[PATCH rtems] thread-API: Add rtems_*mutex_try_lock
Christian Mauderer
christian.mauderer at embedded-brains.de
Wed May 26 09:33:27 UTC 2021
This adds a rtems_mutex_try_lock and a rtems_recursive_mutex_try_lock.
Update #4440.
cpukit/include/rtems/thread.h | 12 +++++
testsuites/sptests/spthread01/init.c | 79 ++++++++++++++++++++++++++++
2 files changed, 91 insertions(+)
diff --git a/cpukit/include/rtems/thread.h b/cpukit/include/rtems/thread.h
index feee612d22..d0cb03c284 100644
--- a/cpukit/include/rtems/thread.h
+++ b/cpukit/include/rtems/thread.h
@@ -54,6 +54,11 @@ static __inline void rtems_mutex_lock( rtems_mutex *mutex )
_Mutex_Acquire( mutex );
+static __inline int rtems_mutex_try_lock( rtems_mutex *mutex )
+ return _Mutex_Try_acquire( mutex );
static __inline void rtems_mutex_unlock( rtems_mutex *mutex )
_Mutex_Release( mutex );
@@ -97,6 +102,13 @@ static __inline void rtems_recursive_mutex_lock(
_Mutex_recursive_Acquire( mutex );
+static __inline int rtems_recursive_mutex_try_lock(
+ rtems_recursive_mutex *mutex
+ return _Mutex_recursive_Try_acquire( mutex );
static __inline void rtems_recursive_mutex_unlock(
diff --git a/testsuites/sptests/spthread01/init.c b/testsuites/sptests/spthread01/init.c
index 4c5bfc12e1..9044ca2601 100644
--- a/testsuites/sptests/spthread01/init.c
+++ b/testsuites/sptests/spthread01/init.c
@@ -25,10 +25,74 @@
const char rtems_test_name[] = "SPTHREAD 1";
+#define WAKEUP_EVENT RTEMS_EVENT_0
+typedef struct {
+ rtems_mutex *mtx;
+ rtems_recursive_mutex *rmtx;
+ rtems_id calling_task;
+} mutex_context;
+static void mutex_task(rtems_task_argument arg)
+ mutex_context *m;
+ int rv;
+ m = (mutex_context *) arg;
+ rtems_test_assert(m->mtx != NULL || m->rmtx != NULL);
+ if (m->mtx) {
+ rv = rtems_mutex_try_lock(m->mtx);
+ rtems_test_assert(rv == EBUSY);
+ if (m->rmtx) {
+ rv = rtems_recursive_mutex_try_lock(m->rmtx);
+ rtems_event_send(m->calling_task, WAKEUP_EVENT);
+static void test_try_lock_from_different_task(
+ rtems_mutex *m,
+ mutex_context ctx;
+ rtems_status_code sc;
+ rtems_event_set e;
+ rtems_id id;
+ ctx.mtx = m;
+ ctx.rmtx = r;
+ ctx.calling_task = rtems_task_self();
+ sc = rtems_task_create(
+ rtems_build_name('M', 'T', 'X', ' '),
+ 2,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &id
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ sc = rtems_task_start(id, mutex_task, (rtems_task_argument) &ctx);
+ sc = rtems_event_receive(WAKEUP_EVENT, RTEMS_EVENT_ANY | RTEMS_WAIT, 10, &e);
+ rtems_task_delete(id);
static void test_mutex(void)
rtems_mutex a = RTEMS_MUTEX_INITIALIZER("a");
const char *name;
+ int rv;
name = rtems_mutex_get_name(&a);
rtems_test_assert(strcmp(name, "a") == 0);
@@ -47,6 +111,13 @@ static void test_mutex(void)
rtems_mutex_lock(&a);
+ test_try_lock_from_different_task(&a, NULL);
+ rtems_mutex_unlock(&a);
+ rv = rtems_mutex_try_lock(&a);
+ rtems_test_assert(rv == 0);
rtems_mutex_destroy(&a);
@@ -56,6 +127,7 @@ static void test_recursive_mutex(void)
rtems_recursive_mutex a = RTEMS_RECURSIVE_MUTEX_INITIALIZER("a");
const char *name;
+ int rv;
name = rtems_recursive_mutex_get_name(&a);
@@ -76,6 +148,13 @@ static void test_recursive_mutex(void)
rtems_recursive_mutex_lock(&a);
+ rv = rtems_recursive_mutex_try_lock(&a);
+ test_try_lock_from_different_task(NULL, &a);
+ rtems_recursive_mutex_unlock(&a);
2.26.2
