[PATCH 2/2] score: Simplify thread queue timeout handling
Peter Dufault
dufault at hda.com
Tue May 18 17:23:54 UTC 2021
Good fix.
> On May 18, 2021, at 09:04 , Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> Add Thread_queue_Context::timeout_absolute to specify an absolute or
> relative timeout. This avoid having to get the current time twice for
> timeouts relative to the current time. It moves also functionality to
> common code.
> cpukit/include/rtems/score/threadq.h | 9 +++++-
> cpukit/include/rtems/score/threadqimpl.h | 36 +++++++++++++++--------
> cpukit/include/rtems/score/watchdogimpl.h | 16 ++++++++++
> cpukit/posix/src/clocknanosleep.c | 33 +++++++++++++--------
> cpukit/posix/src/prwlocktimedrdlock.c | 3 +-
> cpukit/posix/src/prwlocktimedwrlock.c | 3 +-
> cpukit/posix/src/semtimedwait.c | 3 +-
> cpukit/posix/src/sigtimedwait.c | 8 ++---
> cpukit/score/src/mutex.c | 6 ++--
> cpukit/score/src/threadqtimeout.c | 10 +++++--
> 10 files changed, 88 insertions(+), 39 deletions(-)
> diff --git a/cpukit/include/rtems/score/threadq.h b/cpukit/include/rtems/score/threadq.h
> index 5234019b81..10476888d4 100644
> --- a/cpukit/include/rtems/score/threadq.h
> +++ b/cpukit/include/rtems/score/threadq.h
> @@ -214,7 +214,8 @@ struct Thread_queue_Context {
> * callout must be used to install the thread watchdog for timeout handling.
> * @see _Thread_queue_Enqueue_do_nothing_extra().
> - * _Thread_queue_Add_timeout_ticks(), and
> + * _Thread_queue_Add_timeout_ticks(),
> + * _Thread_queue_Add_timeout_monotonic_timespec(), and
> * _Thread_queue_Add_timeout_realtime_timespec().
> Thread_queue_Enqueue_callout enqueue_callout;
> @@ -236,6 +237,12 @@ struct Thread_queue_Context {
> const void *arg;
> } Timeout;
> + * @brief If this member is true, the timeout shall be absolute, otherwise it
> + * shall be relative to the current time of the clock.
> + bool timeout_absolute;
> #if defined(RTEMS_SMP)
> * @brief Representation of a thread queue path from a start thread queue to
> diff --git a/cpukit/include/rtems/score/threadqimpl.h b/cpukit/include/rtems/score/threadqimpl.h
> index ca59de9e31..7b00de009d 100644
> --- a/cpukit/include/rtems/score/threadqimpl.h
> +++ b/cpukit/include/rtems/score/threadqimpl.h
> @@ -267,41 +267,53 @@ _Thread_queue_Context_set_enqueue_timeout_ticks(
> - * @brief Sets the enqueue callout to add an absolute monotonic timeout in
> - * timespec format.
> + * @brief Sets the enqueue callout to add a timeout in timespec format using
> + * CLOCK_MONOTONIC.
> - * @param[out] queue_context The thread queue context.
> - * @param abstime The absolute monotonic timeout.
> + * @param[out] queue_context is the thread queue context.
> + * @param timeout is the absolute or relative timeout.
> + * @param absolute is true, if the timeout shall be absolute, otherwise it
> * @see _Thread_queue_Enqueue().
> RTEMS_INLINE_ROUTINE void
> _Thread_queue_Context_set_enqueue_timeout_monotonic_timespec(
> Thread_queue_Context *queue_context,
> - const struct timespec *abstime
> + const struct timespec *timeout,
> + bool absolute
> - queue_context->Timeout.arg = abstime;
> + queue_context->Timeout.arg = timeout;
> + queue_context->timeout_absolute = absolute;
> queue_context->enqueue_callout =
> _Thread_queue_Add_timeout_monotonic_timespec;
> - * @brief Sets the enqueue callout to add an absolute realtime timeout in
> + * CLOCK_REALTIME.
> - * @param abstime The absolute realtime timeout.
> _Thread_queue_Context_set_enqueue_timeout_realtime_timespec(
> + bool absolute
> queue_context->enqueue_callout = _Thread_queue_Add_timeout_realtime_timespec;
> diff --git a/cpukit/include/rtems/score/watchdogimpl.h b/cpukit/include/rtems/score/watchdogimpl.h
> index a8e6de4fbe..d29a856218 100644
> --- a/cpukit/include/rtems/score/watchdogimpl.h
> +++ b/cpukit/include/rtems/score/watchdogimpl.h
> @@ -534,6 +534,22 @@ RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_timespec(
> return ticks;
> + * @brief Converts the ticks to timespec.
> + * @param ticks are the ticks to convert.
> + * @param[out] ts is the timespec to return the converted ticks.
> +RTEMS_INLINE_ROUTINE void _Watchdog_Ticks_to_timespec(
> + uint64_t ticks,
> + struct timespec *ts
> + ts->tv_sec = ticks >> WATCHDOG_BITS_FOR_1E9_NANOSECONDS;
> + ts->tv_nsec = ticks & ( WATCHDOG_BITS_FOR_1E9_NANOSECONDS - 1 );
> * @brief Converts the sbintime in ticks.
> diff --git a/cpukit/posix/src/clocknanosleep.c b/cpukit/posix/src/clocknanosleep.c
> index eb7f231e86..bfb78466df 100644
> --- a/cpukit/posix/src/clocknanosleep.c
> +++ b/cpukit/posix/src/clocknanosleep.c
> @@ -43,11 +43,10 @@ int clock_nanosleep(
> struct timespec *rmtp
> - Thread_queue_Context queue_context;
> - struct timespec uptime;
> - const struct timespec *end;
> - Thread_Control *executing;
> - int eno;
> + Thread_queue_Context queue_context;
> + bool absolute;
> + Thread_Control *executing;
> + int eno;
> if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC ) {
> return ENOTSUP;
> @@ -60,21 +59,23 @@ int clock_nanosleep(
> if ( ( flags & TIMER_ABSTIME ) != 0 ) {
> - end = rqtp;
> + absolute = true;
> + rmtp = NULL;
> } else {
> - _Timecounter_Nanouptime( &uptime );
> - end = _Watchdog_Future_timespec( &uptime, rqtp );
> + absolute = false;
> if ( clock_id == CLOCK_REALTIME ) {
> &queue_context,
> - end
> + rqtp,
> + absolute
> } else {
> &queue_context,
> - end
> + rqtp,
> + absolute
> @@ -92,10 +93,11 @@ int clock_nanosleep(
> eno = 0;
> - if ( rmtp != NULL && ( flags & TIMER_ABSTIME ) == 0 ) {
> + if ( rmtp != NULL ) {
> #if defined( RTEMS_POSIX_API )
> if ( eno == EINTR ) {
> struct timespec actual_end;
> + struct timespec planned_end;
> _Timecounter_Nanotime( &actual_end );
> @@ -103,8 +105,13 @@ int clock_nanosleep(
> _Timecounter_Nanouptime( &actual_end );
> - if ( _Timespec_Less_than( &actual_end, end ) ) {
> - _Timespec_Subtract( &actual_end, end, rmtp );
> + _Watchdog_Ticks_to_timespec(
> + executing->Timer.Watchdog.expire,
> + &planned_end
> + if ( _Timespec_Less_than( &actual_end, &planned_end ) ) {
> + _Timespec_Subtract( &actual_end, &planned_end, rmtp );
> } else {
> _Timespec_Set_to_zero( rmtp );
> diff --git a/cpukit/posix/src/prwlocktimedrdlock.c b/cpukit/posix/src/prwlocktimedrdlock.c
> index 79059800bf..809f355359 100644
> --- a/cpukit/posix/src/prwlocktimedrdlock.c
> +++ b/cpukit/posix/src/prwlocktimedrdlock.c
> @@ -37,7 +37,8 @@ int pthread_rwlock_timedrdlock(
> _Thread_queue_Context_initialize( &queue_context );
> &queue_context,
> - abstime
> + abstime,
> + true
> status = _CORE_RWLock_Seize_for_reading(
> &the_rwlock->RWLock,
> diff --git a/cpukit/posix/src/prwlocktimedwrlock.c b/cpukit/posix/src/prwlocktimedwrlock.c
> index 9fb9a880a0..614d230ba9 100644
> --- a/cpukit/posix/src/prwlocktimedwrlock.c
> +++ b/cpukit/posix/src/prwlocktimedwrlock.c
> @@ -39,7 +39,8 @@ int pthread_rwlock_timedwrlock(
> &queue_context,
> - abstime
> + abstime,
> + true
> status = _CORE_RWLock_Seize_for_writing(
> diff --git a/cpukit/posix/src/semtimedwait.c b/cpukit/posix/src/semtimedwait.c
> index 21a8320b50..ae83e90540 100644
> --- a/cpukit/posix/src/semtimedwait.c
> +++ b/cpukit/posix/src/semtimedwait.c
> @@ -60,7 +60,8 @@ int sem_timedwait(
> &queue_context,
> - abstime
> + abstime,
> + true
> _Thread_queue_Context_set_ISR_level( &queue_context, level );
> diff --git a/cpukit/posix/src/sigtimedwait.c b/cpukit/posix/src/sigtimedwait.c
> index 4e2b6c2658..0bdb65fd45 100644
> --- a/cpukit/posix/src/sigtimedwait.c
> +++ b/cpukit/posix/src/sigtimedwait.c
> @@ -76,7 +76,6 @@ int sigtimedwait(
> siginfo_t signal_information;
> siginfo_t *the_info;
> int signo;
> int error;
> @@ -93,13 +92,10 @@ int sigtimedwait(
> if ( timeout != NULL ) {
> - end = _Watchdog_Future_timespec( &uptime, timeout );
> &queue_context,
> - end
> + timeout,
> + false
> } else {
> _Thread_queue_Context_set_enqueue_do_nothing_extra( &queue_context );
> diff --git a/cpukit/score/src/mutex.c b/cpukit/score/src/mutex.c
> index 88a390f323..f7e35093b2 100644
> --- a/cpukit/score/src/mutex.c
> +++ b/cpukit/score/src/mutex.c
> @@ -206,7 +206,8 @@ int _Mutex_Acquire_timed(
> } else {
> &queue_context,
> - abstime
> + abstime,
> + true
> _Mutex_Acquire_slow( mutex, owner, executing, level, &queue_context );
> @@ -327,7 +328,8 @@ int _Mutex_recursive_Acquire_timed(
> } else {
> &queue_context,
> - abstime
> + abstime,
> + true
> _Mutex_Acquire_slow( &mutex->Mutex, owner, executing, level, &queue_context );
> diff --git a/cpukit/score/src/threadqtimeout.c b/cpukit/score/src/threadqtimeout.c
> index ec8f67c93b..a3aeea43be 100644
> --- a/cpukit/score/src/threadqtimeout.c
> +++ b/cpukit/score/src/threadqtimeout.c
> @@ -10,7 +10,7 @@
> - * Copyright (c) 2016, 2017 embedded brains GmbH
> + * Copyright (c) 2016, 2021 embedded brains GmbH
> * The license and distribution terms for this file may be
> * found in the file LICENSE in this distribution or at
> @@ -55,8 +55,14 @@ static void _Thread_queue_Add_timeout_timespec(
> const struct timespec *abstime;
> + struct timespec base;
> - abstime = queue_context->Timeout.arg;
> + if ( queue_context->timeout_absolute ) {
> + abstime = queue_context->Timeout.arg;
> + } else {
> + base = *now;
> + abstime = _Watchdog_Future_timespec( &base, queue_context->Timeout.arg );
> if ( _Watchdog_Is_valid_timespec( abstime ) ) {
> uint64_t expire;
> 2.26.2
> devel mailing list
> devel at rtems.org
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210518/460a281a/attachment-0001.bin>
