Heavy SysInit Dependency
Sebastian Huber
Wed May 19 14:05:07 UTC 2021
On 19/05/2021 15:09, Joel Sherrill wrote:
> On Wed, May 19, 2021 at 3:54 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 19/05/2021 10:23, Chris Johns wrote:
> >> On 19 May 2021, at 5:28 pm, Sebastian
> Huber<sebastian.huber at embedded-brains.de
> >> I am not sure how the dependency chain can be fixed with the
> current struct _reent approach of Newlib. A modern approach would be
> to replace this structure with individual thread-local objects. This
> would be technically feasible, however, a lot of work.
> > Do you mean the _reent structure is expanded out into separate
> TLS elements?
> Yes, something like:
> thread_local int errno;
> On paper this would work but most architectures do not have TLS
> support from RTEMS right now. On top of that, I honestly can't tell
> in GCC how TLS is implemented on many architectures. If there is
> a generic pattern, I'd be happy to be educated?
The most relevant architectures have TLS support, at least: arm,
powerpc, sparc, nios2, m68k.
The arm GCC target has a -mtp=soft option. This approach would work an
any target. You just have to add the GCC/llvm support for this for all
targets which need it.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
