[PATCH 2/2] posix: Use RTEMS_POSIX_API in clock_nanosleep()
    Sebastian Huber
    Mon May 17 15:01:34 UTC 2021
It is only possible to get interrupted by a POSIX signal if
RTEMS_POSIX_API is defined.
 cpukit/posix/src/clocknanosleep.c | 5 +++++
 1 file changed, 5 insertions(+)
diff --git a/cpukit/posix/src/clocknanosleep.c b/cpukit/posix/src/clocknanosleep.c
index 73b7d9c6a1..951268bc1f 100644
--- a/cpukit/posix/src/clocknanosleep.c
+++ b/cpukit/posix/src/clocknanosleep.c
@@ -97,6 +97,7 @@ int clock_nanosleep(
   if ( rmtp != NULL && ( flags & TIMER_ABSTIME ) == 0 ) {
+#if defined( RTEMS_POSIX_API )
     if ( eno == EINTR ) {
       struct timespec actual_end;
@@ -110,6 +111,10 @@ int clock_nanosleep(
     } else {
       _Timespec_Set_to_zero( rmtp );
+#else
+    _Assert( eno != EINTR );
+    _Timespec_Set_to_zero( rmtp );
+#endif
   return eno;
2.26.2
