[PATCH] cpukit: Add description of release version numbers
Christian Mauderer
christian.mauderer at embedded-brains.de
Wed May 26 07:41:43 UTC 2021
The release version in the git sources doesn't change. Add a note why
that is the case.
cpukit/include/rtems/version.h | 12 ++++++++++++
1 file changed, 12 insertions(+)
diff --git a/cpukit/include/rtems/version.h b/cpukit/include/rtems/version.h
index a8aff732f3..2e068cd976 100644
--- a/cpukit/include/rtems/version.h
+++ b/cpukit/include/rtems/version.h
@@ -29,6 +29,18 @@ extern "C" {
* @brief The Version API provides functions to return the version or parts of
* the version of RTEMS you are using.
+ * A branch in the version control system will always fall back to a
+ * not-released version number with a minor number of 0. Only the release
+ * archives have a VERSION file with a final release number. That means for
+ * example that the 5 development branch will still show a version 5.0.0 even
+ * after the 5.1 release.
+ * The reason for that is the following: All pre-release tests are performed for
+ * a specific git hash. If the VERSION file would be changed and committed
+ * afterwards for releasing a new version, the released version would have a
+ * different git hash and the test results couldn't be linked to the released
+ * version.
2.26.2
