[PATCH v3] score/aarch64: Align context validation frame
Kinsey Moore
kinsey.moore at oarcorp.com
Tue May 18 20:18:07 UTC 2021
Looks like this fell through the cracks last month and I totally forgot about it.
-----Original Message-----
Sent: Tuesday, April 13, 2021 10:15
To: devel at rtems.org
Cc: Kinsey Moore <kinsey.moore at oarcorp.com>
Subject: [PATCH v3] score/aarch64: Align context validation frame
Ensure the stack remains aligned by keeping the context frame at a
multiple of 16 bytes. This avoids stack alignment exceptions which occur
when the stack pointer is not 16 byte aligned.
.../cpu/aarch64/aarch64-context-validate.S | 29 ++++++++++++-------
1 file changed, 18 insertions(+), 11 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/aarch64-context-validate.S b/cpukit/score/cpu/aarch64/aarch64-context-validate.S
index 57f634934b..1e71bc5b3a 100644
--- a/cpukit/score/cpu/aarch64/aarch64-context-validate.S
+++ b/cpukit/score/cpu/aarch64/aarch64-context-validate.S
@@ -42,7 +42,9 @@
#include <rtems/asm.h>
#include <rtems/score/cpu.h>
+#include <rtems/score/basedefs.h>
+/* These must be 8 byte aligned to avoid misaligned accesses */
#define FRAME_OFFSET_X4 0x00
#define FRAME_OFFSET_X5 0x08
#define FRAME_OFFSET_X6 0x10
@@ -54,18 +56,23 @@
#define FRAME_OFFSET_LR 0x40
#ifdef AARCH64_MULTILIB_VFP
- #define FRAME_OFFSET_V8 0x48
- #define FRAME_OFFSET_V9 0x58
- #define FRAME_OFFSET_V10 0x68
- #define FRAME_OFFSET_V11 0x78
- #define FRAME_OFFSET_V12 0x88
- #define FRAME_OFFSET_V13 0x98
- #define FRAME_OFFSET_V14 0xA8
- #define FRAME_OFFSET_V15 0xB8
- #define FRAME_SIZE (FRAME_OFFSET_V15 + 0x10)
+ /* These must be 16 byte aligned to avoid misaligned accesses */
+ #define FRAME_OFFSET_V8 0x50
+ #define FRAME_OFFSET_V9 0x60
+ #define FRAME_OFFSET_V10 0x70
+ #define FRAME_OFFSET_V11 0x80
+ #define FRAME_OFFSET_V12 0x90
+ #define FRAME_OFFSET_V13 0xA0
+ #define FRAME_OFFSET_V14 0xB0
+ #define FRAME_OFFSET_V15 0xC0
+ * Force 16 byte alignment of the frame size to avoid stack pointer alignment
+ * exceptions.
+ #define FRAME_SIZE RTEMS_ALIGN_UP( FRAME_OFFSET_V15, 16 )
#else
- #define FRAME_SIZE (FRAME_OFFSET_LR + 0x08)
+ #define FRAME_SIZE RTEMS_ALIGN_UP( FRAME_OFFSET_LR, 16 )
#endif
.section .text
2.20.1
