RFC: Separate Header for Some Porting Methods
Tue May 18 05:42:48 UTC 2021
On 18/05/2021 00:12, Joel Sherrill wrote:
> Hi
> In working on the Microblaze port, it occurred to me that the prototypes
> for the context switch methods are always the same. The structures vary,
> not the signatures. What do you all think of making a separate header
> that can be included from various cpu.h files to avoid repeating them?
Maybe we should add a <rtems/score/cpucontext.h> which just defines the
structures and corresponding defines, for example:
#define CPU_HARDWARE_FP                  TRUE
#define CPU_SOFTWARE_FP                  FALSE
We could add the prototypes to <rtems/score/context.h> and remove the
_Context namespace.
> Similarly, swap u32 and u16 are often the duplicated generic ones. A
> single header with those which ports can include if they use the generic
> implementation would also reduce some bulk.
Yes, this makes sense.
> My rough calculation is that a shared header for CPU Context method
> prototypes saves about 75 lines every time it is included which should
> eliminate somewhere between 1300 and 1500 lines in the ports.
> An alternative, slightly more aggressive,  approach be to prototype all
> the port required methods in one file and then let every port include
> that. It would eliminate even more. This would pick up _CPU_Initialize
> and a few others like _CPU_Thread_Idle. Just by honoring some of the
> existing conditionals.
> Thoughts?
We could also add a <rtems/score/cpuisrlevel.h> for the interrupt
enable/disable related support.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
