[PATCH v6 4/5] psx13: Added tests for utimensat() and futimens()
Ryan Long
ryan.long at oarcorp.com
Tue May 18 23:54:38 UTC 2021
-----Original Message-----
Sent: Tuesday, May 18, 2021 3:15 PM
To: Ryan Long <ryan.long at oarcorp.com>
Cc: devel at rtems.org
Subject: Re: [PATCH v6 4/5] psx13: Added tests for utimensat() and futimens()
On Tue, May 18, 2021 at 2:03 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> Improved tests for utime() and utimes() and update license.
> Close #4399
> testsuites/psxtests/psx13/main.c | 5 +-
> testsuites/psxtests/psx13/test.c | 499
> 2 files changed, 481 insertions(+), 23 deletions(-)
> diff --git a/testsuites/psxtests/psx13/main.c
> b/testsuites/psxtests/psx13/main.c
> index f9e7907..7a560f9 100644
> --- a/testsuites/psxtests/psx13/main.c
> +++ b/testsuites/psxtests/psx13/main.c
> @@ -1,5 +1,3 @@
> -/* SPDX-License-Identifier: BSD-2-Clause */
why this is being removed?
[Ryan Long] I don't remember doing this, but I'll make sure it's put back in.
> * @file
> @@ -8,8 +6,7 @@
> - * COPYRIGHT (c) 1989-2009, 2021.
> - * On-Line Applications Research Corporation (OAR).
> + * COPYRIGHT (C) 1989, 2021 On-Line Applications Research Corporation (OAR).
> * Redistribution and use in source and binary forms, with or without
> * modification, are permitted provided that the following conditions
> diff --git a/testsuites/psxtests/psx13/test.c
> b/testsuites/psxtests/psx13/test.c
> index e98b03a..0754dbc 100644
> --- a/testsuites/psxtests/psx13/test.c
> +++ b/testsuites/psxtests/psx13/test.c
> @@ -1,4 +1,4 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> * @file
> @@ -17,12 +17,13 @@
> * - umask()
> * - utime()
> * - utimes()
> + * - utimensat()
> + * - futimens()
> * - sync()
> @@ -52,6 +53,8 @@
> #include <rtems.h>
> #include <rtems/libio.h>
> +#include <rtems/score/timespec.h>
> +#include <rtems/score/todimpl.h>
> #include <sys/time.h>
> #include <fcntl.h>
> #include <unistd.h>
> @@ -210,8 +213,7 @@ static void Dup2Test( void ) }
> - * @brief Exercises fdatasync(). Does NOT test the functionality of the
> - * underlying fdatasync entry in the IMFS op table.
> + * @brief Exercises fdatasync().
> static void FDataSyncTest( void )
> @@ -259,60 +261,517 @@ static void UMaskTest( void ) }
> - * @brief Exercises utime(). Does not test the functionality of the
> - * underlying utime entry in the IMFS op table.
> + * @brief Exercises utime().
> static void UTimeTest( void )
> int rv;
> struct utimbuf time;
> + struct timespec current_time;
> struct stat fstat;
> - /* First, an invalid filename. */
> + /* ENOENT test case */
> + /* Case: Pass an invalid filename. */
> rv = utime( "!This is an =invalid p at thname!!! :)", NULL );
> rtems_test_assert( rv == -1 );
> rtems_test_assert( errno == ENOENT );
> - /* Now, the success test. */
> + /* EACCES test case */
> + /* Case: Change user ID to someone besides root */ rv = seteuid( 1
> + ); rtems_test_assert( rv == 0 );
> + rv = utime( "testfile1.tst", NULL ); rtems_test_assert( rv == -1
> + ); rtems_test_assert( errno == EACCES );
> + rv = seteuid( 0 );
> + rtems_test_assert( rv == 0 );
> + /* EINVAL test cases */
> + /* Case: Invalid access time */
> + time.actime = -1;
> + time.modtime = 54321;
> + rv = utime( "testfile1.tst", &time ); rtems_test_assert( rv == -1
> + ); rtems_test_assert( errno == EINVAL );
> + /* Case: Invalid modified time */
> + time.actime = 12345;
> + time.modtime = -1;
> + /* Successful test cases */
> + /* Case: Test without times argument */ clock_gettime(
> + CLOCK_REALTIME, ¤t_time );
> + rv = utime( "testfile1.tst", NULL ); rtems_test_assert( rv == 0 );
> + rv = stat( "testfile1.tst", &fstat ); rtems_test_assert( rv == 0
> + ); rtems_test_assert( current_time.tv_sec <= fstat.st_atim.tv_sec
> + ); rtems_test_assert( current_time.tv_sec <= fstat.st_mtim.tv_sec
> + /* Case: time is filled with valid values */
> - /* But, did it set the time? */
> + /* Check that it actually changed the time */
> rtems_test_assert( fstat.st_atime == 12345 );
> rtems_test_assert( fstat.st_mtime == 54321 );
> - rv = utime( "testfile1.tst", NULL );
> - rtems_test_assert( rv == 0 );
> - * @brief Exercises utimes(). Does NOT test the functionality of the
> + * @brief Exercises utimes().
> static void UTimesTest( void )
> int rv;
> struct timeval time[2];
> struct stat fstat;
> + /* Case: First, an invalid filename. */
> rv = utimes( "!This is an =invalid p at thname!!! : )", NULL);
> + /* Change the user ID of the process to someone besides root */ rv
> + = seteuid( 1 ); rtems_test_assert( rv == 0 );
> + rv = utimes( "testfile1.tst", NULL ); rtems_test_assert( rv == -1
> + /* Case: Negative access time tv_sec value */ time[0].tv_sec = -1;
> + time[0].tv_usec = 12345; time[1].tv_sec = 54321; time[1].tv_usec =
> + 54321;
> + rv = utimes( "testfile1.tst", time ); rtems_test_assert( rv == -1
> + /* Case: Negative modified time second value */
> time[0].tv_sec = 12345;
> + time[1].tv_sec = -1;
> + /* Case: Negative access time microsecond value */
> + time[0].tv_usec = -1;
> + /* Case: Negative modified time microsecond value */
> + time[0].tv_usec = 12345; time[1].tv_usec = -1;
> + /* Case: Access time microsecond value too large */
> + time[0].tv_usec = 1000000; time[1].tv_usec = 54321;
> + /* Case: Modified time microsecond value too large */
> + time[1].tv_usec = 1000000; time[0].tv_usec = 12345;
> + rv = utimes( "testfile1.tst", NULL ); rtems_test_assert( rv == 0
> + /* Case: time is filled with valid values */ time[0].tv_sec =
> + 12345; time[0].tv_usec = 12345; time[1].tv_sec = 54321;
> + time[1].tv_usec = 54321;
> + rv = utimes( "testfile1.tst", time ); rtems_test_assert( rv == 0
> + rtems_test_assert( fstat.st_atime == 12345 );
> + rtems_test_assert( fstat.st_mtime == 54321 ); }
> + * @brief Exercises utimensat().
> +static void UTimensatTest( void )
> + int rv;
> + struct timespec time[2];
> + struct stat fstat;
> + /* ENOSYS test cases */
> + /* Case: Pass an unsupported file descriptor */ rv = utimensat(
> + 0,
> + "!This is an =invalid p at thname!!! : )",
> + NULL,
> + 0
> + rtems_test_assert( rv == -1 );
> + rtems_test_assert( errno == ENOSYS );
> + /* Case: Pass unsupported flag */
> + rv = utimensat(
> + AT_FDCWD,
> + NULL,
> + 1
> + /* Use an invalid filename. */
> + rv = utimensat(
> + AT_FDCWD,
> + NULL,
> + 0
> + rtems_test_assert( errno == ENOENT );
> + /* EACCES test Cases */
> + /* Case: When times is NULL and the user has insufficient
> + privileges */
> + rv = utimensat( AT_FDCWD, "testfile1.tst", NULL, 0 );
> + rtems_test_assert( rv == -1 ); rtems_test_assert( errno == EACCES
> + /* Case: File is read-only and time's tv_nsec members are UTIME_NOW
> + /* Change file to be read-only */
> + rv = chmod( "testfile1.tst", 06444 ); rtems_test_assert( rv == 0
> + _Timespec_Set( &time[0], 0, UTIME_NOW ); _Timespec_Set( &time[1],
> + 0, UTIME_NOW );
> + rv = utimensat( AT_FDCWD, "testfile1.tst", time, 0 );
> + rv = chmod( "testfile1.tst", fstat.st_mode ); rtems_test_assert(
> + rv == 0 );
> + /* Case: Negative access time second value */ _Timespec_Set(
> + &time[0], -12345, 12345 ); _Timespec_Set( &time[1], 54321, 54321 );
> + rtems_test_assert( rv == -1 ); rtems_test_assert( errno == EINVAL
> + /* Case: Negative modified time second value */ _Timespec_Set(
> + &time[0], 12345, 12345 ); _Timespec_Set( &time[1], -54321, 54321 );
> + /* Case: Negative access time nanosecond value */ _Timespec_Set(
> + &time[0], 12345, -12345 ); _Timespec_Set( &time[1], 54321, 54321 );
> + /* Case: Negative modified time nanosecond value */ _Timespec_Set(
> + &time[0], 12345, 12345 ); _Timespec_Set( &time[1], 54321, -54321 );
> + /* Case: Access time nanosecond value too large */ _Timespec_Set(
> + &time[0], 12345, TOD_NANOSECONDS_PER_SECOND ); _Timespec_Set(
> + &time[1], 54321, 54321 );
> + /* Case: Modified time nanosecond value too large */
> + _Timespec_Set( &time[0], 12345, 12345 ); _Timespec_Set( &time[1],
> + 54321, TOD_NANOSECONDS_PER_SECOND );
> + /* Case: Running with access time nanosecond field equal to
> + UTIME_NOW */ _Timespec_Set( &time[0], 12345, UTIME_NOW );
> + _Timespec_Set( &time[1], 54321, 54321 );
> + ); rtems_test_assert( fstat.st_mtime == 54321 );
> + /* Case: Running with modified time nanosecond field equal to
> + UTIME_NOW */ _Timespec_Set( &time[0], 12345, 12345 );
> + _Timespec_Set( &time[1], 54321, UTIME_NOW );
> + ); rtems_test_assert( fstat.st_atime == 12345 );
> + rtems_test_assert( current_time.tv_sec <= fstat.st_mtim.tv_sec );
> + /* Case: Normal run */
> + 54321, 54321 );
> + * @brief Exercises futimens().
> +static void FutimensTest( void )
> + int rv;
> + int fd;
> + /* EBADF test case */
> + /* Case: Pass an invalid file descriptor */ rv = futimens( -1,
> + time ); rtems_test_assert( rv == -1 ); rtems_test_assert( errno ==
> + EBADF );
> + fd = open( "testfile1.tst", O_RDWR ); rtems_test_assert( fd != -1
> + /* EACCES test cases */
> + privileges */
> + rv = futimens( fd, NULL );
> + rtems_test_assert( errno == EACCES );
> + 0, UTIME_NOW );
> + rv = futimens( fd, time );
> + rv == 0 );
> + rtems_test_assert( errno == EINVAL );
> +/* Case: Running with access time nanosecond field equal to UTIME_NOW
> + _Timespec_Set( &time[0], 12345, UTIME_NOW );
> + 54321, 54321 );
> - rv = utimes( "testfile1.tst", (struct timeval *)&time );
> rtems_test_assert( fstat.st_atime == 12345 ); @@ -443,6 +902,8 @@
> int test_main( void )
> UMaskTest();
> UTimeTest();
> UTimesTest();
> + UTimensatTest();
> + FutimensTest();
> FSyncTest();
> PathConfTest();
> FPathConfTest();
> 1.8.3.1
> devel mailing list
> devel at rtems.org
