[PATCH] score: Move _Thread_queue_Queue_get_name_and_id()
Sebastian Huber
Mon May 17 14:59:47 UTC 2021
Move this diagnostic function to a separate file since it does not
provide a core function of the system.
Change license to BSD-2-Clause according to file history and
re-licensing agreement.
Update #3053.
cpukit/Makefile.am | 1 +
cpukit/score/src/threadq.c | 36 ------------
cpukit/score/src/threadqgetnameandid.c | 76 ++++++++++++++++++++++++++
spec/build/cpukit/librtemscpu.yml | 1 +
4 files changed, 78 insertions(+), 36 deletions(-)
create mode 100644 cpukit/score/src/threadqgetnameandid.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 0178d5d82a..7e7c267fc1 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -984,6 +984,7 @@ librtemscpu_a_SOURCES += score/src/threadqenqueue.c
librtemscpu_a_SOURCES += score/src/threadqextractwithproxy.c
librtemscpu_a_SOURCES += score/src/threadqfirst.c
librtemscpu_a_SOURCES += score/src/threadqflush.c
+librtemscpu_a_SOURCES += score/src/threadqgetnameandid.c
librtemscpu_a_SOURCES += score/src/threadqops.c
librtemscpu_a_SOURCES += score/src/threadqtimeout.c
librtemscpu_a_SOURCES += score/src/timespecaddto.c
diff --git a/cpukit/score/src/threadq.c b/cpukit/score/src/threadq.c
index 55d8760f7c..e322b46b5e 100644
--- a/cpukit/score/src/threadq.c
+++ b/cpukit/score/src/threadq.c
@@ -25,11 +25,7 @@
#include "config.h"
#endif
-#include <string.h>
-#include <rtems/score/rbtreeimpl.h>
-#include <rtems/score/threadimpl.h>
RTEMS_STATIC_ASSERT(
#if defined(RTEMS_SMP)
@@ -166,35 +162,3 @@ void _Thread_queue_MP_callout_do_nothing(
/* Do nothing */
#endif
-size_t _Thread_queue_Queue_get_name_and_id(
- const Thread_queue_Queue *queue,
- char *buffer,
- size_t buffer_size,
- Objects_Id *id
- const char *name;
- name = queue->name;
- if ( name == _Thread_queue_Object_name ) {
- const Thread_queue_Object *queue_object;
- queue_object = THREAD_QUEUE_QUEUE_TO_OBJECT( queue );
- *id = queue_object->Object.id;
- return _Objects_Name_to_string(
- queue_object->Object.name,
- false,
- buffer,
- buffer_size
- } else {
- if ( name == NULL ) {
- name = _Thread_queue_Object_name;
- *id = 0;
- return strlcpy( buffer, name, buffer_size );
diff --git a/cpukit/score/src/threadqgetnameandid.c b/cpukit/score/src/threadqgetnameandid.c
new file mode 100644
index 0000000000..ea4e2203e6
--- /dev/null
+++ b/cpukit/score/src/threadqgetnameandid.c
@@ -0,0 +1,76 @@
+ * @file
+ * @ingroup RTEMSScoreThreadQueue
+ * @brief This source file contains the implementation of
+ * _Thread_queue_Queue_get_name_and_id().
+ * Copyright (C) 2017 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/threadqimpl.h>
+#include <rtems/score/objectimpl.h>
+#include <string.h>
+size_t _Thread_queue_Queue_get_name_and_id(
+ const Thread_queue_Queue *queue,
+ char *buffer,
+ size_t buffer_size,
+ Objects_Id *id
+ const char *name;
+ name = queue->name;
+ if ( name == _Thread_queue_Object_name ) {
+ const Thread_queue_Object *queue_object;
+ queue_object = THREAD_QUEUE_QUEUE_TO_OBJECT( queue );
+ *id = queue_object->Object.id;
+ return _Objects_Name_to_string(
+ queue_object->Object.name,
+ false,
+ buffer,
+ buffer_size
+ } else {
+ if ( name == NULL ) {
+ name = _Thread_queue_Object_name;
+ *id = 0;
+ return strlcpy( buffer, name, buffer_size );
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 682032182f..ac9e494f0c 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1542,6 +1542,7 @@ source:
- cpukit/score/src/threadqextractwithproxy.c
- cpukit/score/src/threadqfirst.c
- cpukit/score/src/threadqflush.c
+- cpukit/score/src/threadqgetnameandid.c
- cpukit/score/src/threadqops.c
- cpukit/score/src/threadqtimeout.c
- cpukit/score/src/threadrestart.c
2.26.2
