[PATCH 1/2] posix: Move clock_nanosleep()
Sebastian Huber
Mon May 17 15:01:33 UTC 2021
Move clock_nanosleep() to a separate file to avoid a dependency on errno
which pulls in the Newlib reentrancy support.
cpukit/Makefile.am | 1 +
cpukit/posix/src/clocknanosleep.c | 116 ++++++++++++++++++++++++++++++
cpukit/posix/src/nanosleep.c | 91 -----------------------
spec/build/cpukit/librtemscpu.yml | 1 +
4 files changed, 118 insertions(+), 91 deletions(-)
create mode 100644 cpukit/posix/src/clocknanosleep.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 0178d5d82a..a5f3a9665f 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -490,6 +490,7 @@ librtemscpu_a_SOURCES += posix/src/cleanuppush.c
librtemscpu_a_SOURCES += posix/src/clockgetcpuclockid.c
librtemscpu_a_SOURCES += posix/src/clockgetres.c
librtemscpu_a_SOURCES += posix/src/clockgettime.c
+librtemscpu_a_SOURCES += posix/src/clocknanosleep.c
librtemscpu_a_SOURCES += posix/src/clocksettime.c
librtemscpu_a_SOURCES += posix/src/condattrdestroy.c
librtemscpu_a_SOURCES += posix/src/condattrgetclock.c
diff --git a/cpukit/posix/src/clocknanosleep.c b/cpukit/posix/src/clocknanosleep.c
new file mode 100644
index 0000000000..73b7d9c6a1
--- /dev/null
+++ b/cpukit/posix/src/clocknanosleep.c
@@ -0,0 +1,116 @@
+ * @file
+ * @ingroup POSIXAPI
+ * @brief Suspends Execution of calling thread until Time elapses
+ * COPYRIGHT (c) 1989-2015.
+ * On-Line Applications Research Corporation (OAR).
+ * Copyright (c) 2016. Gedare Bloom.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <time.h>
+#include <rtems/score/threadimpl.h>
+#include <rtems/score/threadqimpl.h>
+#include <rtems/score/timespec.h>
+#include <rtems/score/timecounter.h>
+#include <rtems/score/watchdogimpl.h>
+#include <rtems/posix/posixapi.h>
+static Thread_queue_Control _Nanosleep_Pseudo_queue =
+ THREAD_QUEUE_INITIALIZER( "Nanosleep" );
+ * High Resolution Sleep with Specifiable Clock, IEEE Std 1003.1, 2001
+int clock_nanosleep(
+ clockid_t clock_id,
+ int flags,
+ const struct timespec *rqtp,
+ struct timespec *rmtp
+ Thread_queue_Context queue_context;
+ struct timespec uptime;
+ const struct timespec *end;
+ Thread_Control *executing;
+ int eno;
+ if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC ) {
+ return ENOTSUP;
+ _Thread_queue_Context_initialize( &queue_context );
+ _Thread_queue_Context_set_thread_state(
+ &queue_context,
+ STATES_WAITING_FOR_TIME | STATES_INTERRUPTIBLE_BY_SIGNAL
+ if ( ( flags & TIMER_ABSTIME ) != 0 ) {
+ end = rqtp;
+ if ( clock_id == CLOCK_REALTIME ) {
+ _Thread_queue_Context_set_enqueue_timeout_realtime_timespec(
+ &queue_context,
+ end
+ } else {
+ _Thread_queue_Context_set_enqueue_timeout_monotonic_timespec(
+ &queue_context,
+ end
+ } else {
+ _Timecounter_Nanouptime( &uptime );
+ end = _Watchdog_Future_timespec( &uptime, rqtp );
+ &queue_context,
+ end
+ _Thread_queue_Acquire( &_Nanosleep_Pseudo_queue, &queue_context );
+ executing = _Thread_Executing;
+ _Thread_queue_Enqueue(
+ &_Nanosleep_Pseudo_queue.Queue,
+ &_Thread_queue_Operations_FIFO,
+ executing,
+ &queue_context
+ eno = _POSIX_Get_error_after_wait( executing );
+ if ( eno == ETIMEDOUT ) {
+ eno = 0;
+ if ( rmtp != NULL && ( flags & TIMER_ABSTIME ) == 0 ) {
+ if ( eno == EINTR ) {
+ struct timespec actual_end;
+ _Timecounter_Nanouptime( &actual_end );
+ if ( _Timespec_Less_than( &actual_end, end ) ) {
+ _Timespec_Subtract( &actual_end, end, rmtp );
+ } else {
+ _Timespec_Set_to_zero( rmtp );
+ } else {
+ return eno;
diff --git a/cpukit/posix/src/nanosleep.c b/cpukit/posix/src/nanosleep.c
index 8d1a4b84e4..167dcbc787 100644
--- a/cpukit/posix/src/nanosleep.c
+++ b/cpukit/posix/src/nanosleep.c
@@ -23,17 +23,8 @@
#include <time.h>
-#include <rtems/score/threadimpl.h>
-#include <rtems/score/threadqimpl.h>
-#include <rtems/score/timespec.h>
-#include <rtems/score/timecounter.h>
-#include <rtems/score/watchdogimpl.h>
-#include <rtems/posix/posixapi.h>
#include <rtems/seterr.h>
-static Thread_queue_Control _Nanosleep_Pseudo_queue =
- THREAD_QUEUE_INITIALIZER( "Nanosleep" );
* 14.2.5 High Resolution Sleep, P1003.1b-1993, p. 269
@@ -52,85 +43,3 @@ int nanosleep(
return eno;
- * High Resolution Sleep with Specifiable Clock, IEEE Std 1003.1, 2001
-int clock_nanosleep(
- clockid_t clock_id,
- int flags,
- const struct timespec *rqtp,
- struct timespec *rmtp
- Thread_queue_Context queue_context;
- struct timespec uptime;
- const struct timespec *end;
- Thread_Control *executing;
- int eno;
- if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC ) {
- return ENOTSUP;
- _Thread_queue_Context_initialize( &queue_context );
- _Thread_queue_Context_set_thread_state(
- &queue_context,
- STATES_WAITING_FOR_TIME | STATES_INTERRUPTIBLE_BY_SIGNAL
- if ( ( flags & TIMER_ABSTIME ) != 0 ) {
- end = rqtp;
- if ( clock_id == CLOCK_REALTIME ) {
- _Thread_queue_Context_set_enqueue_timeout_realtime_timespec(
- &queue_context,
- end
- } else {
- _Thread_queue_Context_set_enqueue_timeout_monotonic_timespec(
- &queue_context,
- end
- } else {
- _Timecounter_Nanouptime( &uptime );
- end = _Watchdog_Future_timespec( &uptime, rqtp );
- &queue_context,
- end
- _Thread_queue_Acquire( &_Nanosleep_Pseudo_queue, &queue_context );
- executing = _Thread_Executing;
- _Thread_queue_Enqueue(
- &_Nanosleep_Pseudo_queue.Queue,
- &_Thread_queue_Operations_FIFO,
- executing,
- &queue_context
- eno = _POSIX_Get_error_after_wait( executing );
- if ( eno == ETIMEDOUT ) {
- eno = 0;
- if ( rmtp != NULL && ( flags & TIMER_ABSTIME ) == 0 ) {
- if ( eno == EINTR ) {
- struct timespec actual_end;
- _Timecounter_Nanouptime( &actual_end );
- if ( _Timespec_Less_than( &actual_end, end ) ) {
- _Timespec_Subtract( &actual_end, end, rmtp );
- } else {
- _Timespec_Set_to_zero( rmtp );
- } else {
- return eno;
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 682032182f..efd0d1bfe1 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -990,6 +990,7 @@ source:
- cpukit/posix/src/clockgetcpuclockid.c
- cpukit/posix/src/clockgetres.c
- cpukit/posix/src/clockgettime.c
+- cpukit/posix/src/clocknanosleep.c
- cpukit/posix/src/clocksettime.c
- cpukit/posix/src/condattrdestroy.c
- cpukit/posix/src/condattrgetclock.c
2.26.2
