[PATCH 2/2] posix: Use RTEMS_POSIX_API in clock_nanosleep()
Gedare Bloom
gedare at rtems.org
Mon May 17 16:36:58 UTC 2021
Out of curiosity, should we refine this feature check internally to
something specific to signals?
On Mon, May 17, 2021 at 9:06 AM Joel Sherrill <joel at rtems.org> wrote:
> Looks ok
> On Mon, May 17, 2021 at 10:01 AM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> It is only possible to get interrupted by a POSIX signal if
>> RTEMS_POSIX_API is defined.
>> cpukit/posix/src/clocknanosleep.c | 5 +++++
>> 1 file changed, 5 insertions(+)
>> diff --git a/cpukit/posix/src/clocknanosleep.c b/cpukit/posix/src/clocknanosleep.c
>> index 73b7d9c6a1..951268bc1f 100644
>> --- a/cpukit/posix/src/clocknanosleep.c
>> +++ b/cpukit/posix/src/clocknanosleep.c
>> @@ -97,6 +97,7 @@ int clock_nanosleep(
>> if ( rmtp != NULL && ( flags & TIMER_ABSTIME ) == 0 ) {
>> +#if defined( RTEMS_POSIX_API )
>> if ( eno == EINTR ) {
>> struct timespec actual_end;
>> @@ -110,6 +111,10 @@ int clock_nanosleep(
>> } else {
>> _Timespec_Set_to_zero( rmtp );
>> +#else
>> + _Assert( eno != EINTR );
>> + _Timespec_Set_to_zero( rmtp );
>> +#endif
>> return eno;
>> 2.26.2
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
