[PATCH v4] sb: Merge mailer changes from rtems-tools
Alex White
alex.white at oarcorp.com
Thu May 27 15:59:24 UTC 2021
On Wed, May 26, 2021 at 7:39 PM Chris Johns <chrisj at rtems.org> wrote:
> On 12/5/21 3:19 am, Alex White wrote:
> > This adds the improved mailer.py script from rtems-tools.
> > Closes #4388
> > source-builder/sb/mailer.py | 194 ++++++++++++++++++++++++++------
> > source-builder/sb/options.py | 26 ++++-
> > source-builder/sb/setbuilder.py | 2 +
> > 3 files changed, 189 insertions(+), 33 deletions(-)
> > diff --git a/source-builder/sb/mailer.py b/source-builder/sb/mailer.py
> > index ff25df5..aafe6d6 100644
> > --- a/source-builder/sb/mailer.py
> > +++ b/source-builder/sb/mailer.py
> > @@ -1,21 +1,33 @@
> > # RTEMS Tools Project (http://www.rtems.org/)
> > -# Copyright 2013 Chris Johns (chrisj at rtems.org)
> > +# Copyright 2013-2016 Chris Johns (chrisj at rtems.org)
> > +# Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
> > # All rights reserved.
> > # This file is part of the RTEMS Tools package in 'rtems-tools'.
> > -# Permission to use, copy, modify, and/or distribute this software for any
> > -# purpose with or without fee is hereby granted, provided that the above
> > -# copyright notice and this permission notice appear in all copies.
> > +# Redistribution and use in source and binary forms, with or without
> > +# modification, are permitted provided that the following conditions are met:
> > +# 1. Redistributions of source code must retain the above copyright notice,
> > +# this list of conditions and the following disclaimer.
> > +# 2. Redistributions in binary form must reproduce the above copyright notice,
> > +# this list of conditions and the following disclaimer in the documentation
> > +# and/or other materials provided with the distribution.
> > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> > +# POSSIBILITY OF SUCH DAMAGE.
> > -# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
> > -# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
> > -# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
> > -# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
> > -# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
> > -# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
> > -# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
> > # Manage emailing results or reports.
> > @@ -28,18 +40,72 @@ import smtplib
> > import socket
> > from . import error
> > +from . import execute
> > from . import options
> > from . import path
> > +_options = {
> > + '--mail' : 'Send email report or results.',
> > + '--use-gitconfig': 'Use mail configuration from git config.',
> > + '--mail-to' : 'Email address to send the email to.',
> > + '--mail-from' : 'Email address the report is from.',
> > + '--smtp-host' : 'SMTP host to send via.',
> > + '--smtp-port' : 'SMTP port to send via.',
> > + '--smtp-user' : 'User for SMTP authentication.',
> > + '--smtp-password': 'Password for SMTP authentication.'
> > def append_options(opts):
> > - opts['--mail'] = 'Send email report or results.'
> > - opts['--smtp-host'] = 'SMTP host to send via.'
> > - opts['--mail-to'] = 'Email address to send the email too.'
> > - opts['--mail-from'] = 'Email address the report is from.'
> > + for o in _options:
> > + opts[o] = _options[o]
> > +def add_arguments(argsp):
> > + argsp.add_argument('--mail', help = _options['--mail'], action = 'store_true')
> > + argsp.add_argument('--use-gitconfig', help = _options['--use-gitconfig'], action = 'store_true')
> > + no_add = ['--mail', '--use-gitconfig']
> > + for o in [opt for opt in list(_options) if opt not in no_add]:
> > + argsp.add_argument(o, help = _options[o], type = str)
> > class mail:
> > def __init__(self, opts):
> > self.opts = opts
> > + self.gitconfig_lines = None
> > + if opts.find_arg('--use-gitconfig') is not None:
> > + # Read the output of `git config --list` instead of reading the
> > + # .gitconfig file directly because Python 2 ConfigParser does not
> > + # accept tabs at the beginning of lines.
> > + e = execute.capture_execution()
> > + exit_code, proc, output = e.open('git config --list', shell=True)
> > + if exit_code == 0:
> > + self.gitconfig_lines = output.split(os.linesep)
> > + def _args_are_macros(self):
> > + return isinstance(self.opts, options.command_line)
> > + def _get_arg(self, arg):
> > + if self._args_are_macros():
> > + value = self.opts.find_arg(arg)
> > + if value is not None:
> > + value = self.opts.find_arg(arg)[1]
> > + else:
> > + if arg.startswith('--'):
> > + arg = arg[2:]
> > + arg = arg.replace('-', '_')
> > + if arg in vars(self.opts):
> > + value = vars(self.opts)[arg]
> > + else:
> > + value = None
> > + return value
> > + def _get_from_gitconfig(self, variable_name):
> > + if self.gitconfig_lines is None:
> > + return None
> > + for line in self.gitconfig_lines:
> > + if line.startswith(variable_name):
> > + ls = line.split('=')
> > + if len(ls) >= 2:
> > + return ls[1]
> > def from_address(self):
> > @@ -52,9 +118,15 @@ class mail:
> > l = l[:l.index('\n')]
> > return l.strip()
> > - addr = self.opts.get_arg('--mail-from')
> > + addr = self._get_arg('--mail-from')
> > if addr is not None:
> > - return addr[1]
> > + return addr
> > + addr = self._get_from_gitconfig('user.email')
> > + if addr is not None:
> > + name = self._get_from_gitconfig('user.name')
> > + if name is not None:
> > + addr = '%s <%s>' % (name, addr)
> > + return addr
> > mailrc = None
> > if 'MAILRC' in os.environ:
> > mailrc = os.environ['MAILRC']
> > @@ -63,9 +135,8 @@ class mail:
> > if mailrc is not None and path.exists(mailrc):
> > # set from="Joe Blow <joe at blow.org>"
> > try:
> > - mrc = open(mailrc, 'r')
> > - lines = mrc.readlines()
> > - mrc.close()
> > + with open(mailrc, 'r') as mrc:
> > + lines = mrc.readlines()
> > except IOError as err:
> > raise error.general('error reading: %s' % (mailrc))
> > for l in lines:
> > @@ -76,40 +147,99 @@ class mail:
> > addr = fa[fa.index('=') + 1:].replace('"', ' ').strip()
> > return addr
> > - addr = self.opts.defaults.get_value('%{_sbgit_mail}')
> > + addr = self.opts.defaults.get_value('%{_sbgit_mail}')
> > + else:
> > + raise error.general('no valid from address for mail')
> > return addr
> > def smtp_host(self):
> > - host = self.opts.get_arg('--smtp-host')
> > + host = self._get_arg('--smtp-host')
> > if host is not None:
> > - return host[1]
> > - host = self.opts.defaults.get_value('%{_mail_smtp_host}')
> > + return host
> > + host = self._get_from_gitconfig('sendemail.smtpserver')
> > + if host is not None:
> > + return host
> > + host = self.opts.defaults.get_value('%{_mail_smtp_host}')
> > return host
> > return 'localhost'
> > + def smtp_port(self):
> > + port = self._get_arg('--smtp-port')
> > + if port is not None:
> > + return port
> > + port = self._get_from_gitconfig('sendemail.smtpserverport')
> > + return port
> > + port = self.opts.defaults.get_value('%{_mail_smtp_port}')
> > + return port
> > + def smtp_user(self):
> > + user = self._get_arg('--smtp-user')
> > + if user is not None:
> > + return user
> > + user = self._get_from_gitconfig('sendemail.smtpuser')
> > + return user
> > + def smtp_password(self):
> > + password = self._get_arg('--smtp-password')
> > + if password is not None:
> > + return password
> > + password = self._get_from_gitconfig('sendemail.smtppass')
> > + return password
> > def send(self, to_addr, subject, body):
> > from_addr = self.from_address()
> > msg = "From: %s\r\nTo: %s\r\nSubject: %s\r\n\r\n" % \
> > (from_addr, to_addr, subject) + body
> > - if type(to_addr) is str:
> > - to_addr = to_addr.split(',')
> > - if type(to_addr) is not list:
> > - raise error.general('invalid to_addr type')
> > + port = self.smtp_port()
> > try:
> > - s = smtplib.SMTP(self.smtp_host())
> > - s.sendmail(from_addr, to_addr, msg)
> > + s = smtplib.SMTP(self.smtp_host(), port, timeout=10)
> > + password = self.smtp_password()
> > + # If a password is provided, assume that authentication is required.
> > + user = self.smtp_user()
> > + if user is None:
> > + user = from_addr
> > + s.starttls()
> > + s.login(user, password)
> > + s.sendmail(from_addr, [to_addr], msg)
> > except smtplib.SMTPException as se:
> > raise error.general('sending mail: %s' % (str(se)))
> > except socket.error as se:
> > + def send_file_as_body(self, to_addr, subject, name, intro = None):
> > + try:
> > + with open(name, 'r') as f:
> > + body = f.readlines()
> > + except IOError as err:
> > + raise error.general('error reading mail body: %s' % (name))
> > + if intro is not None:
> > + body = intro + body
> > + self.send(to_addr, from_addr, body)
> What is this call for?
This function is brought over from the rtems-tools mailer.py script. It appears that it is unused both in this repo and in rtems-tools as well:
$ grep -r send_file_as_body .
./rtemstoolkit/mailer.py: def send_file_as_body(self, to_addr, subject, name, intro = None):
Would you like me to remove it from both?
Alex
> Chris
> > if __name__ == '__main__':
> > import sys
> > + from . import macros
> > optargs = {}
> > + rtdir = 'source-builder'
> > + defaults = '%s/defaults.mc' % (rtdir)
> > append_options(optargs)
> > - opts = options.load(sys.argv, optargs = optargs, defaults = 'defaults.mc')
> > + opts = options.command_line(base_path = '.',
> > + argv = sys.argv,
> > + optargs = optargs,
> > + defaults = macros.macros(name = defaults, rtdir = rtdir),
> > + command_path = '.')
> > + options.load(opts)
> > m = mail(opts)
> > print('From: %s' % (m.from_address()))
> > print('SMTP Host: %s' % (m.smtp_host()))
> > - m.send(m.from_address(), 'Test mailer.py', 'This is a test')
> > + if '--mail' in sys.argv:
> > + m.send(m.from_address(), 'Test mailer.py', 'This is a test')
> > diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
> > index d6bffd0..a0f196b 100644
> > --- a/source-builder/sb/options.py
> > +++ b/source-builder/sb/options.py
> > @@ -517,6 +517,15 @@ class command_line:
> > return None
> > return self.parse_args(arg)
> > + def find_arg(self, arg):
> > + if self.optargs is None or arg not in self.optargs:
> > + raise error.internal('bad arg: %s' % (arg))
> > + for a in self.args:
> > + sa = a.split('=')
> > + if sa[0].startswith(arg):
> > + return sa
> > + return None
> > def with_arg(self, label, default = 'not-found'):
> > # the default if there is no option for without.
> > result = default
> > @@ -582,7 +591,22 @@ class command_line:
> > self.opts['no-install'] = '1'
> > def info(self):
> > - s = ' Command Line: %s%s' % (' '.join(self.argv), os.linesep)
> > + # Filter potentially sensitive mail options out.
> > + filtered_args = [
> > + arg for arg in self.argv
> > + if all(
> > + smtp_opt not in arg
> > + for smtp_opt in [
> > + '--smtp-host',
> > + '--mail-to',
> > + '--mail-from',
> > + '--smtp-user',
> > + '--smtp-password',
> > + '--smtp-port'
> > + s = ' Command Line: %s%s' % (' '.join(filtered_args), os.linesep)
> > s += ' Python: %s' % (sys.version.replace('\n', ''))
> > return s
> > diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
> > index b0e2b23..c8c8fee 100644
> > --- a/source-builder/sb/setbuilder.py
> > +++ b/source-builder/sb/setbuilder.py
> > @@ -695,6 +695,8 @@ def run():
> > 'log' : '',
> > 'reports': [],
> > 'failure': None }
> > + # Request this now to generate any errors.
> > + smtp_host = mail['mail'].smtp_host()
> > to_addr = opts.get_arg('--mail-to')
> > if to_addr is not None:
> > mail['to'] = to_addr[1]
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210527/96f27684/attachment-0001.html>
