[PATCH v1 3/4] objectextendinformation.c: Ensure information->object_blocks is not NULL
Ryan Long
ryan.long at oarcorp.com
Fri May 28 19:11:24 UTC 2021
CID 26033: Dereference after null check in _Objects_Extend_information().
Closes #4326
cpukit/score/src/objectextendinformation.c | 11 +++++++++++
1 file changed, 11 insertions(+)
diff --git a/cpukit/score/src/objectextendinformation.c b/cpukit/score/src/objectextendinformation.c
index 9796eb9..c669301 100644
--- a/cpukit/score/src/objectextendinformation.c
+++ b/cpukit/score/src/objectextendinformation.c
@@ -171,6 +171,17 @@ Objects_Maximum _Objects_Extend_information(
if ( old_maximum > extend_count ) {
+ * Coverity thinks there is a way for this to be NULL (CID #26033).
+ * After much time spent analyzing this, no one has identified the
+ * conditions where this can actually occur. Adding this _Assert ensures
+ * that it is never NULL. If this assert is triggered, condition
+ * generating this case will have been identified and it can be revisted.
+ * This is being done out of an abundance of caution since we could have
+ * easily flagged this as a false positive and ignored it completely.
+ _Assert(information->object_blocks != NULL);
* Copy each section of the table over. This has to be performed as
* separate parts as size of each block has changed.
1.8.3.1
