Minimum.exe Text Size Outliers
Joel Sherrill
joel at rtems.org
Wed May 26 17:23:10 UTC 2021
On Wed, May 26, 2021 at 6:02 AM Sebastian Huber <
> On 25/05/2021 20:33, Christian Mauderer wrote:
> >> I thought Sebastian added a "malloc" for the BSP to use before the
> >> heap was initialized. But I don't remember the name. Am I remembering
> >> correctly?
> > I don't really know that malloc. But I doubt that it works that early.
> > Again: Copying the FDT is one of the first things that these BSPs do. If
> > you want to know the exact location: For ARM it's here:
> > https://git.rtems.org/rtems/tree/bsps/arm/shared/start/start.S#n325
> > So it's really basic setup before that. It's interrupt stack, switching
> > modes, setup stack pointer and then it's already copy FDT.
> Yes, there is an early "malloc". This is _Memory_Allocate() using
> _Memory_Get(). However, for the device tree copy this is not early
> enough. We don't know the device tree location provided by the boot
> loader. It could be somewhere in the memory area used by the
> application. So, it is important to copy this very early into a fixed
> location. Also, the device tree may be used to get the size of the
> memory provided by _Memory_Get().
I assume read-only is only from the perspective of higher level
language code. Is it possible that being read-only it could be
mapped to Flash?
For the purposes of minimum size analysis, I will subtract the
size of the FDT block from the minimum .text size and if it
is still over 64, flag it.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210526/f173c977/attachment.html>
