[PATCH] c-users: Add rtems_*mutex_try_lock
Fri May 28 02:31:23 UTC 2021
looks alright to me.
On Wed, May 26, 2021 at 3:34 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
>  c-user/self_contained_objects.rst | 35 +++++++++++++++++++++++++++++++
>  1 file changed, 35 insertions(+)
> diff --git a/c-user/self_contained_objects.rst b/c-user/self_contained_objects.rst
> index 0be1423..3351b98 100644
> --- a/c-user/self_contained_objects.rst
> +++ b/c-user/self_contained_objects.rst
> @@ -132,6 +132,10 @@ copies of the object in calls to
>  * :c:func:`rtems_recursive_mutex_lock`,
> +* :c:func:`rtems_mutex_try_lock`,
> +* :c:func:`rtems_recursive_mutex_try_lock`,
>  * :c:func:`rtems_mutex_unlock`,
>  * :c:func:`rtems_recursive_mutex_unlock`,
> @@ -262,6 +266,37 @@ NOTES:
>      \clearpage
> +Try to lock the mutex
> +CALLING SEQUENCE:
> +    .. code-block:: c
> +        void rtems_mutex_try_lock(
> +          rtems_mutex *mutex
> +        void rtems_recursive_mutex_try_lock(
> +          rtems_recursive_mutex *mutex
> +DESCRIPTION:
> +    Tries to lock the ``mutex``. In case the mutex is not locked, it will be
> +    locked and the function returns with a return value of ``0``. If the mutex
> +    is already locked, the function will return with a value of ``EBUSY``.
> +NOTES:
> +    This function must be called from thread context with interrupts enabled.
> +    For recursively locking a mutex, please also see the notes for
> +    :c:func:`rtems_mutex_lock` and :c:func:`rtems_recursive_mutex_lock`.
> +    Each mutex lock operation must have a corresponding unlock operation.
> +.. raw:: latex
> +    \clearpage
>  Unlock the mutex
> 2.26.2
> devel mailing list
> devel at rtems.org
