[PATCH 1/2] covoar: Store only the file name in ExecutableInfo
Chris Johns
chrisj at rtems.org
Tue May 25 23:35:08 UTC 2021
On 4/5/21 7:07 pm, Gedare Bloom wrote:
> On Fri, Apr 30, 2021 at 2:02 PM Alex White <alex.white at oarcorp.com> wrote:
>> This changes the ExecutableInfo class to only store the executable
>> file's name rather than an entire instance of rld::files::object. This
>> allows the rld::files::object to be cleaned up in the ExecutableInfo
>> constructor.
>> Updates #4383
>> tester/covoar/ExecutableInfo.cc | 12 +++++-------
>> tester/covoar/ExecutableInfo.h | 10 +++++-----
>> 2 files changed, 10 insertions(+), 12 deletions(-)
>> diff --git a/tester/covoar/ExecutableInfo.cc b/tester/covoar/ExecutableInfo.cc
>> index fc368ce..861e60d 100644
>> --- a/tester/covoar/ExecutableInfo.cc
>> +++ b/tester/covoar/ExecutableInfo.cc
>> @@ -21,7 +21,7 @@ namespace Coverage {
>> const char* const theExecutableName,
>> const char* const theLibraryName,
>> bool verbose
>> - ) : executable(theExecutableName),
>> + ) : fileName(theExecutableName),
>> loadAddress(0)
>> if (theLibraryName != nullptr)
>> @@ -34,6 +34,8 @@ namespace Coverage {
>> std::cerr << std::endl;
>> + rld::files::object executable(theExecutableName);
>> executable.open();
>> executable.begin();
>> executable.load_symbols(symbols);
>> @@ -82,8 +84,6 @@ namespace Coverage {
>> } catch (...) {
>> debug.end();
>> - executable.end();
>> - executable.close();
> I may be missing something, but don't you still need to end() and close() it?
The object is now local scope so the object destructs when control exits the
block and that should clean things up.
>> throw;
>> @@ -95,8 +95,6 @@ namespace Coverage {
>> ExecutableInfo::~ExecutableInfo()
>> debug.end();
>> - executable.end();
>> void ExecutableInfo::dumpCoverageMaps( void ) {
>> @@ -132,9 +130,9 @@ namespace Coverage {
>> return aCoverageMap;
>> - const std::string ExecutableInfo::getFileName ( void ) const
>> + const std::string& ExecutableInfo::getFileName ( void ) const
>> - return executable.name().full();
>> + return fileName;
>> const std::string ExecutableInfo::getLibraryName( void ) const
>> diff --git a/tester/covoar/ExecutableInfo.h b/tester/covoar/ExecutableInfo.h
>> index d5ccb19..5d5a595 100644
>> --- a/tester/covoar/ExecutableInfo.h
>> +++ b/tester/covoar/ExecutableInfo.h
>> @@ -77,7 +77,7 @@ namespace Coverage {
>> * @return Returns the executable's file name
>> - const std::string getFileName( void ) const;
>> + const std::string& getFileName( void ) const;
>> * This method returns the library name associated with the executable.
>> @@ -158,14 +158,14 @@ namespace Coverage {
>> - * The ELF executable.
>> + * The DWARF data to the ELF executable.
>> - rld::files::object executable;
>> + rld::dwarf::file debug;
>> - * The DWARF data to the ELF executable.
>> + * The executable's file name.
>> - rld::dwarf::file debug;
>> + std::string fileName;
>> * The executable's symbol table.
>> 2.27.0
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
