[PATCH RSB v3] rtems-kernel: Implement kernel recipe using waf
Ryan Long ryan.long at oarcorp.com
Thu Nov 4 14:31:08 UTC 2021
Closes #4145
 rtems/config/tools/rtems-kernel-6.cfg       |   6 +-
 rtems/config/tools/rtems-kernel-common.cfg  | 125 +++++++++++------------
 source-builder/sb/rtems-kernel-config-check | 147 ++++++++++++++++++++++++++++
 3 files changed, 215 insertions(+), 63 deletions(-)
 create mode 100755 source-builder/sb/rtems-kernel-config-check
diff --git a/rtems/config/tools/rtems-kernel-6.cfg b/rtems/config/tools/rtems-kernel-6.cfg
index f1d0990..9120862 100644
--- a/rtems/config/tools/rtems-kernel-6.cfg
+++ b/rtems/config/tools/rtems-kernel-6.cfg
@@ -2,10 +2,10 @@
 # RTEMS 5
-%define rtems_kernel_version 3ec5f20484cc4201e1d7b87844505644533b6148
-%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
-              BjMKrf5n1YR6IpiZrY5TUEzKATPRJxA2/6m6f833DdRu+RyLxccXqA4gHRdVUqFelFNQ3o0XdG4o1naBKYfhkQ==
+%define rtems_kernel_version 3bb97a30b17b6c138dead3e3a6b329c3b301cdb3
+%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.gz \
+              m/ogwrJj4X60ewDIbV6WRj1MJa/22gQHQd56XiNMfvCr0nsvcXdkXKAObLIGYIGYfUyEwlVk3SRjjRFkFalDGQ==
 # The RTEMS build instructions.
diff --git a/rtems/config/tools/rtems-kernel-common.cfg b/rtems/config/tools/rtems-kernel-common.cfg
index 157c7a4..431fc1d 100644
--- a/rtems/config/tools/rtems-kernel-common.cfg
+++ b/rtems/config/tools/rtems-kernel-common.cfg
@@ -9,7 +9,7 @@
 # and BSPs. Only after the source to download.
 %if %{_dry_run} && %{defined with_download}
- %log Kenrel configuration errors ignored
+ %log Kernel configuration errors ignored
  %define rtems_kernel_error 0
 %else
  %define rtems_kernel_error 1
@@ -19,10 +19,15 @@
  %define rtems_kernel_version %{rsb_version}
 %endif
+%if %{defined with_rtems_bsp_config}
+ %define _target %(%{_sbdir}/sb/rtems-kernel-config-check -v %{rtems_version} -t %{with_rtems_bsp_config})
+ %define rtems_bsp %(%{_sbdir}/sb/rtems-kernel-config-check -b %{with_rtems_bsp_config})
+%endif
 # The target. It could be set in rtems_target.
-%if %{defined rtems_target}
+%if %{defined rtems_target} && !%{defined with_rtems_bsp_config}
  %define _target %{rtems_target}
 %endif
 %if %{_target} == %{nil} && %{rtems_kernel_error}
@@ -32,10 +37,21 @@
 # The BSP.
-%if !%{defined with_rtems_bsp} && %{rtems_kernel_error}
+%if !%{defined with_rtems_bsp} && %{rtems_kernel_error} && !%{defined with_rtems_bsp_config}
  %error No RTEMS BSP specified: --with-rtems-bsp=bsp
 %endif
-%define rtems_bsp %{with_rtems_bsp}
+%if !%{defined with_rtems_bsp_config}
+ %define rtems_bsp %{with_rtems_bsp}
+%endif
+# Configuration file used with waf
+%ifn %{defined with_rtems_bsp_config}
+ %define config_file config-%{_target}-%{rtems_bsp}.ini
+%else
+ %define config_file %{with_rtems_bsp_config}
+%endif
 # If no tools are provided use the prefix.
@@ -98,14 +114,6 @@ URL: 	 https://www.rtems.org/
  %define rtems_posix 0
 %endif
-%if %{defined with_rtems_legacy_network}
- %define rtems_networking 1
-%endif
-%if %{defined with_rtems_cxx}
- %define rtems_cxx 1
-%endif
 %if %{defined with_rtems_bspopts}
  %define bspopts %{with_rtems_bspopts}
 %endif
@@ -143,43 +151,43 @@ URL: 	 https://www.rtems.org/
 # --without-rtems-tests          : Supported, forced to no
 # --with-rtems-smp               : Supported
 # --without-rtems-smp            : Don't care
-# --with-rtems-legacy-network    : Supported
+# --with-rtems-legacy-network    : Unsupported
 # --without-rtems-legacy-network : Don't care
-# --with-rtems-bspopts           : Supported, quote for a list
-# --without-rtems-bspopts        : Don't care
 %if %{defined without_rtemsbsp}
  %error Option --without-rtemsbsp is not supported.
 %endif
+%if %{defined with_rtems_legacy_network}
+ echo "RTEMS legacy network has been removed."
+ echo "Please review and update your configuration."
+ exit 1
+%endif
+%if %{defined enable_cxx}
+ echo CXX has been removed."
+ exit 1
+%endif
 %if %{defined without_rtems_tests}
- %define with_rtems_tests no
+ %define rtems_tests False
+ %define rtems_sample_tests False
 %endif
 %if %{defined with_rtems_tests}
  %if %{with_rtems_tests} == 1
-  %define with_rtems_tests yes
+   %define rtems_tests True
+   %define rtems_sample_tests True
  %endif
- %if %{with_rtems_tests} == yes || \
-     %{with_rtems_tests} == no || \
-     %{with_rtems_tests} == samples
-  %define rtems_tests %{with_rtems_tests}
+  %if %{with_rtems_tests} == samples
  %endif
 %endif
 %if %{defined with_rtems_smp}
  %define rtems_smp 1
 %endif
-%endif
  %define rtems_bspopts %{with_rtems_bspopts}
 %endif
-# If C++ defined for the tool set use it to control RTEMS's setting..
-%if %{defined enable_cxx}
- %define rtems_cxx %{enable_cxx}
-%endif
 # Default set up. Override these in a BSP if you want a
@@ -188,14 +196,9 @@ URL: 	 https://www.rtems.org/
 %ifn %{defined rtems_posix}
  %define rtems_posix 1
 %endif
-%ifn %{defined rtems_networking}
- %define rtems_networking 0
-%endif
-%ifn %{defined rtems_cxx}
-%endif
 %ifn %{defined rtems_tests}
- %define rtems_tests samples
 %endif
 %ifn %{defined rtems_bspopts}
  %define rtems_bspopts %{nil}
@@ -213,8 +216,6 @@ URL: 	 https://www.rtems.org/
     %if %{defined _internal_autotools_path}
       export PATH="%{_internal_autotools_path}/bin:${PATH}"
     %endif
-    ./bootstrap -c
-    ./rtems-bootstrap
   %endif
   cd ..
@@ -225,38 +226,42 @@ URL: 	 https://www.rtems.org/
   else
     build_dir="build"
   fi
+  cd ${source_dir_rtems}
+  %if %{defined without_rtems_bsp_config}
+    cpu=`echo %{_target} | cut -d- -f1`
+    echo "[${cpu}/%{rtems_bsp}]" > %{config_file}
+    echo "RTEMS_POSIX_API = %{?rtems_posix:True}%{!?rtems_posix:False}" >> %{config_file}
+    echo "RTEMS_SMP = %{?rtems_smp:True}%{!?rtems_smp:False}" >> %{config_file}
+    echo "BUILD_TESTS = %{rtems_tests}" >> %{config_file}
+    echo "BUILD_SAMPLES = %{rtems_sample_tests}" >> %{config_file}
+  %endif
   mkdir -p ${build_dir}
-  cd ${build_dir}
-  ../${source_dir_rtems}/configure \
-    --build=%{_build} --host=%{_host} \
-    --target=%{_target} \
-    --enable-rtemsbsp="%{rtems_bsp}" \
-    %{?rtems_cxx:--enable-cxx}%{!?rtems_cxx:--disable-cxx} \
-    %{?rtems_posix:--enable-posix}%{!?rtems_posix:--disable-posix} \
-    %{?rtems_networking:--enable-networking}%{!?rtems_networking:--disable-networking} \
-    %{?rtems_tests:--enable-tests=%{rtems_tests}} \
-    %{?rtems_smp:--enable-smp} \
+  ./waf configure \
+    --rtems-bsps=%{_target}/%{rtems_bsp} \
     --prefix=%{_prefix} --bindir=%{_bindir} \
-    --exec-prefix=%{_exec_prefix} \
-    --includedir=%{_includedir} --libdir=%{_libdir} \
-    --mandir=%{_mandir} --infodir=%{_infodir} \
-    %{rtems_bspopts}
+    --rtems-config=%{config_file}
+  ./waf %{?_smp_mflags}
-  %{__make} %{?_smp_mflags} all
   cd ..
 %install
   %{__rmdir} $SB_BUILD_ROOT
-  cd ${build_dir}
-  %{__make} DESTDIR=$SB_BUILD_ROOT install
+  ./waf --destdir=$SB_BUILD_ROOT install
+  echo "rtems_tests: %{rtems_tests}"
-  %if %{rtems_tests} != no
+  %if %{rtems_tests} != False
    %define rtems_test_install %{_target}/%{rtems_bsp}/tests
    mkdir -p $SB_BUILD_ROOT/%{_prefix}/%{rtems_test_install}
    find . -name \*.exe -and -not -name \*.norun.exe \
       -exec cp -v \{\} $SB_BUILD_ROOT/%{_prefix}/%{rtems_test_install}/ \;
   %endif
-  cd ..
+  cd -
diff --git a/source-builder/sb/rtems-kernel-config-check b/source-builder/sb/rtems-kernel-config-check
new file mode 100755
index 0000000..9bdff22
--- /dev/null
+++ b/source-builder/sb/rtems-kernel-config-check
@@ -0,0 +1,147 @@
+#! /usr/bin/env python
+SPDX-License-Identifier: BSD-2-Clause
+COPYRIGHT (C) 2021 On-Line Applications Research Corporation (OAR).
+Redistribution and use in source and binary forms, with or without
+modification, are permitted provided that the following conditions
+are met:
+1. Redistributions of source code must retain the above copyright
+   notice, this list of conditions and the following disclaimer.
+2. Redistributions in binary form must reproduce the above copyright
+   notice, this list of conditions and the following disclaimer in the
+   documentation and/or other materials provided with the distribution.
+THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+POSSIBILITY OF SUCH DAMAGE.
+from __future__ import print_function
+import sys
+import argparse
+from os.path import exists
+try:
+    import ConfigParser
+    configparser = ConfigParser # used for python2
+except ImportError:
+    try:
+        import configparser # used for python3
+    except ImportError:
+        print("Could not import configparser. Exiting...", file = sys.stderr)
+        sys.exit(1)
+def run():
+    parser = argparse.ArgumentParser()
+    parser.add_argument("config", help="path to config file")
+        "-a",
+        "--arch",
+        help="return target architecture specified in the config",
+        action="store_true"
+        "-b",
+        "--bsp",
+        help="return BSP specified in the config",
+        "-c",
+        "--arch-bsp",
+        help="return target architecture and BSP specified in the config",
+        "-v",
+        "--rtems-version",
+        help="version of RTEMS",
+        type=int,
+        default=6
+        "-t",
+        "--target",
+        help="return target (<arch-rtems<rtems-version>)",
+    args = parser.parse_args()
+    config = configparser.ConfigParser()
+    if args.config[-4:] != ".ini":
+        print(
+            "The config file is missing an *.ini extension.",
+            file = sys.stderr
+        sys.exit(1)
+    try:
+        config.read(args.config)
+    except configparser.MissingSectionHeaderError:
+        print(
+            "There is no section header in the config file",
+            file = sys.stderr
+        sys.exit(1)
+    except configparser.ParsingError:
+        print(
+            "An exception occured when parsing the config file",
+            file = sys.stderr
+        sys.exit(1)
+    except:
+        print(
+            "An unknown exception occured",
+            file = sys.stderr
+    if len(config.sections()) != 1:
+        print(
+            "You can only have one arch/bsp section in your config.",
+            file = sys.stderr
+        sys.exit(1)
+    arch_bsp_str = config.sections()[0]
+    if arch_bsp_str.find("/") == -1:
+        print(
+            "arch/bsp section in config is missing '/'",
+            file = sys.stderr
+        sys.exit(1)
+    if ( args.arch or args.bsp) and args.arch_bsp:
+        args.arch = False
+    if args.arch:
+        print(arch_bsp_str.split("/")[0])
+        return
+    if args.bsp:
+        print(arch_bsp_str.split("/")[1])
+        return
+    if args.arch_bsp:
+        print(arch_bsp_str.replace("/", " "))
+        return
+    if args.target:
+        arch = arch_bsp_str.split("/")[0]
+        print(arch + "-rtems" + str(args.rtems_version))
+        return
+if __name__ == "__main__":
+    run()
1.8.3.1
