[PATCH v7 3/5] libcsupport: Implement utimes() in terms of utimensat()
Ryan Long ryan.long at oarcorp.com
Wed May 19 00:10:30 UTC 2021
utimes() now calls utimensat() to update file access
and modification timestamps.
Updated license.
Closes #4398
 cpukit/libcsupport/src/utimes.c | 63 ++++++++++++++++++++++++++++++++---------
 1 file changed, 49 insertions(+), 14 deletions(-)
diff --git a/cpukit/libcsupport/src/utimes.c b/cpukit/libcsupport/src/utimes.c
index 3dc47c0..9748abb 100644
--- a/cpukit/libcsupport/src/utimes.c
+++ b/cpukit/libcsupport/src/utimes.c
@@ -1,38 +1,73 @@
  *  @file
- *  @brief Change File Last Access and Modification Times
  *  @ingroup libcsupport
+ *  @brief Set file access and modification times in milliseconds.
- *  Written by: Vinu Rajashekhar <vinutheraj at gmail.com>
+ * COPYRIGHT (C) 1989, 2021 On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
 #include "config.h"
 #endif
-#include <sys/types.h>
-#include <utime.h>
 #include <sys/time.h>
+#include <rtems/score/todimpl.h>
+#include <fcntl.h>
+ *  https://pubs.opengroup.org/onlinepubs/9699919799.2008edition/functions/futimens.html
+ *  Set file access and modification times
 int utimes(
   const char           *path,
   const struct timeval  times[2]
-  struct utimbuf timeinsecs;
+  struct timespec new_times[2];
-  if ( times == NULL )
-    return utime( path, NULL );
+  if ( times == NULL ) {
+    return utimensat( AT_FDCWD, path, NULL , 0 );
-  timeinsecs.actime  = times[0].tv_sec;
-  timeinsecs.modtime = times[1].tv_sec;
+  _Timespec_Set(
+    &new_times[0],
+    times[0].tv_sec,
+    times[0].tv_usec * TOD_NANOSECONDS_PER_MICROSECOND
+  _Timespec_Set(
+    &new_times[1],
+    times[1].tv_sec,
+    times[1].tv_usec * TOD_NANOSECONDS_PER_MICROSECOND
-  return utime( path, &timeinsecs );
+  return utimensat( AT_FDCWD, path, new_times, 0 );
1.8.3.1
