[PATCH 2/2] covoar: Store address-to-line info outside of DWARF
Alex White
alex.white at oarcorp.com
Thu May 27 19:01:09 UTC 2021
On Tue, May 25, 2021 at 7:24 PM Chris Johns <chrisj at rtems.org> wrote:
> On 1/5/21 8:01 am, Alex White wrote:
> > This adds the AddressToLineMapper class and supporting classes to
> > assume responsibility of tracking address-to-line information.
> > This allows the DWARF library to properly cleanup all of its resources
> > and leads to significant memory savings.
> > Closes #4383
> > rtemstoolkit/rld-dwarf.cpp | 5 +
> > rtemstoolkit/rld-dwarf.h | 5 +
> > tester/covoar/AddressToLineMapper.cc | 105 +++++++++++++++
> > tester/covoar/AddressToLineMapper.h | 193 +++++++++++++++++++++++++++
> > tester/covoar/ExecutableInfo.cc | 73 +++++-----
> > tester/covoar/ExecutableInfo.h | 11 +-
> > tester/covoar/wscript | 1 +
> > 7 files changed, 351 insertions(+), 42 deletions(-)
> > create mode 100644 tester/covoar/AddressToLineMapper.cc
> > create mode 100644 tester/covoar/AddressToLineMapper.h
> > diff --git a/rtemstoolkit/rld-dwarf.cpp b/rtemstoolkit/rld-dwarf.cpp
> > index 2fce0e4..1eae50c 100644
> > --- a/rtemstoolkit/rld-dwarf.cpp
> > +++ b/rtemstoolkit/rld-dwarf.cpp
> > @@ -1893,6 +1893,11 @@ namespace rld
> > return false;
> > + const addresses& compilation_unit::get_addresses () const
> > + return addr_lines_;
> > functions&
> > compilation_unit::get_functions ()
> > diff --git a/rtemstoolkit/rld-dwarf.h b/rtemstoolkit/rld-dwarf.h
> > index 1210813..eadb50d 100644
> > --- a/rtemstoolkit/rld-dwarf.h
> > +++ b/rtemstoolkit/rld-dwarf.h
> > @@ -707,6 +707,11 @@ namespace rld
> > unsigned int pc_high () const;
> > + * The addresses associated with this compilation unit.
> > + const addresses& get_addresses () const;
> > * Get the source and line for an address. If the address does not match
> > * false is returned the file is set to 'unknown' and the line is set to
> > diff --git a/tester/covoar/AddressToLineMapper.cc b/tester/covoar/AddressToLineMapper.cc
> > new file mode 100644
> > index 0000000..1062fd7
> > --- /dev/null
> > +++ b/tester/covoar/AddressToLineMapper.cc
> > @@ -0,0 +1,105 @@
> > +/*! @file AddressToLineMapper.cc
> > + * @brief AddressToLineMapper Implementation
> > + * This file contains the implementation of the functionality
> > + * of the AddressToLineMapper class.
> > +#include "AddressToLineMapper.h"
> > +namespace Coverage {
> > + uint64_t SourceLine::location() const
> > + return address;
> > + bool SourceLine::is_an_end_sequence() const
> > + return is_end_sequence;
> > + std::string SourceLine::path() const
> > + return *sourceIterator;
> > + uint64_t SourceLine::line() const
> > + return line_num;
> > + void AddressLineRange::addSourceLine(const rld::dwarf::address& address)
> > + auto insertResult = sourcePaths.insert(address.path());
> > + sourceLines.emplace_back(
> > + SourceLine (
> > + address.location(),
> > + insertResult.first,
> > + address.line(),
> > + address.is_an_end_sequence()
> > + const SourceLine* AddressLineRange::getSourceLine(uint32_t address) const
> > + if (address < lowAddress || address > highAddress) {
> > + return nullptr;
> > + const SourceLine* last_line = nullptr;
> > + for (const auto &line : sourceLines) {
> > + if (address <= line.location())
> > + if (address == line.location())
> > + last_line = &line;
> > + break;
> > + return last_line;
> > + void AddressToLineMapper::getSource(
> > + uint32_t address,
> > + std::string& sourceFile,
> > + int& sourceLine
> > + ) const {
> > + sourceFile = "unknown";
> > + sourceLine = -1;
> > + const SourceLine* match = nullptr;
> > + for (const auto &range : addressLineRanges) {
> > + const SourceLine* potential_match = range.getSourceLine(address);
> > + if (potential_match != nullptr) {
> > + if (match == nullptr) {
> > + match = potential_match;
> > + } else if (match->is_an_end_sequence() || !potential_match->is_an_end_sequence()) {
> > + if (match != nullptr) {
> > + sourceFile = match->path();
> > + sourceLine = match->line();
> > + AddressLineRange& AddressToLineMapper::makeRange(
> > + uint32_t low,
> > + uint32_t high
> > + addressLineRanges.emplace_back(
> > + AddressLineRange(low, high)
> > + return addressLineRanges.back();
> > diff --git a/tester/covoar/AddressToLineMapper.h b/tester/covoar/AddressToLineMapper.h
> > index 0000000..ee0a633
> > --- /dev/null
> > +++ b/tester/covoar/AddressToLineMapper.h
> > @@ -0,0 +1,193 @@
> > +/*! @file AddressToLineMapper.h
> > + * @brief AddressToLineMapper Specification
> > + * This file contains the specification of the AddressToLineMapper class.
> > +#ifndef __ADDRESS_TO_LINE_MAPPER_H__
> > +#define __ADDRESS_TO_LINE_MAPPER_H__
> > +#include <cstdint>
> > +#include <set>
> > +#include <string>
> > +#include <vector>
> > +#include <rld-dwarf.h>
> > + /*! @class SourceLine
> > + * This class stores source information for a specific address.
> > + class SourceLine {
> > + public:
> > + SourceLine(
> > + uint64_t addr,> + std::set<std::string>::const_iterator src,
> Why not just pass in a reference to the object the iterator references? You do
> not touch the iterator which is a good thing because the iterator held in the
> object is a copy of a copy of the outside iterator.
Good point. I will change it to accept a const reference to a std::string.
> > + int64_t ln,
> > + bool end_sequence
> > + ) : address(addr),
> > + sourceIterator(src),
> > + line_num(ln),
> > + is_end_sequence(end_sequence)
> > + * This method gets the address of this source information.
> > + * @return Returns the address of this source information
> > + uint64_t location() const;
> > + * This method gets a value indicating whether this address represents an
> > + * end sequence.
> > + * @return Returns whether this address represents an end sequence or not
> > + bool is_an_end_sequence() const;
> > + * This method gets the source file path of this address.
> > + * @return Returns the source file path of this address
> > + std::string path() const;
> > + * This method gets the source line number of this address.
> > + * @return Returns the source line number of this address
> > + uint64_t line() const;
> Why not `unsigned int` or `size_t`?
Actually I'm seeing now that the line is always set as the result of a call to
`rld::dwarf::address::line()` which returns an `int`. The `rld::dwarf::address`
class, however, stores the line number as an `int64_t`. So maybe this should use
`int64_t`, and `rld::dwarf::address::line()` should be modified to return
`int64_t` or the equivalent `rld::dwarf::dwarf_signed`. Would that be
acceptable?
> > + private:
> > + * The address of this source information.
> > + uint64_t address;
> > + * An iterator pointing to the location in the set that contains the
> > + * source file path of the address.
> > + std::set<std::string>::const_iterator sourceIterator;
> Would `const std::string& path_;` work ?
Yes. I will change it.
> > + * The source line number of the address.
> > + int64_t line_num;
> > + * Whether the address represents an end sequence or not.
> > + bool is_end_sequence;
> > + /*! @class AddressLineRange
> > + * This class stores source information for an address range.
> > + class AddressLineRange {
> > + public:
> > + AddressLineRange(
> > + uint32_t low,
> > + uint32_t high
> > + ) : lowAddress(low), highAddress(high)
> > + * This method adds source and line information for a specified address.
> > + * @param[in] address specifies the DWARF address information
> > + void addSourceLine(const rld::dwarf::address& address);
> > + * This method gets the source file name and line number for a given
> > + * address.
> > + * @param[in] address specifies the address to look up
> > + * @return Returns the source information for the specified address or
> > + * nullptr if not found.
> > + const SourceLine* getSourceLine(uint32_t address) const;
> Why a pointer? Returning `nullptr` is a potential source of bugs where the
> pointer is not checked. All you have done is encoded an address and a state in
> the one variable, something that is done in C.
> An `operator[](uint32_t address)` could be used here that throws an exception on
> an invalid address. You just need to catch the exception in
> `AddressToLineMapper::getSource()` and make `match` be in instance. Just add a
> default constructor to SourceLine with the path set to "uknown" and line to
> "-1". This however means you need to make the change to not use an iterator as a
> reference. It seems the choice to use the iterator in the class has cascaded out
> into other areas.
You're right. The pointer can be avoided. I will make this change.
> > + private:
> > + * The low address for this range.
> > + uint32_t lowAddress;
> > + * The high address for this range.
> > + uint32_t highAddress;
> > + * The source information for addresses in this range.
> > + std::vector<SourceLine> sourceLines;
> > + * The set of source file names for this range.
> > + std::set<std::string> sourcePaths;
> I always add a local class/struct typedef for containers.
> > + /*! @class AddressToLineMapper
> > + * This class provides address-to-line capabilities.
> > + class AddressToLineMapper {
> > + public:
> > + * address.
> > + * @param[out] sourceFile specifies the name of the source file
> > + * @param[out] sourceLine specifies the line number in the source file
> > + void getSource(
> > + uint32_t address,
> > + int& sourceLine
> > + ) const;
> > + * This method creates a new range with the specified addresses.
> > + * @param[in] low specifies the low address of the range
> > + * @param[in] high specifies the high address of the range
> > + * @return Returns a reference to the newly created range
> > + AddressLineRange& makeRange(uint32_t low, uint32_t high);
> > + private:
> > + * The address and line information ranges.
> > + std::vector<AddressLineRange> addressLineRanges;
> Why is this private? :)
It is private because it does not need to be public. :)
Alex
> Chris
> > +#endif
> > diff --git a/tester/covoar/ExecutableInfo.cc b/tester/covoar/ExecutableInfo.cc
> > index 861e60d..a6184e7 100644
> > --- a/tester/covoar/ExecutableInfo.cc
> > +++ b/tester/covoar/ExecutableInfo.cc
> > @@ -40,61 +40,60 @@ namespace Coverage {
> > executable.begin();
> > executable.load_symbols(symbols);
> > + rld::dwarf::file debug;
> > debug.begin(executable.elf());
> > debug.load_debug();
> > debug.load_functions();
> > - try {
> > - for (auto& cu : debug.get_cus()) {
> > - for (auto& func : cu.get_functions()) {
> > - if (!func.has_machine_code()) {
> > - continue;
> > + for (auto& cu : debug.get_cus()) {
> > + AddressLineRange& range = mapper.makeRange(cu.pc_low(), cu.pc_high());
> > + // Does not filter on desired symbols under the assumption that the test
> > + // code and any support code is small relative to what is being tested.
> > + for (const auto &address : cu.get_addresses()) {
> > + range.addSourceLine(address);
> > - if (!SymbolsToAnalyze->isDesired(func.name())) {
> > - continue;
> > + for (auto& func : cu.get_functions()) {
> > + if (!func.has_machine_code()) {
> > + continue;
> > + if (!SymbolsToAnalyze->isDesired(func.name())) {
> > + continue;
> > + if (func.is_inlined()) {
> > + if (func.is_external()) {
> > + // Flag it
> > + std::cerr << "Function is both external and inlined: "
> > + << func.name() << std::endl;
> > - if (func.is_inlined()) {
> > - if (func.is_external()) {
> > - // Flag it
> > - std::cerr << "Function is both external and inlined: "
> > - << func.name() << std::endl;
> > - if (func.has_entry_pc()) {
> > - continue;
> > - // If the low PC address is zero, the symbol does not appear in
> > - // this executable.
> > - if (func.pc_low() == 0) {
> > - continue;
> > + if (func.has_entry_pc()) {
> > + continue;
> > - // We can't process a zero size function.
> > - if (func.pc_high() == 0) {
> > + // If the low PC address is zero, the symbol does not appear in
> > + // this executable.
> > + if (func.pc_low() == 0) {
> > continue;
> > - createCoverageMap (cu.name(), func.name(),
> > - func.pc_low(), func.pc_high() - 1);
> > + // We can't process a zero size function.
> > + if (func.pc_high() == 0) {
> > + continue;
> > + createCoverageMap (cu.name(), func.name(),
> > + func.pc_low(), func.pc_high() - 1);
> > - } catch (...) {
> > - debug.end();
> > - throw;
> > - // Can't cleanup handles until the destructor because the information is
> > - // referenced elsewhere. NOTE: This could cause problems from too many open
> > - // file descriptors.
> > ExecutableInfo::~ExecutableInfo()
> > - debug.end();
> > void ExecutableInfo::dumpCoverageMaps( void ) {
> > @@ -197,7 +196,7 @@ namespace Coverage {
> > std::string file;
> > int lno;
> > - debug.get_source (address, file, lno);
> > + mapper.getSource (address, file, lno);
> > std::ostringstream ss;
> > ss << file << ':' << lno;
> > line = ss.str ();
> > diff --git a/tester/covoar/ExecutableInfo.h b/tester/covoar/ExecutableInfo.h
> > index 5d5a595..dfc71aa 100644
> > --- a/tester/covoar/ExecutableInfo.h
> > +++ b/tester/covoar/ExecutableInfo.h
> > @@ -15,6 +15,7 @@
> > #include <rld-files.h>
> > #include <rld-symbols.h>
> > #include "CoverageMapBase.h"
> > #include "SymbolTable.h"
> > @@ -157,11 +158,6 @@ namespace Coverage {
> > - * The DWARF data to the ELF executable.
> > - rld::dwarf::file debug;
> > * The executable's file name.
> > @@ -172,6 +168,11 @@ namespace Coverage {
> > rld::symbols::table symbols;
> > + * The address-to-line mapper for this executable.
> > + AddressToLineMapper mapper;
> > * This map associates a symbol with its coverage map.
> > diff --git a/tester/covoar/wscript b/tester/covoar/wscript
> > index 82599b0..a928b1b 100644
> > --- a/tester/covoar/wscript
> > +++ b/tester/covoar/wscript
> > @@ -83,6 +83,7 @@ def build(bld):
> > bld.stlib(target = 'ccovoar',
> > source = ['app_common.cc',
> > + 'AddressToLineMapper.cc',
> > 'CoverageFactory.cc',
> > 'CoverageMap.cc',
> > 'CoverageMapBase.cc',
> devel mailing list
> devel at rtems.org
Sent: Tuesday, May 25, 2021 7:24 PM
To: Alex White <alex.white at oarcorp.com>; devel at rtems.org <devel at rtems.org>
Subject: Re: [PATCH 2/2] covoar: Store address-to-line info outside of DWARF
> Closes #4383
> return false;
> functions&
> --- /dev/null
> @@ -0,0 +1,105 @@
> + return address;
> + return line_num;
> + SourceLine (
> + address.line(),
> + return nullptr;
> + break;
> + return last_line;
> + uint32_t address,
> + int& sourceLine
> + ) const {
> + sourceLine = -1;
> + uint32_t low,
> + uint32_t high
> --- /dev/null
> @@ -0,0 +1,193 @@
> +#include <cstdint>
> +#include <set>
> +#include <string>
> +#include <vector>
> + public:
> + SourceLine(
> + int64_t ln,
> + bool end_sequence
> + line_num(ln),
> + * end sequence.
> + private:
> + uint64_t address;
> + int64_t line_num;
> + public:
> + AddressLineRange(
> + uint32_t low,
> + uint32_t high
> + * address.
into other areas.
> + private:
> + public:
> + * address.
> + void getSource(
> + uint32_t address,
> + int& sourceLine
> + ) const;
> + private:
> +#endif
> executable.begin();
> debug.load_debug();
> - try {
> - continue;
> - continue;
> + continue;
> + continue;
> + // Flag it
> - // Flag it
> - continue;
> - continue;
> + continue;
> continue;
> + continue;
> - } catch (...) {
> - debug.end();
> - throw;
> - debug.end();
> std::string file;
> int lno;
> line = ss.str ();
> @@ -15,6 +15,7 @@
> 'CoverageMap.cc',
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210527/8995f2f2/attachment-0001.html>
