[PATCH] cpukit/libpci: fix potential buffer overflow in pci_cfg_print_code.c
Vijay Kumar Banerjee
vijay at rtems.org
Wed May 26 22:46:57 UTC 2021
Hi,
On Wed, May 26, 2021 at 2:45 PM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, May 26, 2021 at 1:58 PM Harrison Edward Gerber <gerberhe11 at gmail.com> wrote:
>> See also CID 1399721
>> Closes #4442
> Blank line between these.
> But otherwise I think this looks good.
I pushed it with the added blank line in the commit message.
Thanks.
> Gedare... this looks like a good paper on this family of methods for
> advice on safe programming:
> https://www.sudo.ws/todd/papers/strlcpy.html
> Should we put a discussion of this type of issue in the Coding Style
> and reference it?
>> cpukit/libpci/pci_cfg_print_code.c | 4 ++--
>> 1 file changed, 2 insertions(+), 2 deletions(-)
>> diff --git a/cpukit/libpci/pci_cfg_print_code.c b/cpukit/libpci/pci_cfg_print_code.c
>> index e758fa661a..e0979db74a 100644
>> --- a/cpukit/libpci/pci_cfg_print_code.c
>> +++ b/cpukit/libpci/pci_cfg_print_code.c
>> @@ -65,8 +65,8 @@ static void pci_cfg_print_device(struct pci_dev *dev, char *prefix)
>> char name[32];
>> char buf[8];
>> printf("%s.resources = {\n", prefix);
>> - strcpy(buf, prefix);
>> - strcat(buf, "\t");
>> + strlcpy(buf, prefix, sizeof(buf));
>> + strlcat(buf, "\t", sizeof(buf));
>> pci_cfg_print_resources(dev->resources, buf);
>> printf("%s},\n", prefix);
>> if (dev->next == NULL) {
>> 2.25.1
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
