[PATCH rtems-docs] cpu-supplement: Update AArch64 SMP details
Kinsey Moore
kinsey.moore at oarcorp.com
Mon Nov 1 18:54:20 UTC 2021
AArch64 now supports SMP for the Xilinx ZynqMP BSP family.
cpu-supplement/aarch64.rst | 6 ++++--
1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/cpu-supplement/aarch64.rst b/cpu-supplement/aarch64.rst
index a102817..2b3d620 100644
--- a/cpu-supplement/aarch64.rst
+++ b/cpu-supplement/aarch64.rst
@@ -9,7 +9,7 @@ This chapter discusses the dependencies of the
*ARM AArch64 architecture*
(https://en.wikipedia.org/wiki/ARM_architecture#AArch64_features) in this port
of RTEMS. The ARMv8-A versions are supported by RTEMS. Processors with a MMU
-use a static configuration which is set up during system start. SMP is not
+use a static configuration which is set up during system start. SMP is
supported.
**Architecture Documents**
@@ -124,7 +124,9 @@ actions:
Symmetric Multiprocessing
-SMP is not currently supported on ARMv8-A.
+SMP is supported on ARMv8-A. Available platforms are:
+- Xilinx ZynqMP (QEMU and hardware using PSCI via ARM Trusted Firmware)
Thread-Local Storage
2.30.2
