[PATCH rtems-docs] eng/vc-authors: Add section on migrating personal repo to top-level
Vijay Kumar Banerjee
vijay at rtems.org
Sun May 30 21:11:49 UTC 2021
eng/vc-authors.rst | 46 ++++++++++++++++++++++++++++++++++++++++++++++
1 file changed, 46 insertions(+)
diff --git a/eng/vc-authors.rst b/eng/vc-authors.rst
index dcbbeb9..179ad08 100644
--- a/eng/vc-authors.rst
+++ b/eng/vc-authors.rst
@@ -166,6 +166,52 @@ flag to prevent merge from issuing an automatic merge commit message.
When you have committed changes on a branch that is public/shared with another
developer you should not rebase that branch.
+Migrate a Personal Repository to top-level
+Once a project is production ready in the personal repository, it's time to
+migrate it to the top-level RTEMS git directory. First, the project directory
+needs to be copied and then the permissions need to be set, so that everyone can
+push into that repository.
+.. code-block:: shell
+ cp -R /data/git/user/my-rtems-project.git /data/git
+ cd /data/git/my-rtems-project.git
+ chgrp -R gitrw ./
+ chmod -R g+rws ./
+Then copy the post-receive script from the rtems.git directory and change the
+name of REPO.
+ cp /data/git/rtems.git/hooks/post-receive /data/git/my-rtems-project.git/hooks/
+After making the change the post-receive script in the new repository should
+look like this
+ #!/bin/sh
+ # The "post-receive" script is run after receive-pack has accepted a pack
+ # and the repository has been updated. It is passed arguments in through
+ # stdin in the form
+ # <oldrev> <newrev> <refname>
+ # For example:
+ # aa453216d1b3e49e7f6f98441fa56946ddcd6a20 68f7abf4e6f922807889f52bc043ecd31b79f814 refs/heads/master
+ REPO=my-rtems-project
+ . /data/support/git-support/hooks/post-receive-0
+ . /data/support/git-support/hooks/post-receive-1
+ #. /data/support/git-support/hooks/post-receive-2
+ . /data/support/git-support/hooks/post-receive-3
+ . /data/support/git-support/hooks/post-receive-4
+ . /data/support/git-support/hooks/post-receive-5
GIT Push Configuration
2.26.2
