[PATCH] bsps/raspberrypi/console: Fix default console device
Alan Cudmore
alan.cudmore at gmail.com
Thu May 20 11:41:14 UTC 2021
Hi Niteesh,
I tried your firmware, booting directly instead of using u-boot. I was
able to get the RTEMS 5 branch to run on the Raspberry Pi Zero, but I
still cannot get the master/6 branch to run. I need some time to do
additional tests. I was also going to re-try your patch and see if I
can run the master branch and your firmware with the Pi 3.
Our GSOC student just started a RPi improvement project, so I think
the first step should be to sort all of this out.
I'm pretty busy right now, but I'll see if I can continue testing in
the next few days. I want to try loading from u-boot next.
Alan
On Thu, May 20, 2021 at 12:52 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
> ping.
> On Tue, May 11, 2021 at 1:09 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
>> Hello Gedare,
>> On Mon, May 10, 2021 at 8:57 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Thu, May 6, 2021 at 8:49 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
>>> > Hi Alan,
>>> > On Thu, May 6, 2021 at 6:12 PM Alan Cudmore <alan.cudmore at gmail.com> wrote:
>>> >> Hi Niteesh,
>>> >> I was hoping to try this out as soon as I get some time. No later than weekend. So if nobody else is able to check it out, I will be able to provide some feedback soon.
>>> >> I should be able to bring up the console on a RPi Zero W and RPi3, correct?
>>> > the consoles should work on Zero W and Pi3 by default. They only fail to work when CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>> > this option is used. This is because when that option is used it calls console_initialize which checks if any boot options were present if none were
>>> > given it defaults to pl011 which is the secondary UART in Zero w and Pi3 so we get no output. This patch defaults to the primary UART instead of
>>> > pl011 depending on the board.
>>> > Also, this patch should be applied on RTEMS 5 since we started supporting Pi3 and Zero w from RTEMS 5.
>>> You'll need to provide a separate patch with a ticket to close on 5
>>> for a backport. Wait until you get the approval for the master branch
>>> though.
>> OK. I'll create a ticket and request for a backport once this is pushed on
>> to the current master
>> Thanks,
>> Niteesh.
>>> > Thanks,
>>> > Niteesh.
>>> >> Thanks,
>>> >> Alan
>>> >> From: Niteesh G. S.
>>> >> Sent: Thursday, May 6, 2021 4:29 AM
>>> >> To: Joel Sherrill; Christian Mauderer
>>> >> Cc: rtems-devel at rtems.org
>>> >> Subject: Re: [PATCH] bsps/raspberrypi/console: Fix default console device
>>> >> ping.
>>> >> On Sat, May 1, 2021 at 9:47 PM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
>>> >> On Sat, May 1, 2021 at 8:31 PM Joel Sherrill <joel at rtems.org> wrote:
>>> >> On Sat, May 1, 2021, 8:53 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
>>> >> Just to provide more context,
>>> >> When the CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER option is used
>>> >> and no --console option is provided, the console driver defaults to PL011.
>>> >> In raspberry pi 3 and other models whose primary UART is not PL011, we get no output.
>>> >> This patch fixes that by linking the primary UART to the console device.
>>> >> Thanks,
>>> >> Niteesh
>>> >> On Sat, May 1, 2021 at 7:05 PM G S Niteesh Babu <niteesh.gs at gmail.com> wrote:
>>> >> When no console argument is given, the driver defaults to pl011
>>> >> this results in no output in case of Rpi3 whose primary uart is
>>> >> miniuart.
>>> >> This patch fixes that by defaulting to the primary uart when no
>>> >> console option is provided.
>>> >> Does the default need to vary by model?
>>> >> Yes, the primary UART is different across models.
>>> >> Rpi's have two UARTs PL011 and miniuart, on models which have Bluetooth
>>> >> the PL011 is used to talk to the Bluetooth and miniuart acts as the primary UART.
>>> >> Now we can change this by adding miniuart-bt to config.txt but the miniuart is
>>> >> based on the VPU core and requires to add another option which sets the core to
>>> >> a fixed freq.
>>> >> bsps/arm/raspberrypi/console/console-config.c | 12 +++++++++---
>>> >> 1 file changed, 9 insertions(+), 3 deletions(-)
>>> >> diff --git a/bsps/arm/raspberrypi/console/console-config.c b/bsps/arm/raspberrypi/console/console-config.c
>>> >> index 6b8eb80aa4..bd3a8d34c2 100644
>>> >> --- a/bsps/arm/raspberrypi/console/console-config.c
>>> >> +++ b/bsps/arm/raspberrypi/console/console-config.c
>>> >> @@ -165,10 +165,16 @@ static void console_select( void )
>>> >> }else {
>>> >> - * If no command line option was given, default to PL011.
>>> >> + * If no console option was given we default to the primary uarts.
>>> >> + * The initialization of the uart's and BSP_output_char is already done
>>> >> + * in the uart_probe function called before this. So now we can safely
>>> >> + * compare BSP_output_char.
>>> >> - BSP_output_char = output_char_pl011;
>>> >> - link(PL011, CONSOLE_DEVICE_NAME);
>>> >> + if (BSP_output_char == output_char_pl011) {
>>> >> + link(PL011, CONSOLE_DEVICE_NAME);
>>> >> + }else {
>>> >> + link(MINIUART, CONSOLE_DEVICE_NAME);
>>> >> 2.17.1
>>> >> _______________________________________________
>>> >> devel mailing list
>>> >> devel at rtems.org
>>> >> http://lists.rtems.org/mailman/listinfo/devel
>>> > devel mailing list
>>> > devel at rtems.org
