[PATCH v2 2/6] bsps/aarch64: Align MVAs consistently
Kinsey Moore kinsey.moore at oarcorp.com
Wed May 26 21:01:44 UTC 2021
This fixes a bug where addresses were not being aligned correctly.
Addresses used in cache functions are now aligned consistently using
RTEMS_ALIGN_DOWN.
 bsps/aarch64/shared/cache/cache.c | 13 +++++--------
 1 file changed, 5 insertions(+), 8 deletions(-)
diff --git a/bsps/aarch64/shared/cache/cache.c b/bsps/aarch64/shared/cache/cache.c
index ce2e130abe..47722c21e4 100644
--- a/bsps/aarch64/shared/cache/cache.c
+++ b/bsps/aarch64/shared/cache/cache.c
@@ -39,11 +39,9 @@
 #include <bsp/utility.h>
 #include <rtems/score/aarch64-system-registers.h>
-#define AARCH64_CACHE_L1_CPU_DATA_ALIGNMENT ((size_t)64)
-#define AARCH64_CACHE_L1_DATA_LINE_MASK \
-  ( AARCH64_CACHE_L1_CPU_DATA_ALIGNMENT - 1 )
-#define AARCH64_CACHE_PREPARE_MVA(mva) \
-  ((const void *) (((size_t) (mva)) & AARCH64_CACHE_L1_DATA_LINE_MASK))
+#define AARCH64_CACHE_L1_CPU_DATA_ALIGNMENT ( (size_t) 64 )
+#define AARCH64_CACHE_PREPARE_MVA(mva) (const void *) \
+  RTEMS_ALIGN_DOWN ( (size_t) mva, AARCH64_CACHE_L1_CPU_DATA_ALIGNMENT )
 static inline
 void AArch64_data_cache_clean_and_invalidate_line(const void *d_addr)
@@ -75,7 +73,7 @@ _CPU_cache_flush_data_range(
   _AARCH64_Data_synchronization_barrier();
   if ( n_bytes != 0 ) {
-    size_t adx = (size_t) d_addr & ~AARCH64_CACHE_L1_DATA_LINE_MASK;
+    size_t adx = (size_t) AARCH64_CACHE_PREPARE_MVA ( d_addr );
     const size_t ADDR_LAST = (size_t) d_addr + n_bytes - 1;
     for (; adx <= ADDR_LAST; adx += AARCH64_CACHE_L1_CPU_DATA_ALIGNMENT ) {
@@ -116,8 +114,7 @@ _CPU_cache_invalidate_data_range(
-                         & ~AARCH64_CACHE_L1_DATA_LINE_MASK;
     const size_t end = (size_t)d_addr + n_bytes -1;
     /* Back starting address up to start of a line and invalidate until end */
2.20.1
