[PATCH v2 6/6] spec/aarch64: Add BSPs for real ZynqMP hardware
Kinsey Moore
kinsey.moore at oarcorp.com
Wed May 26 21:01:48 UTC 2021
Add the BSPs for running on the ZU3EG Ultrascale+ Zynq MPSoC and alter
the option defaults necessary for them to run properly using the
standard BOOT.BIN configured for PetaLinux that comes in the Out-of-Box
package.
spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml | 1 +
.../aarch64/xilinx-zynqmp/bspzu3egilp32.yml | 19 +++++++++++++++++++
.../aarch64/xilinx-zynqmp/bspzu3eglp64.yml | 19 +++++++++++++++++++
.../bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml | 18 ++++++++++++++++++
.../bsps/aarch64/xilinx-zynqmp/optloadoff.yml | 6 +++++-
.../bsps/aarch64/xilinx-zynqmp/optramori.yml | 6 +++++-
.../bsps/aarch64/xilinx-zynqmp/tstzu3eg.yml | 18 ++++++++++++++++++
7 files changed, 85 insertions(+), 2 deletions(-)
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/tstzu3eg.yml
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml
index c723b5f252..56c7694f35 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml
@@ -14,6 +14,7 @@ default-by-variant:
- -mabi=ilp32
variants:
- aarch64/xilinx_zynqmp_ilp32_qemu
+ - aarch64/xilinx_zynqmp_ilp32_zu3eg
description: |
ABI flags
enabled-by: true
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml
new file mode 100644
index 0000000000..dd7d39fb94
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3egilp32.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+arch: aarch64
+bsp: xilinx_zynqmp_ilp32_zu3eg
+build-type: bsp
+cflags: []
+copyrights:
+- Copyright (C) 2020 On-Line Applications Research (OAR)
+cppflags: []
+enabled-by: true
+family: xilinx-zynqmp
+includes: []
+install: []
+links:
+- role: build-dependency
+ uid: grp_zu3eg
+ uid: linkcmds_ilp32
+source: []
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml
index 0000000000..073e91175b
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspzu3eglp64.yml
@@ -0,0 +1,19 @@
+arch: aarch64
+bsp: xilinx_zynqmp_lp64_zu3eg
+build-type: bsp
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+install: []
+links:
+ uid: grp_zu3eg
+ uid: linkcmds_lp64
+source: []
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml
index 0000000000..801195cdf5
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml
@@ -0,0 +1,18 @@
+build-type: group
+copyrights:
+- Copyright (C) 2021 On-Line Applications Research (OAR)
+enabled-by: true
+includes: []
+install: []
+ldflags: []
+links:
+ uid: grp
+ uid: ../../optstarthyp
+ uid: tstzu3eg
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
index 4546006c7e..0bdc2d61df 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
@@ -8,7 +8,11 @@ build-type: option
copyrights:
default: 32768
-default-by-variant: []
+default-by-variant:
+- value: 0x0
+ variants:
+ - aarch64/xilinx_zynqmp_lp64_zu3eg
description: |
offset of RAM region from memory area base
enabled-by: true
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
index 73c89995ba..c17febe288 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
copyrights:
default: 0x40018000
+- value: 0x10000000
+ variants:
description: |
base address of memory area available to the BSP
enabled-by: true
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/tstzu3eg.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/tstzu3eg.yml
index 0000000000..8bf646b1d4
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/tstzu3eg.yml
@@ -0,0 +1,18 @@
+actions:
+- set-test-state:
+ # expected to produce a fatal-error when run
+ minimum: exclude
+ # don't compile due to toolchain issues, see RTEMS issue #4218
+ spconfig01: exclude
+ spmisc01: exclude
+build-type: option
+copyrights:
+default: null
+default-by-variant: []
+description: ''
+enabled-by: true
+links: []
+type: build
2.20.1
