[PATCH v2] legacy nfs.c: Change filesystem utime_h handler to utimens_h
Fri May 21 14:43:46 UTC 2021
As a warning, this and the corresponding libbsd patch are queued
behind an RSB patch to get UTIME_NOW and UTIME_OMIT in
newlib. That patch was merged into newlib. Then the RTEMS
*utime* patch set and these two will go in at the same time. Otherwise,
there will be breakage.
On Fri, May 21, 2021 at 9:26 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, May 3, 2021 at 12:41 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> > Changed nfs_utime() to nfs_utimens(), changed the arguments to use
> > a timespec array instead of individual variables for access and
> > modified time.
> > Updates #4400
> >  nfsclient/src/nfs.c | 50
> >  1 file changed, 25 insertions(+), 25 deletions(-)
> > diff --git a/nfsclient/src/nfs.c b/nfsclient/src/nfs.c
> > index bc9a2c6..72fefb9 100644
> > --- a/nfsclient/src/nfs.c
> > +++ b/nfsclient/src/nfs.c
> > @@ -2050,19 +2050,19 @@ static int nfs_rmnod(
> >         return rv;
> > -static int nfs_utime(
> > +static int nfs_utimens(
> >         const rtems_filesystem_location_info_t  *pathloc, /* IN */
> > -       time_t                                   actime,  /* IN */
> > -       time_t                                   modtime  /* IN */
> > +       struct timespec                          times[2] /* IN */
> >  sattr  arg;
> >         /* TODO: add rtems EPOCH - UNIX EPOCH seconds */
> > -       arg.atime.seconds  = actime;
> > -       arg.atime.useconds = 0;
> > -       arg.mtime.seconds  = modtime;
> > -       arg.mtime.useconds = 0;
> > +       arg.atime.seconds  = times[0].tv_sec;
> > +       arg.atime.useconds = times[0].tv_nsec / 1000;
> Do we have a macro exposed for this, like in
> TOD_NANOSECONDS_PER_MICROSECOND? If not, this is fine I suppose.
This wouldn't be public since it doesn't start with RTEMS_ and I don't
see any of the TOD_ constants redefined in the RTEMS namespace.
> > +       arg.mtime.seconds  = times[1].tv_sec;
> > +       arg.mtime.useconds = times[1].tv_nsec / 1000;
> >         return nfs_sattr(pathloc->node_access, &arg, SATTR_ATIME |
> SATTR_MTIME);
> > @@ -2254,25 +2254,25 @@ sattr   arg;
> >  const struct _rtems_filesystem_operations_table nfs_fs_ops = {
> > -       .lock_h         = nfs_lock,
> > -       .unlock_h       = nfs_unlock,
> > -       .eval_path_h    = nfs_eval_path,
> > -       .link_h         = nfs_link,
> > +       .lock_h            = nfs_lock,
> > +       .unlock_h          = nfs_unlock,
> > +       .eval_path_h       = nfs_eval_path,
> > +       .link_h            = nfs_link,
> >         .are_nodes_equal_h = nfs_are_nodes_equal,
> > -       .mknod_h        = nfs_mknod,
> > -       .rmnod_h        = nfs_rmnod,
> > -       .fchmod_h       = nfs_fchmod,
> > -       .chown_h        = nfs_chown,
> > -       .clonenod_h     = nfs_clonenode,
> > -       .freenod_h      = nfs_freenode,
> > -       .mount_h        = rtems_filesystem_default_mount,
> > -       .unmount_h      = rtems_filesystem_default_unmount,
> > -       .fsunmount_me_h = nfs_fsunmount_me,
> > -       .utime_h        = nfs_utime,
> > -       .symlink_h      = nfs_symlink,
> > -       .readlink_h     = nfs_readlink,
> > -       .rename_h       = nfs_rename,
> > -       .statvfs_h      = rtems_filesystem_default_statvfs
> > +       .mknod_h           = nfs_mknod,
> > +       .rmnod_h           = nfs_rmnod,
> > +       .fchmod_h          = nfs_fchmod,
> > +       .chown_h           = nfs_chown,
> > +       .clonenod_h        = nfs_clonenode,
> > +       .freenod_h         = nfs_freenode,
> > +       .mount_h           = rtems_filesystem_default_mount,
> > +       .unmount_h         = rtems_filesystem_default_unmount,
> > +       .fsunmount_me_h    = nfs_fsunmount_me,
> > +       .utimens_h         = nfs_utimens,
> > +       .symlink_h         = nfs_symlink,
> > +       .readlink_h        = nfs_readlink,
> > +       .rename_h          = nfs_rename,
> > +       .statvfs_h         = rtems_filesystem_default_statvfs
> Why so many additional whitespace changes?
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210521/b9821859/attachment.html>
