How to debug on leon3 with sis and gdb
Richi Dubey
richidubey at gmail.com
Sat May 22 05:13:11 UTC 2021
Thanks for the quick response and the explanation! It was of immense help.
On Fri, May 21, 2021 at 2:05 PM Jiri Gaisler <jiri at gaisler.se> wrote:
> Forgot copy the list.
> On 5/21/21 7:02 AM, Richi Dubey wrote:
> Hi,
> A test fails at the assert(sc==RTEMS_SUCCESSFUL) after a call to
> rtems_task_set_affinity.
> So, following the docs <https://devel.rtems.org/wiki/Debugging/sis>, I
> figured out where the break point should be set:
> $ ~/quick-start/rtems/6/bin/sparc-rtems6-sis -leon3 -m 4
> ~/sis-quick-start/src/rtems/build/sparc/leon3/testsuites/smptests/smpschedstrongapa01.exe
> SIS - SPARC/RISCV instruction simulator 2.26, copyright Jiri Gaisler 2020
> Bug-reports to jiri at gaisler.se
> LEON3 emulation enabled, 4 cpus online, delta 50 clocks
> Loaded
> /home/richi/sis-quick-start/src/rtems/build/sparc/leon3/testsuites/smptests/smpschedstrongapa01.exe,
> entry 0x40000000
> cpu0> hi 10
> trace history length = 10
> cpu0> run
> Waking CPU 1
> Waking CPU 2
> Waking CPU 3
> assertion "sc == RTEMS_SUCCESSFUL" failed: file
> "../../../testsuites/smptests/smpschedstrongapa01/init.c", line 264,
> function: Init
> cpu 0 in error mode (tt = 0x80)
> 423950 4000f9e0: 91d02000 ta 0x0
> cpu0> hi
> 423922 40019d40: 90100018 mov %i0, %o0
> 423923 4000f9e4: 82102001 mov 1, %g1
> 423924 4000f9e8: 84100008 mov %o0, %g2
> 423925 4000f9ec: 86100009 mov %o1, %g3
> 423926 4000f9f0: 91d02000 ta 0x0
> 423928 40000800: a1480000 mov %psr, %l0
> 423929 40000804: 2910003e sethi %hi(0x4000f800), %l4
> 423930 40000808: 81c521e0 jmp %l4 + 0x1e0
> 423932 4000080c: a6102080 mov 128, %l3
> 423933 4000f9e0: 91d02000 ta 0x0
> cpu0> reg
> INS LOCALS OUTS GLOBALS
> 0: 00000007 F3001FC6 00000007 00000000
> 1: 4002F008 4000F9F0 00000000 00000001
> 2: 40029CF8 4000F9F4 4002F008 00000007
> 3: 0000000A 00000080 40020400 4002F008
> 4: 00000073 4000F800 0000000E 00000000
> 5: 40029C00 00000000 00000004 00000000
> 6: 4002EEE0 4002A250 4002EE78 4002CD00
> 7: 40019D3C 4002CD00 4000EC80 00000000
> psr: F3001FC6 wim: 00000008 tbr: 40000800 y: 00000000
> pc: 4000F9E0 = 91D02000 ta 0x0
> npc: 4000F9E4 = 82102001 mov 1, %g1
> IU in error mode
> cpu0> quit
> So the breakpoint has to be set at the second last instruction at address
> 0x4000080c
> This is the wrong assumption. The program does not halt where the
> assertion fails, it prints the error message and exits the normal way. To
> stop execution right where the assertion is made, you should add a
> breakpoint at the line number:
> bre init.c:264
> Also, make sure you compile RTEMS without optimization, or single-stepping
> and debugging will be hard. I usually do this by removing all optimization
> flags in the OPTIMIZATION_FLAGS variable in the bsp .ini file before
> configuring with waf.
> But when I try to debug this with gdb keeping the sis as remote target, it
> does not work:
> $ ~/quick-start/rtems/6/bin/sparc-rtems6-gdb
> GNU gdb (GDB) 10.1.90.20210409-git
> Copyright (C) 2021 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later <
> http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law.
> Type "show copying" and "show warranty" for details.
> This GDB was configured as "--host=x86_64-linux-gnu --target=sparc-rtems6".
> Type "show configuration" for configuration details.
> For bug reporting instructions, please see:
> <https://www.gnu.org/software/gdb/bugs/>.
> Find the GDB manual and other documentation resources online at:
> <http://www.gnu.org/software/gdb/documentation/>.
> For help, type "help".
> Type "apropos word" to search for commands related to "word"...
> Reading symbols from
> /home/richi/sis-quick-start/src/rtems/build/sparc/leon3/testsuites/smptests/smpschedstrongapa01.exe...
> (gdb) tar sim -leon3
> Undefined target command: "sim -leon3". Try "help target".
> (gdb) target extended-remote localhost:1234
> Remote debugging using localhost:1234
> 0x00000000 in ?? ()
> (gdb) load
> Loading section .text, size 0x218f0 lma 0x40000000
> Loading section .rtemsroset, size 0x90 lma 0x400218f0
> Loading section .data, size 0x530 lma 0x40029980
> Start address 0x40000000, load size 138928
> Transfer rate: 3083 KB/sec, 271 bytes/write.
> (gdb) bre 0x4000080c
> To break at a hex address in gdb, you need a pointer:
> bre *0x4000080c
> Function "0x4000080c" not defined.
> Make breakpoint pending on future shared library load? (y or [n]) y
> Breakpoint 1 (0x4000080c) pending.
> (gdb) run
> The program being debugged has been started already.
> Start it from the beginning? (y or n) y
> Starting program:
> Program received signal SIGTERM, Terminated.
> syscall () at ../../../cpukit/score/cpu/sparc/syscall.S:44
> 44 ta 0 ! syscall 1, halt with %g1,%g2,%g3 info
> (gdb)
> And the output on the other terminal is:
> $ ~/quick-start/rtems/6/bin/sparc-rtems6-sis -leon3 -m 4 -gdb
> gdb: listening on port 1234 connected
> X40000000,0:#72
> Waking CPU 1
> Waking CPU 2
> Waking CPU 3
> function: Init
> So, is there a way I can debug this? Can I use si or ni, cause it is not
> working here when I tried it after 'load'. Also can I not set breakpoints
> at functions and then step continue till the function comes?
> Please advise.
> Thanks.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210522/7eb8c6dc/attachment.html>
