RTEMS source builder: can't find RTEMS include files but then can?
Joel Sherrill
joel at rtems.org
Thu May 27 01:50:40 UTC 2021
On Wed, May 26, 2021, 7:54 PM Chris Johns <chrisj at rtems.org> wrote:
> On 30/4/21 1:15 am, dufault at hda.com wrote:
> >> On Apr 30, 2021, at 05:03 , dufault at hda.com wrote:
> >> Can I override what to use as "cmake" in RSB to specify "cmake3"?
> >>> On Apr 30, 2021, at 04:41 , Peter Dufault <dufault at hda.com> wrote:
> >>> I verified my environment is squeaky-clean with a simple path and no
> environment variables set that affect RTEMS or "make".
> > I need help figuring out how to setup rtems-source-builder, SOEM, and
> cmake. I got it to "work" but it's mis-configured. At first it is not
> finding header files (is it looking at the Linux headers?), then it
> installs SOEM in the wrong place, etc. I can get the build and install to
> "work" by re-running commands in a shell script - the second time a command
> is run it behaves differently.
> > - *Notes*
> > -- This started when I updated SOEM and needed to change to "cmake3".
> > -- After the following convoluted process the testing I've done on the
> results are OK.
> > - To simplify my path I make it simple except I add a directory with
> only a "cmake" bash script: "cmake3 $*" in order to pick up cmake3.
> Maybe the --macros argument can help. Create a file `xyz.txt` containing
> __cmake: exe, optional, 'cmake3'
> then try running with `--macros=xyz.txt` If the recipe for the build using
> cmake
> uses `%{__cmake}` then this may work. I have not tested any of this. :)
This may be a stupid question but can you build it by hand?
--joel
> Chris
> > - The first time I run "sb-set-builder" the SOEM build fails because it
> can't find <net/bpf.h>. This is just after it compiled a C file that
> includes <net/if.h>. I'm not sure where it is looking for the headers, I'd
> expect it would fail earlier if it was trying to use Linux headers, it's
> all the way to the last file.
> > - I then run the do-build script sb-set-builder created and it builds
> SOEM *but it installs it in the wrong place*.
> > -- The do-build script is in
> "${GITDIR}/rtems/rtems-source-builder/rtems/build/soem-powerpc-rtems6-1/do-build"
> > -- "do-build" installs SOEM in in
> "${GITDIR}/rtems-source-builder/rtems/build/tmp/soem-powerpc-rtems6-1-root-dufault/opt/flatland/opt/rtems-6"
> instead of "/opt/flatland/opt/rtems-6".
> > - I then go to the generated directory
> "${GITDIR}/rtems/rtems-source-builder/rtems/build/soem-powerpc-rtems6-1/build-xc"
> and type "make install" The make succeeds, and *it installs SOEM in the
> correct place* and SOEM is "successfully" built and installed.
> > - The last nit is that when I try to build the SOEM examples I need to
> export LDFLAGS="-lrtemsdefaultconfig -lm" to get the SOEM examples to
> configure. *Note* this was an issue before I switched to cmake3, this one
> is not new.
> > I hope this gives someone enough clues to suggest what must be done to
> set source builder up correctly. For reference here's the script.
> > #!/bin/sh
> > set -e
> > # Script to get SOEM to build and install "properly". I just need to be
> insistent.
> > HERE=$(pwd)
> > # Clean up environment rsb-overrides only has a cmake shell script that
> is "cmake $*".
> > export PATH=${HOME}/bin/rsb-overrides:/usr/bin:/usr/sbin:/bin:/sbin
> > unset LD_IBRARY_PATH
> > export RTEMS_GIT=/home/dufault/development/rtems
> > export RTEMS_VER=6
> > export RTEMS_SB=${RTEMS_GIT}/rtems-source-builder
> > export RTEMS_SB_BUILD=${RTEMS_SB}/rtems/build
> > export RTEMS_TOOLS=/opt/flatland/opt/rtems-${RTEMS_VER}
> > export RTEMS_ARCH=powerpc
> > export RTEMS_BSP=beatnik
> > # "soem-rtems" fetches waf-2.0.4.
> > SOEM_WAF=waf-2.0.4
> > SOEM_TIDY_UP="\
> ${RTEMS_TOOLS}/share/rtems/rsb/soem-${RTEMS_ARCH}-rtems${RTEMS_VER}-1.txt \
> ${RTEMS_TOOLS}/share/rtems/rsb/soem-${RTEMS_ARCH}-rtems${RTEMS_VER}-1.xml \
> ${RTEMS_TOOLS}/${RTEMS_ARCH}-rtems${RTEMS_VER}/${RTEMS_BSP}/lib/share/soem
> ${RTEMS_TOOLS}/${RTEMS_ARCH}-rtems${RTEMS_VER}/${RTEMS_BSP}/lib/include/soem"
> > # We have this setup: ${RTEMS_GIT}
> > # |-- soem-rtems
> > # |-- rtems
> > # |-- rtems-source-builder
> > # First tidy-up so we always start in the same state.
> > rm -rf ${RTEMS_SB_BUILD} ${SOEM_TIDY_UP}
> > cd ${RTEMS_GIT}/soem-rtems
> > if [ ! -e ${SOEM_WAF} ]; then
> > wget -P . https://waf.io/${SOEM_WAF}
> > chmod u+x ${SOEM_WAF}
> > git submodule init
> > git submodule update
> > else
> > ./${SOEM_WAF} distclean
> > fi
> > cd ${RTEMS_SB}/rtems
> > RTEMS_SB_DEBUG="--no-clean --jobs=1"
> > # Now configure to build SOEM.
> > # This will fail with:
> ${RTEMS_SB_BUILD}soem-${RTEMS_ARCH}-rtems${RTEMS_VER}-1/soem/oshw/rtems/nicdrv.c:37:10:
> > # fatal error: net/bpf.h: No such file or directory
> > if ${RTEMS_SB}/source-builder/sb-set-builder \
> > --log=log_${RTEMS_ARCH}_soem \
> > --prefix=${RTEMS_TOOLS} \
> > --with-tools=${RTEMS_TOOLS} \
> > --host=${RTEMS_ARCH}-rtems${RTEMS_VER} \
> > --with-rtems-bsp=${RTEMS_BSP} \
> > ${RTEMS_SB_DEBUG} \
> > net/soem ; \
> > then
> > echo 2>&1 "*************************"
> > echo 2>&1 "************************* Success with sb-set-builder
> for net/soem? But I expect failure!"
> > exit 1
> > else
> > echo "*************************"
> > echo "************************* sb-set-builder failed because it
> can't find <net/bpf.h>. Build again..."
> > fi
> > # Now we can manually do the build to finish the build.
> > # This won't quite work either, because it installs SOEM in the wrong
> place.
> > ${RTEMS_SB_BUILD}/soem-${RTEMS_ARCH}-rtems${RTEMS_VER}-1/do-build
> > echo "************************* Finished do-build but it installed in
> the wrong place. Redo install..."
> > # so to finish up and install properly in the prefix
> > # I need to do another "make install" in the build-xc directory.
> > cd ${RTEMS_SB_BUILD}/soem-${RTEMS_ARCH}-rtems${RTEMS_VER}-1/build-xc/
> > make install
> > # SOEM is "installed". Now I can build the RTEMS SOEM examples.
> > echo "************************* XXX Why do I need to set LDFLAGS to
> ${LDFLAGS} before the ./${SOEM_WAF} configure?"
> > ./${SOEM_WAF} configure \
> > --rtems-bsps=${RTEMS_ARCH}/${RTEMS_BSP} \
> > --rtems-version=${RTEMS_VER}
> > ./${SOEM_WAF}
> > echo "************************* Done!"
> > Peter
> > Peter Dufault
> > HD Associates, Inc. Software and System Engineering
> > This email is delivered through the public internet using protocols
> subject to interception and tampering.
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210526/65048cb5/attachment.html>
