[PATCH rtems v2] testsuites: Remove telnetd01
Vijay Kumar Banerjee vijay at rtems.org
Thu May 20 23:53:36 UTC 2021
On Thu, May 20, 2021 at 5:49 PM Joel Sherrill <joel.sherrill at gmail.com> wrote:
> Sure. Push it.
Thanks. Pushed.
> On Thu, May 20, 2021, 6:36 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> Hi,
>> In the last review, the commit message wasn't clear, I fixed it in this version.
>> Does this look Ok to be merged?
>> Best regards,
>> Vijay
>> On Thu, Apr 22, 2021 at 8:02 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> > telnetd01 test cannot be run without a network stack, so this test is being
>> > moved to the rtems-net-legacy repository.
>> >  spec/build/testsuites/libtests/grp.yml       |   2 -
>> >  spec/build/testsuites/libtests/telnetd01.yml |  22 ----
>> >  testsuites/libtests/telnetd01/init.c         | 120 -------------------
>> >  testsuites/libtests/telnetd01/telnetd01.doc  |  24 ----
>> >  testsuites/libtests/telnetd01/telnetd01.scn  |  11 --
>> >  5 files changed, 179 deletions(-)
>> >  delete mode 100644 spec/build/testsuites/libtests/telnetd01.yml
>> >  delete mode 100644 testsuites/libtests/telnetd01/init.c
>> >  delete mode 100644 testsuites/libtests/telnetd01/telnetd01.doc
>> >  delete mode 100644 testsuites/libtests/telnetd01/telnetd01.scn
>> > diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
>> > index 5695fc7f06..20a593a5d3 100644
>> > --- a/spec/build/testsuites/libtests/grp.yml
>> > +++ b/spec/build/testsuites/libtests/grp.yml
>> > @@ -258,8 +258,6 @@ links:
>> >    uid: tar02
>> >  - role: build-dependency
>> >    uid: tar03
>> > -- role: build-dependency
>> > -  uid: telnetd01
>> >    uid: termios
>> > diff --git a/spec/build/testsuites/libtests/telnetd01.yml b/spec/build/testsuites/libtests/telnetd01.yml
>> > deleted file mode 100644
>> > index 9f5bda84d9..0000000000
>> > --- a/spec/build/testsuites/libtests/telnetd01.yml
>> > +++ /dev/null
>> > @@ -1,22 +0,0 @@
>> > -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>> > -build-type: test-program
>> > -cflags: []
>> > -copyrights:
>> > -- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>> > -cppflags: []
>> > -cxxflags: []
>> > -enabled-by:
>> > -- RTEMS_NETWORKING
>> > -features: c cprogram
>> > -includes:
>> > -- cpukit/libnetworking
>> > -ldflags: []
>> > -links: []
>> > -source:
>> > -- testsuites/libtests/telnetd01/init.c
>> > -stlib: []
>> > -target: testsuites/libtests/telnetd01.exe
>> > -type: build
>> > -use-after:
>> > -- telnetd
>> > -use-before: []
>> > diff --git a/testsuites/libtests/telnetd01/init.c b/testsuites/libtests/telnetd01/init.c
>> > index a17126bf41..0000000000
>> > --- a/testsuites/libtests/telnetd01/init.c
>> > +++ /dev/null
>> > @@ -1,120 +0,0 @@
>> > - * Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
>> > - *  embedded brains GmbH
>> > - *  Dornierstr. 4
>> > - *  82178 Puchheim
>> > - *  Germany
>> > - *  <rtems at embedded-brains.de>
>> > - * The license and distribution terms for this file may be
>> > - * found in the file LICENSE in this distribution or at
>> > - * http://www.rtems.org/license/LICENSE.
>> > -#ifdef HAVE_CONFIG_H
>> > -#include "config.h"
>> > -#endif
>> > -#include <sys/stat.h>
>> > -#include <fcntl.h>
>> > -#include <string.h>
>> > -#include <rtems.h>
>> > -#include <rtems/rtems_bsdnet.h>
>> > -#include <rtems/telnetd.h>
>> > -#include <tmacros.h>
>> > -const char rtems_test_name[] = "TELNETD 1";
>> > -struct rtems_bsdnet_config rtems_bsdnet_config;
>> > -static void command(char *device_name, void *arg)
>> > -static void test_command_null(void)
>> > -  static const rtems_telnetd_config_table config = {
>> > -    .command = NULL
>> > -  rtems_status_code sc;
>> > -  sc = rtems_telnetd_start(&config);
>> > -  rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
>> > -static void test_cannot_start_server_task(void)
>> > -    .command = command,
>> > -    .priority = UINT32_MAX
>> > -  rtems_test_assert(sc == RTEMS_UNSATISFIED);
>> > -static void test_successful_start(void)
>> > -    .stack_size = RTEMS_MINIMUM_STACK_SIZE
>> > -  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
>> > -static void test_already_started(void)
>> > -  rtems_test_assert(sc == RTEMS_RESOURCE_IN_USE);
>> > -static rtems_task Init(rtems_task_argument argument)
>> > -  int rv;
>> > -  TEST_BEGIN();
>> > -  rv = rtems_bsdnet_initialize_network();
>> > -  rtems_test_assert(rv == 0);
>> > -  test_command_null();
>> > -  test_cannot_start_server_task();
>> > -  test_successful_start();
>> > -  test_already_started();
>> > -  TEST_END();
>> > -  rtems_test_exit(0);
>> > -#define CONFIGURE_INIT
>> > -#define CONFIGURE_MICROSECONDS_PER_TICK 10000
>> > -#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> > -#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
>> > -#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS (3 + 1 + 5 * 4)
>> > -#define CONFIGURE_MAXIMUM_TASKS 8
>> > -#define CONFIGURE_MAXIMUM_POSIX_KEYS 1
>> > -#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> > -#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> > -#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
>> > -#include <rtems/confdefs.h>
>> > diff --git a/testsuites/libtests/telnetd01/telnetd01.doc b/testsuites/libtests/telnetd01/telnetd01.doc
>> > index fe1a4d31a3..0000000000
>> > --- a/testsuites/libtests/telnetd01/telnetd01.doc
>> > +++ /dev/null
>> > @@ -1,24 +0,0 @@
>> > -# Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
>> > -#  embedded brains GmbH
>> > -#  Dornierstr. 4
>> > -#  82178 Puchheim
>> > -#  Germany
>> > -#  <rtems at embedded-brains.de>
>> > -# The license and distribution terms for this file may be
>> > -# found in the file LICENSE in this distribution or at
>> > -# http://www.rtems.org/license/LICENSE.
>> > -This file describes the directives and concepts tested by this test set.
>> > -test set name: telnetd01
>> > -directives:
>> > -  - rtems_telnetd_start()
>> > -concepts:
>> > -+ Check if Telnet server works.
>> > diff --git a/testsuites/libtests/telnetd01/telnetd01.scn b/testsuites/libtests/telnetd01/telnetd01.scn
>> > index 3e9cc0007a..0000000000
>> > --- a/testsuites/libtests/telnetd01/telnetd01.scn
>> > +++ /dev/null
>> > @@ -1,11 +0,0 @@
>> > -*** BEGIN OF TEST TELNETD 1 ***
>> > -*** TEST VERSION: 5.0.0.dc32b6aa0807fb70f9b26bc0bc6e164ddb49bd3a
>> > -*** TEST STATE: EXPECTED_PASS
>> > -*** TEST BUILD: RTEMS_NETWORKING
>> > -*** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB 9670d7541e0621915e521fe76e7bb33de8cee661, Newlib d13c84eb07e35984bf7a974cd786a6cdac29e6b9)
>> > -syslog: telnetd: configuration with invalid command
>> > -syslog: telnetd: cannot create session task
>> > -syslog: telnetd: started successfully on port 23
>> > -syslog: telnetd: cannot bind server socket
>> > -*** END OF TEST TELNETD 1 ***
>> > 2.26.2
>> devel mailing list
>> devel at rtems.org
