[PATCH v1 1/6] Explanations.cc: Fix resource leaks
    Ryan Long
    ryan.long at oarcorp.com
    Fri May 28 20:08:13 UTC 2021
CID 1399608: Resource leak in load().
CID 1399611: Resource leak in load().
Closes #4417
 tester/covoar/Explanations.cc | 18 +++++++++++-------
 1 file changed, 11 insertions(+), 7 deletions(-)
diff --git a/tester/covoar/Explanations.cc b/tester/covoar/Explanations.cc
index 12bd809..d94cd2e 100644
--- a/tester/covoar/Explanations.cc
+++ b/tester/covoar/Explanations.cc
@@ -32,7 +32,7 @@ namespace Coverage {
     #define MAX_LINE_LENGTH 512
     FILE       *explain;
     char        *cStatus;
-    Explanation *e;
+    Explanation  e;
     int          line = 1;
     if (!explanations)
@@ -46,7 +46,6 @@ namespace Coverage {
     while ( 1 ) {
-      e = new Explanation;
       // Read the starting line of this explanation and
       // skip blank lines between
       do {
@@ -65,12 +64,13 @@ namespace Coverage {
         what << "line " << line
              << "contains a duplicate explanation ("
              << inputBuffer << ")";
+        fclose( explain );
         throw rld::error( what, "Explanations::load" );
       // Add the starting line and file
-      e->startingPoint = std::string(inputBuffer);
-      e->found = false;
+      e.startingPoint = std::string(inputBuffer);
+      e.found = false;
       // Get the classification
       cStatus = fgets( inputBuffer, MAX_LINE_LENGTH, explain );
@@ -78,10 +78,11 @@ namespace Coverage {
         std::ostringstream what;
              << "out of sync at the classification";
       inputBuffer[ strlen(inputBuffer) - 1] = '\0';
-      e->classification = inputBuffer;
+      e.classification = inputBuffer;
       line++;
       // Get the explanation
@@ -92,6 +93,7 @@ namespace Coverage {
                << "out of sync at the explanation";
@@ -102,15 +104,17 @@ namespace Coverage {
           break;
         // XXX only taking last line.  Needs to be a vector
-        e->explanation.push_back( inputBuffer );
+        e.explanation.push_back( inputBuffer );
       // Add this to the set of Explanations
-      set[ e->startingPoint ] = *e;
+      set[ e.startingPoint ] = e;
 done:
     #undef MAX_LINE_LENGTH
1.8.3.1
