[PATCH v2] sysconf: Remove sysconf(515)
Gedare Bloom
gedare at rtems.org
Fri May 21 04:02:03 UTC 2021
looks good
On Thu, May 20, 2021 at 7:25 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> GCC originally needed this 20 years ago. No longer needed, so it
> is being removed.
> Closes #4391
> cpukit/posix/src/sysconf.c | 4 ----
> testsuites/psxtests/psxsysconf/init.c | 8 --------
> 2 files changed, 12 deletions(-)
> diff --git a/cpukit/posix/src/sysconf.c b/cpukit/posix/src/sysconf.c
> index 1696ec5..439a27e 100644
> --- a/cpukit/posix/src/sysconf.c
> +++ b/cpukit/posix/src/sysconf.c
> @@ -54,10 +54,6 @@ long sysconf(
> return (long) rtems_scheduler_get_processor_maximum();
> case _SC_POSIX_26_VERSION:
> return (long) _POSIX_26_VERSION;
> -#if defined(__sparc__)
> - case 515: /* Solaris _SC_STACK_PROT */
> - return 0;
> -#endif
> default:
> rtems_set_errno_and_return_minus_one( EINVAL );
> diff --git a/testsuites/psxtests/psxsysconf/init.c b/testsuites/psxtests/psxsysconf/init.c
> index a008af3..66d6dd3 100644
> --- a/testsuites/psxtests/psxsysconf/init.c
> +++ b/testsuites/psxtests/psxsysconf/init.c
> @@ -83,14 +83,6 @@ void *POSIX_Init(
> == (long) rtems_scheduler_get_processor_maximum()
> - /* Solaris _SC_STACK_PROT - 515 */
> - sc = sysconf( _SC_PAGESIZE );
> - printf( "sysconf - (SPARC only) _SC_STACK_PROT=%ld\n", sc );
> - if ( sc == -1 )
> - rtems_test_exit(0);
> -#endif
> TEST_END();
> rtems_test_exit( 0 );
> 1.8.3.1
> devel mailing list
> devel at rtems.org
