[PATCH rtems v2] testsuites: Remove telnetd01
Vijay Kumar Banerjee vijay at rtems.org
Thu May 20 23:36:02 UTC 2021
Hi,
In the last review, the commit message wasn't clear, I fixed it in this version.
Does this look Ok to be merged?
Best regards,
Vijay
On Thu, Apr 22, 2021 at 8:02 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> telnetd01 test cannot be run without a network stack, so this test is being
> moved to the rtems-net-legacy repository.
>  spec/build/testsuites/libtests/grp.yml       |   2 -
>  spec/build/testsuites/libtests/telnetd01.yml |  22 ----
>  testsuites/libtests/telnetd01/init.c         | 120 -------------------
>  testsuites/libtests/telnetd01/telnetd01.doc  |  24 ----
>  testsuites/libtests/telnetd01/telnetd01.scn  |  11 --
>  5 files changed, 179 deletions(-)
>  delete mode 100644 spec/build/testsuites/libtests/telnetd01.yml
>  delete mode 100644 testsuites/libtests/telnetd01/init.c
>  delete mode 100644 testsuites/libtests/telnetd01/telnetd01.doc
>  delete mode 100644 testsuites/libtests/telnetd01/telnetd01.scn
> diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
> index 5695fc7f06..20a593a5d3 100644
> --- a/spec/build/testsuites/libtests/grp.yml
> +++ b/spec/build/testsuites/libtests/grp.yml
> @@ -258,8 +258,6 @@ links:
>    uid: tar02
>  - role: build-dependency
>    uid: tar03
> -- role: build-dependency
> -  uid: telnetd01
>    uid: termios
> diff --git a/spec/build/testsuites/libtests/telnetd01.yml b/spec/build/testsuites/libtests/telnetd01.yml
> deleted file mode 100644
> index 9f5bda84d9..0000000000
> --- a/spec/build/testsuites/libtests/telnetd01.yml
> +++ /dev/null
> @@ -1,22 +0,0 @@
> -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> -build-type: test-program
> -cflags: []
> -copyrights:
> -- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> -cppflags: []
> -cxxflags: []
> -enabled-by:
> -- RTEMS_NETWORKING
> -features: c cprogram
> -includes:
> -- cpukit/libnetworking
> -ldflags: []
> -links: []
> -source:
> -- testsuites/libtests/telnetd01/init.c
> -stlib: []
> -target: testsuites/libtests/telnetd01.exe
> -type: build
> -use-after:
> -- telnetd
> -use-before: []
> diff --git a/testsuites/libtests/telnetd01/init.c b/testsuites/libtests/telnetd01/init.c
> index a17126bf41..0000000000
> --- a/testsuites/libtests/telnetd01/init.c
> +++ /dev/null
> @@ -1,120 +0,0 @@
> - * Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
> - *  embedded brains GmbH
> - *  Dornierstr. 4
> - *  82178 Puchheim
> - *  Germany
> - *  <rtems at embedded-brains.de>
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> - * http://www.rtems.org/license/LICENSE.
> -#ifdef HAVE_CONFIG_H
> -#include "config.h"
> -#endif
> -#include <sys/stat.h>
> -#include <fcntl.h>
> -#include <string.h>
> -#include <rtems.h>
> -#include <rtems/rtems_bsdnet.h>
> -#include <rtems/telnetd.h>
> -#include <tmacros.h>
> -const char rtems_test_name[] = "TELNETD 1";
> -struct rtems_bsdnet_config rtems_bsdnet_config;
> -static void command(char *device_name, void *arg)
> -static void test_command_null(void)
> -  static const rtems_telnetd_config_table config = {
> -    .command = NULL
> -  rtems_status_code sc;
> -  sc = rtems_telnetd_start(&config);
> -  rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
> -static void test_cannot_start_server_task(void)
> -    .command = command,
> -    .priority = UINT32_MAX
> -  rtems_test_assert(sc == RTEMS_UNSATISFIED);
> -static void test_successful_start(void)
> -    .stack_size = RTEMS_MINIMUM_STACK_SIZE
> -  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> -static void test_already_started(void)
> -  rtems_test_assert(sc == RTEMS_RESOURCE_IN_USE);
> -static rtems_task Init(rtems_task_argument argument)
> -  int rv;
> -  TEST_BEGIN();
> -  rv = rtems_bsdnet_initialize_network();
> -  rtems_test_assert(rv == 0);
> -  test_command_null();
> -  test_cannot_start_server_task();
> -  test_successful_start();
> -  test_already_started();
> -  TEST_END();
> -  rtems_test_exit(0);
> -#define CONFIGURE_INIT
> -#define CONFIGURE_MICROSECONDS_PER_TICK 10000
> -#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> -#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> -#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS (3 + 1 + 5 * 4)
> -#define CONFIGURE_MAXIMUM_TASKS 8
> -#define CONFIGURE_MAXIMUM_POSIX_KEYS 1
> -#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> -#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> -#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
> -#include <rtems/confdefs.h>
> diff --git a/testsuites/libtests/telnetd01/telnetd01.doc b/testsuites/libtests/telnetd01/telnetd01.doc
> index fe1a4d31a3..0000000000
> --- a/testsuites/libtests/telnetd01/telnetd01.doc
> +++ /dev/null
> @@ -1,24 +0,0 @@
> -# Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
> -#  embedded brains GmbH
> -#  Dornierstr. 4
> -#  82178 Puchheim
> -#  Germany
> -#  <rtems at embedded-brains.de>
> -# The license and distribution terms for this file may be
> -# found in the file LICENSE in this distribution or at
> -# http://www.rtems.org/license/LICENSE.
> -This file describes the directives and concepts tested by this test set.
> -test set name: telnetd01
> -directives:
> -  - rtems_telnetd_start()
> -concepts:
> -+ Check if Telnet server works.
> diff --git a/testsuites/libtests/telnetd01/telnetd01.scn b/testsuites/libtests/telnetd01/telnetd01.scn
> index 3e9cc0007a..0000000000
> --- a/testsuites/libtests/telnetd01/telnetd01.scn
> +++ /dev/null
> @@ -1,11 +0,0 @@
> -*** BEGIN OF TEST TELNETD 1 ***
> -*** TEST VERSION: 5.0.0.dc32b6aa0807fb70f9b26bc0bc6e164ddb49bd3a
> -*** TEST STATE: EXPECTED_PASS
> -*** TEST BUILD: RTEMS_NETWORKING
> -*** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB 9670d7541e0621915e521fe76e7bb33de8cee661, Newlib d13c84eb07e35984bf7a974cd786a6cdac29e6b9)
> -syslog: telnetd: configuration with invalid command
> -syslog: telnetd: cannot create session task
> -syslog: telnetd: started successfully on port 23
> -syslog: telnetd: cannot bind server socket
> -*** END OF TEST TELNETD 1 ***
> 2.26.2
