[PATCH 1/2] posix: Move clock_nanosleep()
Joel Sherrill
joel at rtems.org
Mon May 17 15:22:10 UTC 2021
On Mon, May 17, 2021 at 10:19 AM Sebastian Huber <
> On 17/05/2021 17:05, Joel Sherrill wrote:
> > Why doesn't per item compilation and linking avoid this dependency?
> The problem is that most parts which are pulled in cannot be garbage
> collected by the linker due to the system initialization linker set.
Can you add that to the log message before you commit?
Are there other places where a system initialization item is combined
in a file with something it shouldn't be? How would one spot it?
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210517/e9b5e7ef/attachment-0001.html>
