include "config.h"
 #endif
-/* FIXME: This include is a workaround for a broken <utime.h> in Newlib */
-#include <sys/types.h>
+#include <sys/stat.h>
+#include <rtems/libio_.h>
+#include <fcntl.h>
 #include <utime.h>
-#include <rtems/libio_.h>
- *  POSIX 1003.1b 5.5.6 - Set File Access and Modification Times
+ *  https://pubs.opengroup.org/onlinepubs/009604599/functions/utime.html
+ *  Set file access and modification times
-int utime( const char *path, const struct utimbuf *times )
+int utime(
+  const char *path,
+  const struct utimbuf *times
-  int rv = 0;
-  rtems_filesystem_eval_path_context_t ctx;
-  int eval_flags = RTEMS_FS_FOLLOW_LINK;
-  const rtems_filesystem_location_info_t *currentloc =
-    rtems_filesystem_eval_path_start( &ctx, path, eval_flags );
-  struct utimbuf now_times;
+  struct timespec new_times[2];
   if ( times == NULL ) {
-    time_t now = time( NULL );
-    now_times.actime = now;
-    now_times.modtime = now;
-    times = &now_times;
+    return utimensat(AT_FDCWD, path, NULL, 0);
-  rv = (*currentloc->mt_entry->ops->utime_h)(
-    currentloc,
-    times->actime,
-    times->modtime
-  rtems_filesystem_eval_path_cleanup( &ctx );
+  _Timespec_Set(&new_times[0], times->actime, 0);
+  _Timespec_Set(&new_times[1], times->modtime, 0);
-  return rv;
+  return utimensat(AT_FDCWD, path, new_times, 0);
1.8.3.1
