[PATCH v6 4/5] psx13: Added tests for utimensat() and futimens()
Gedare Bloom
gedare at rtems.org
Tue May 18 20:36:40 UTC 2021
On Tue, May 18, 2021 at 2:21 PM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, May 18, 2021 at 3:03 PM Ryan Long <ryan.long at oarcorp.com> wrote:
>> Improved tests for utime() and utimes() and update license.
>> Close #4399
>> testsuites/psxtests/psx13/main.c | 5 +-
>> testsuites/psxtests/psx13/test.c | 499 +++++++++++++++++++++++++++++++++++++--
>> 2 files changed, 481 insertions(+), 23 deletions(-)
>> diff --git a/testsuites/psxtests/psx13/main.c b/testsuites/psxtests/psx13/main.c
>> index f9e7907..7a560f9 100644
>> --- a/testsuites/psxtests/psx13/main.c
>> +++ b/testsuites/psxtests/psx13/main.c
>> @@ -1,5 +1,3 @@
>> -/* SPDX-License-Identifier: BSD-2-Clause */
> Agree with Gedare. This shouldn't have been removed.
> There were some dates changed in the copyrights.
> Check all of the issues against all of the patches.
>> * @file
>> @@ -8,8 +6,7 @@
>> - * COPYRIGHT (c) 1989-2009, 2021.
>> - * On-Line Applications Research Corporation (OAR).
>> + * COPYRIGHT (C) 1989, 2021 On-Line Applications Research Corporation (OAR).
> This changes the years which is wrong.
Actually, we only document the first and last year now.
>> * Redistribution and use in source and binary forms, with or without
>> * modification, are permitted provided that the following conditions
>> diff --git a/testsuites/psxtests/psx13/test.c b/testsuites/psxtests/psx13/test.c
>> index e98b03a..0754dbc 100644
>> --- a/testsuites/psxtests/psx13/test.c
>> +++ b/testsuites/psxtests/psx13/test.c
>> @@ -1,4 +1,4 @@
>> +/* SPDX-License-Identifier: BSD-2-Clause */
>> * @file
>> @@ -17,12 +17,13 @@
>> * - umask()
>> * - utime()
>> * - utimes()
>> + * - utimensat()
>> + * - futimens()
>> * - sync()
> Again a year change.
>> @@ -52,6 +53,8 @@
>> #include <rtems.h>
>> #include <rtems/libio.h>
>> +#include <rtems/score/timespec.h>
>> +#include <rtems/score/todimpl.h>
>> #include <sys/time.h>
>> #include <fcntl.h>
>> #include <unistd.h>
>> @@ -210,8 +213,7 @@ static void Dup2Test( void )
>> - * @brief Exercises fdatasync(). Does NOT test the functionality of the
>> - * underlying fdatasync entry in the IMFS op table.
>> + * @brief Exercises fdatasync().
>> static void FDataSyncTest( void )
>> @@ -259,60 +261,517 @@ static void UMaskTest( void )
>> - * @brief Exercises utime(). Does not test the functionality of the
>> - * underlying utime entry in the IMFS op table.
>> + * @brief Exercises utime().
>> static void UTimeTest( void )
>> int rv;
>> struct utimbuf time;
>> + struct timespec current_time;
>> struct stat fstat;
>> - /* First, an invalid filename. */
>> + /* ENOENT test case */
>> + /* Case: Pass an invalid filename. */
>> rv = utime( "!This is an =invalid p at thname!!! :)", NULL );
>> rtems_test_assert( rv == -1 );
>> rtems_test_assert( errno == ENOENT );
>> - /* Now, the success test. */
>> + /* EACCES test case */
>> + /* Case: Change user ID to someone besides root */
>> + rv = seteuid( 1 );
>> + rtems_test_assert( rv == 0 );
>> + rv = utime( "testfile1.tst", NULL );
>> + rtems_test_assert( rv == -1 );
>> + rtems_test_assert( errno == EACCES );
>> + rv = seteuid( 0 );
>> + /* EINVAL test cases */
>> + /* Case: Invalid access time */
>> + time.actime = -1;
>> + time.modtime = 54321;
>> + rv = utime( "testfile1.tst", &time );
>> + rtems_test_assert( errno == EINVAL );
>> + /* Case: Invalid modified time */
>> + time.actime = 12345;
>> + time.modtime = -1;
>> + /* Successful test cases */
>> + /* Case: Test without times argument */
>> + clock_gettime( CLOCK_REALTIME, ¤t_time );
>> + rv = stat( "testfile1.tst", &fstat );
>> + rtems_test_assert( current_time.tv_sec <= fstat.st_atim.tv_sec );
>> + rtems_test_assert( current_time.tv_sec <= fstat.st_mtim.tv_sec );
>> + /* Case: time is filled with valid values */
>> - /* But, did it set the time? */
>> + /* Check that it actually changed the time */
>> rtems_test_assert( fstat.st_atime == 12345 );
>> rtems_test_assert( fstat.st_mtime == 54321 );
>> - rv = utime( "testfile1.tst", NULL );
>> - rtems_test_assert( rv == 0 );
>> - * @brief Exercises utimes(). Does NOT test the functionality of the
>> + * @brief Exercises utimes().
>> static void UTimesTest( void )
>> int rv;
>> struct timeval time[2];
>> struct stat fstat;
>> + /* Case: First, an invalid filename. */
>> rv = utimes( "!This is an =invalid p at thname!!! : )", NULL);
>> + /* Change the user ID of the process to someone besides root */
>> + rv = utimes( "testfile1.tst", NULL );
>> + /* Case: Negative access time tv_sec value */
>> + time[0].tv_sec = -1;
>> + time[0].tv_usec = 12345;
>> + time[1].tv_sec = 54321;
>> + time[1].tv_usec = 54321;
>> + rv = utimes( "testfile1.tst", time );
>> + /* Case: Negative modified time second value */
>> time[0].tv_sec = 12345;
>> + time[1].tv_sec = -1;
>> + /* Case: Negative access time microsecond value */
>> + time[0].tv_usec = -1;
>> + /* Case: Negative modified time microsecond value */
>> + time[1].tv_usec = -1;
>> + /* Case: Access time microsecond value too large */
>> + time[0].tv_usec = 1000000;
>> + /* Case: Modified time microsecond value too large */
>> + time[1].tv_usec = 1000000;
>> + time[0].tv_sec = 12345;
>> + rtems_test_assert( fstat.st_atime == 12345 );
>> + rtems_test_assert( fstat.st_mtime == 54321 );
>> + * @brief Exercises utimensat().
>> +static void UTimensatTest( void )
>> + int rv;
>> + struct timespec time[2];
>> + struct stat fstat;
>> + /* ENOSYS test cases */
>> + /* Case: Pass an unsupported file descriptor */
>> + rv = utimensat(
>> + 0,
>> + "!This is an =invalid p at thname!!! : )",
>> + NULL,
>> + 0
>> + rtems_test_assert( errno == ENOSYS );
>> + /* Case: Pass unsupported flag */
>> + rv = utimensat(
>> + AT_FDCWD,
>> + NULL,
>> + 1
>> + /* Use an invalid filename. */
>> + rv = utimensat(
>> + AT_FDCWD,
>> + NULL,
>> + 0
>> + rtems_test_assert( errno == ENOENT );
>> + /* EACCES test Cases */
>> + /* Case: When times is NULL and the user has insufficient privileges */
>> + rv = utimensat( AT_FDCWD, "testfile1.tst", NULL, 0 );
>> + /* Case: File is read-only and time's tv_nsec members are UTIME_NOW */
>> + /* Change file to be read-only */
>> + rv = chmod( "testfile1.tst", 06444 );
>> + _Timespec_Set( &time[0], 0, UTIME_NOW );
>> + _Timespec_Set( &time[1], 0, UTIME_NOW );
>> + rv = utimensat( AT_FDCWD, "testfile1.tst", time, 0 );
>> + rv = chmod( "testfile1.tst", fstat.st_mode );
>> + /* Case: Negative access time second value */
>> + _Timespec_Set( &time[0], -12345, 12345 );
>> + _Timespec_Set( &time[1], 54321, 54321 );
>> + _Timespec_Set( &time[0], 12345, 12345 );
>> + _Timespec_Set( &time[1], -54321, 54321 );
>> + /* Case: Negative access time nanosecond value */
>> + _Timespec_Set( &time[0], 12345, -12345 );
>> + /* Case: Negative modified time nanosecond value */
>> + _Timespec_Set( &time[1], 54321, -54321 );
>> + /* Case: Access time nanosecond value too large */
>> + _Timespec_Set( &time[0], 12345, TOD_NANOSECONDS_PER_SECOND );
>> + /* Case: Modified time nanosecond value too large */
>> + _Timespec_Set( &time[1], 54321, TOD_NANOSECONDS_PER_SECOND );
>> + /* Case: Running with access time nanosecond field equal to UTIME_NOW */
>> + _Timespec_Set( &time[0], 12345, UTIME_NOW );
>> + /* Case: Running with modified time nanosecond field equal to UTIME_NOW */
>> + _Timespec_Set( &time[1], 54321, UTIME_NOW );
>> + /* Case: Normal run */
>> + * @brief Exercises futimens().
>> +static void FutimensTest( void )
>> + int rv;
>> + int fd;
>> + /* EBADF test case */
>> + /* Case: Pass an invalid file descriptor */
>> + rv = futimens( -1, time );
>> + rtems_test_assert( errno == EBADF );
>> + fd = open( "testfile1.tst", O_RDWR );
>> + rtems_test_assert( fd != -1 );
>> + /* EACCES test cases */
>> + rv = futimens( fd, NULL );
>> + rv = futimens( fd, time );
>> +/* Case: Running with access time nanosecond field equal to UTIME_NOW */
>> - rv = utimes( "testfile1.tst", (struct timeval *)&time );
>> @@ -443,6 +902,8 @@ int test_main( void )
>> UMaskTest();
>> UTimeTest();
>> UTimesTest();
>> + UTimensatTest();
>> + FutimensTest();
>> FSyncTest();
>> PathConfTest();
>> FPathConfTest();
>> 1.8.3.1
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
