[PATCH v2 2/2] score: Simplify thread queue timeout handling
Tue May 18 18:06:28 UTC 2021
v2 set looks good to me
On Tue, May 18, 2021 at 10:49 AM Sebastian Huber
> Add Thread_queue_Context::timeout_absolute to specify an absolute or
> relative timeout.  This avoid having to get the current time twice for
> timeouts relative to the current time.  It moves also functionality to
> common code.
>  cpukit/include/rtems/score/threadq.h      |  9 +++++-
>  cpukit/include/rtems/score/threadqimpl.h  | 36 ++++++++++++++-------
>  cpukit/include/rtems/score/watchdogimpl.h | 16 ++++++++++
>  cpukit/posix/src/clocknanosleep.c         | 38 ++++++++++++-----------
>  cpukit/posix/src/prwlocktimedrdlock.c     |  3 +-
>  cpukit/posix/src/prwlocktimedwrlock.c     |  3 +-
>  cpukit/posix/src/semtimedwait.c           |  3 +-
>  cpukit/posix/src/sigtimedwait.c           |  8 ++---
>  cpukit/score/src/mutex.c                  |  6 ++--
>  cpukit/score/src/threadqtimeout.c         | 10 ++++--
>  10 files changed, 88 insertions(+), 44 deletions(-)
> diff --git a/cpukit/include/rtems/score/threadq.h b/cpukit/include/rtems/score/threadq.h
> index 5234019b81..10476888d4 100644
> --- a/cpukit/include/rtems/score/threadq.h
> +++ b/cpukit/include/rtems/score/threadq.h
> @@ -214,7 +214,8 @@ struct Thread_queue_Context {
>     * callout must be used to install the thread watchdog for timeout handling.
>     * @see _Thread_queue_Enqueue_do_nothing_extra().
> -   *   _Thread_queue_Add_timeout_ticks(), and
> +   *   _Thread_queue_Add_timeout_ticks(),
> +   *   _Thread_queue_Add_timeout_monotonic_timespec(), and
>     *   _Thread_queue_Add_timeout_realtime_timespec().
>    Thread_queue_Enqueue_callout enqueue_callout;
> @@ -236,6 +237,12 @@ struct Thread_queue_Context {
>      const void *arg;
>    } Timeout;
> +   * @brief If this member is true, the timeout shall be absolute, otherwise it
> +   *   shall be relative to the current time of the clock.
> +  bool timeout_absolute;
>  #if defined(RTEMS_SMP)
>     * @brief Representation of a thread queue path from a start thread queue to
> diff --git a/cpukit/include/rtems/score/threadqimpl.h b/cpukit/include/rtems/score/threadqimpl.h
> index ca59de9e31..7b00de009d 100644
> --- a/cpukit/include/rtems/score/threadqimpl.h
> +++ b/cpukit/include/rtems/score/threadqimpl.h
> @@ -267,41 +267,53 @@ _Thread_queue_Context_set_enqueue_timeout_ticks(
> - * @brief Sets the enqueue callout to add an absolute monotonic timeout in
> - * timespec format.
> + * @brief Sets the enqueue callout to add a timeout in timespec format using
> + *   CLOCK_MONOTONIC.
> - * @param[out] queue_context The thread queue context.
> - * @param abstime The absolute monotonic timeout.
> + * @param[out] queue_context is the thread queue context.
> + * @param timeout is the absolute or relative timeout.
> + * @param absolute is true, if the timeout shall be absolute, otherwise it
>   * @see _Thread_queue_Enqueue().
>  RTEMS_INLINE_ROUTINE void
>  _Thread_queue_Context_set_enqueue_timeout_monotonic_timespec(
>    Thread_queue_Context  *queue_context,
> -  const struct timespec *abstime
> +  const struct timespec *timeout,
> +  bool                   absolute
> -  queue_context->Timeout.arg = abstime;
> +  queue_context->Timeout.arg = timeout;
> +  queue_context->timeout_absolute = absolute;
>    queue_context->enqueue_callout =
>      _Thread_queue_Add_timeout_monotonic_timespec;
> - * @brief Sets the enqueue callout to add an absolute realtime timeout in
> + *   CLOCK_REALTIME.
> - * @param abstime The absolute realtime timeout.
>  _Thread_queue_Context_set_enqueue_timeout_realtime_timespec(
> +  bool                   absolute
>    queue_context->enqueue_callout = _Thread_queue_Add_timeout_realtime_timespec;
> diff --git a/cpukit/include/rtems/score/watchdogimpl.h b/cpukit/include/rtems/score/watchdogimpl.h
> index a8e6de4fbe..7b364b8828 100644
> --- a/cpukit/include/rtems/score/watchdogimpl.h
> +++ b/cpukit/include/rtems/score/watchdogimpl.h
> @@ -534,6 +534,22 @@ RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_timespec(
>    return ticks;
> + * @brief Converts the ticks to timespec.
> + * @param ticks are the ticks to convert.
> + * @param[out] ts is the timespec to return the converted ticks.
> +RTEMS_INLINE_ROUTINE void _Watchdog_Ticks_to_timespec(
> +  uint64_t         ticks,
> +  struct timespec *ts
> +  ts->tv_sec = ticks >> WATCHDOG_BITS_FOR_1E9_NANOSECONDS;
> +  ts->tv_nsec = ticks & ( ( 1U << WATCHDOG_BITS_FOR_1E9_NANOSECONDS ) - 1 );
>   * @brief Converts the sbintime in ticks.
> diff --git a/cpukit/posix/src/clocknanosleep.c b/cpukit/posix/src/clocknanosleep.c
> index 588f67a60a..bfb78466df 100644
> --- a/cpukit/posix/src/clocknanosleep.c
> +++ b/cpukit/posix/src/clocknanosleep.c
> @@ -43,11 +43,10 @@ int clock_nanosleep(
>    struct timespec        *rmtp
> -  Thread_queue_Context   queue_context;
> -  struct timespec        now;
> -  const struct timespec *end;
> -  Thread_Control        *executing;
> -  int                    eno;
> +  Thread_queue_Context queue_context;
> +  bool                 absolute;
> +  Thread_Control      *executing;
> +  int                  eno;
>    if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC ) {
>      return ENOTSUP;
> @@ -60,26 +59,23 @@ int clock_nanosleep(
>    if ( ( flags & TIMER_ABSTIME ) != 0 ) {
> -    end = rqtp;
> +    absolute = true;
> +    rmtp = NULL;
>    } else {
> -    if ( clock_id == CLOCK_REALTIME ) {
> -      _Timecounter_Nanotime( &now );
> -    } else {
> -      _Timecounter_Nanouptime( &now );
> -    end = _Watchdog_Future_timespec( &now, rqtp );
> +    absolute = false;
>        &queue_context,
> -      end
> +      rqtp,
> +      absolute
>    } else {
>        &queue_context,
> -      end
> +      rqtp,
> +      absolute
> @@ -97,10 +93,11 @@ int clock_nanosleep(
>      eno = 0;
> -  if ( rmtp != NULL && ( flags & TIMER_ABSTIME ) == 0 ) {
> +  if ( rmtp != NULL ) {
>  #if defined( RTEMS_POSIX_API )
>      if ( eno == EINTR ) {
>        struct timespec actual_end;
> +      struct timespec planned_end;
>          _Timecounter_Nanotime( &actual_end );
> @@ -108,8 +105,13 @@ int clock_nanosleep(
>          _Timecounter_Nanouptime( &actual_end );
> -      if ( _Timespec_Less_than( &actual_end, end ) ) {
> -        _Timespec_Subtract( &actual_end, end, rmtp );
> +      _Watchdog_Ticks_to_timespec(
> +        executing->Timer.Watchdog.expire,
> +        &planned_end
> +      if ( _Timespec_Less_than( &actual_end, &planned_end ) ) {
> +        _Timespec_Subtract( &actual_end, &planned_end, rmtp );
>        } else {
>          _Timespec_Set_to_zero( rmtp );
> diff --git a/cpukit/posix/src/prwlocktimedrdlock.c b/cpukit/posix/src/prwlocktimedrdlock.c
> index 79059800bf..809f355359 100644
> --- a/cpukit/posix/src/prwlocktimedrdlock.c
> +++ b/cpukit/posix/src/prwlocktimedrdlock.c
> @@ -37,7 +37,8 @@ int pthread_rwlock_timedrdlock(
>    _Thread_queue_Context_initialize( &queue_context );
>      &queue_context,
> -    abstime
> +    abstime,
> +    true
>    status = _CORE_RWLock_Seize_for_reading(
>      &the_rwlock->RWLock,
> diff --git a/cpukit/posix/src/prwlocktimedwrlock.c b/cpukit/posix/src/prwlocktimedwrlock.c
> index 9fb9a880a0..614d230ba9 100644
> --- a/cpukit/posix/src/prwlocktimedwrlock.c
> +++ b/cpukit/posix/src/prwlocktimedwrlock.c
> @@ -39,7 +39,8 @@ int pthread_rwlock_timedwrlock(
>      &queue_context,
> -    abstime
> +    abstime,
> +    true
>    status = _CORE_RWLock_Seize_for_writing(
> diff --git a/cpukit/posix/src/semtimedwait.c b/cpukit/posix/src/semtimedwait.c
> index 21a8320b50..ae83e90540 100644
> --- a/cpukit/posix/src/semtimedwait.c
> +++ b/cpukit/posix/src/semtimedwait.c
> @@ -60,7 +60,8 @@ int sem_timedwait(
>        &queue_context,
> -      abstime
> +      abstime,
> +      true
>      _Thread_queue_Context_set_ISR_level( &queue_context, level );
> diff --git a/cpukit/posix/src/sigtimedwait.c b/cpukit/posix/src/sigtimedwait.c
> index 4e2b6c2658..0bdb65fd45 100644
> --- a/cpukit/posix/src/sigtimedwait.c
> +++ b/cpukit/posix/src/sigtimedwait.c
> @@ -76,7 +76,6 @@ int sigtimedwait(
>    siginfo_t             signal_information;
>    siginfo_t            *the_info;
>    int                   signo;
> -  struct timespec       uptime;
>    int                   error;
> @@ -93,13 +92,10 @@ int sigtimedwait(
>    if ( timeout != NULL ) {
> -    _Timecounter_Nanouptime( &uptime );
> -    end = _Watchdog_Future_timespec( &uptime, timeout );
>        &queue_context,
> -      end
> +      timeout,
> +      false
>    } else {
>      _Thread_queue_Context_set_enqueue_do_nothing_extra( &queue_context );
> diff --git a/cpukit/score/src/mutex.c b/cpukit/score/src/mutex.c
> index 88a390f323..f7e35093b2 100644
> --- a/cpukit/score/src/mutex.c
> +++ b/cpukit/score/src/mutex.c
> @@ -206,7 +206,8 @@ int _Mutex_Acquire_timed(
>    } else {
>        &queue_context,
> -      abstime
> +      abstime,
> +      true
>      _Mutex_Acquire_slow( mutex, owner, executing, level, &queue_context );
> @@ -327,7 +328,8 @@ int _Mutex_recursive_Acquire_timed(
>    } else {
>        &queue_context,
> -      abstime
> +      abstime,
> +      true
>      _Mutex_Acquire_slow( &mutex->Mutex, owner, executing, level, &queue_context );
> diff --git a/cpukit/score/src/threadqtimeout.c b/cpukit/score/src/threadqtimeout.c
> index ec8f67c93b..a3aeea43be 100644
> --- a/cpukit/score/src/threadqtimeout.c
> +++ b/cpukit/score/src/threadqtimeout.c
> @@ -10,7 +10,7 @@
> - * Copyright (c) 2016, 2017 embedded brains GmbH
> + * Copyright (c) 2016, 2021 embedded brains GmbH
>   * The license and distribution terms for this file may be
>   * found in the file LICENSE in this distribution or at
> @@ -55,8 +55,14 @@ static void _Thread_queue_Add_timeout_timespec(
>    const struct timespec *abstime;
> +  struct timespec        base;
> -  abstime = queue_context->Timeout.arg;
> +  if ( queue_context->timeout_absolute ) {
> +    abstime = queue_context->Timeout.arg;
> +  } else {
> +    base = *now;
> +    abstime = _Watchdog_Future_timespec( &base, queue_context->Timeout.arg );
>    if ( _Watchdog_Is_valid_timespec( abstime ) ) {
>      uint64_t expire;
> 2.26.2
> devel mailing list
> devel at rtems.org
