[PATCH v6 3/5] libcsupport: Implement utimes() in terms of utimensat()
Ryan Long
ryan.long at oarcorp.com
Tue May 18 20:03:28 UTC 2021
utimes() now calls utimensat() to update file access
and modification timestamps.
Updated license.
Closes #4398
cpukit/libcsupport/src/utimes.c | 63 ++++++++++++++++++++++++++++++++---------
1 file changed, 49 insertions(+), 14 deletions(-)
diff --git a/cpukit/libcsupport/src/utimes.c b/cpukit/libcsupport/src/utimes.c
index 3dc47c0..9748abb 100644
--- a/cpukit/libcsupport/src/utimes.c
+++ b/cpukit/libcsupport/src/utimes.c
@@ -1,38 +1,73 @@
* @file
- * @brief Change File Last Access and Modification Times
* @ingroup libcsupport
+ * @brief Set file access and modification times in milliseconds.
- * Written by: Vinu Rajashekhar <vinutheraj at gmail.com>
+ * COPYRIGHT (C) 1989, 2021 On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
-#include <sys/types.h>
-#include <utime.h>
#include <sys/time.h>
+#include <rtems/score/todimpl.h>
+#include <fcntl.h>
+ * https://pubs.opengroup.org/onlinepubs/9699919799.2008edition/functions/futimens.html
+ * Set file access and modification times
int utimes(
const char *path,
const struct timeval times[2]
- struct utimbuf timeinsecs;
+ struct timespec new_times[2];
- if ( times == NULL )
- return utime( path, NULL );
+ if ( times == NULL ) {
+ return utimensat( AT_FDCWD, path, NULL , 0 );
- timeinsecs.actime = times[0].tv_sec;
- timeinsecs.modtime = times[1].tv_sec;
+ _Timespec_Set(
+ &new_times[0],
+ times[0].tv_sec,
+ times[0].tv_usec * TOD_NANOSECONDS_PER_MICROSECOND
+ _Timespec_Set(
+ &new_times[1],
+ times[1].tv_sec,
+ times[1].tv_usec * TOD_NANOSECONDS_PER_MICROSECOND
- return utime( path, &timeinsecs );
+ return utimensat( AT_FDCWD, path, new_times, 0 );
1.8.3.1
