[PATCH 12/26] Mark more nodes as CTLFLAG_MPSAFE
Sebastian Huber
Mon Nov 8 06:27:40 UTC 2021
or CTLFLAG_NEEDGIANT (17 of many)
r357614 added CTLFLAG_NEEDGIANT to make it easier to find nodes that are
still not MPSAFE (or already are but aren’t properly marked).
Use it in preparation for a general review of all nodes.
This is non-functional change that adds annotations to SYSCTL_NODE and
SYSCTL_PROC nodes using one of the soon-to-be-required flags.
Mark all obvious cases as MPSAFE. All entries that haven't been marked
as MPSAFE before are by default marked as NEEDGIANT
Approved by: kib (mentor, blanket)
Commented by: kib, gallatin, melifaro
Differential Revision: https://reviews.freebsd.org/D23718
cpukit/score/src/kern_tc.c | 37 ++++++++++++++++++++++++-------------
1 file changed, 24 insertions(+), 13 deletions(-)
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index aa7e9b0cb2..16fbb9ba70 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -253,11 +253,16 @@ volatile int32_t time_uptime = 1;
#ifndef __rtems__
static int sysctl_kern_boottime(SYSCTL_HANDLER_ARGS);
-SYSCTL_PROC(_kern, KERN_BOOTTIME, boottime, CTLTYPE_STRUCT|CTLFLAG_RD,
- NULL, 0, sysctl_kern_boottime, "S,timeval", "System boottime");
+SYSCTL_PROC(_kern, KERN_BOOTTIME, boottime,
+ CTLTYPE_STRUCT | CTLFLAG_RD | CTLFLAG_MPSAFE, NULL, 0,
+ sysctl_kern_boottime, "S,timeval",
+ "System boottime");
-SYSCTL_NODE(_kern, OID_AUTO, timecounter, CTLFLAG_RW, 0, "");
-static SYSCTL_NODE(_kern_timecounter, OID_AUTO, tc, CTLFLAG_RW, 0, "");
+SYSCTL_NODE(_kern, OID_AUTO, timecounter, CTLFLAG_RW | CTLFLAG_MPSAFE, 0,
+static SYSCTL_NODE(_kern_timecounter, OID_AUTO, tc,
+ CTLFLAG_RW | CTLFLAG_MPSAFE, 0,
static int timestepwarnings;
SYSCTL_INT(_kern_timecounter, OID_AUTO, stepwarnings, CTLFLAG_RW,
@@ -1354,16 +1359,19 @@ tc_init(struct timecounter *tc)
tc_root = SYSCTL_ADD_NODE_WITH_LABEL(NULL,
SYSCTL_STATIC_CHILDREN(_kern_timecounter_tc), OID_AUTO, tc->tc_name,
- CTLFLAG_RW, 0, "timecounter description", "timecounter");
+ "timecounter description", "timecounter");
SYSCTL_ADD_UINT(NULL, SYSCTL_CHILDREN(tc_root), OID_AUTO,
"mask", CTLFLAG_RD, &(tc->tc_counter_mask), 0,
"mask for implemented bits");
SYSCTL_ADD_PROC(NULL, SYSCTL_CHILDREN(tc_root), OID_AUTO,
- "counter", CTLTYPE_UINT | CTLFLAG_RD, tc, sizeof(*tc),
- sysctl_kern_timecounter_get, "IU", "current timecounter value");
+ "counter", CTLTYPE_UINT | CTLFLAG_RD | CTLFLAG_MPSAFE, tc,
+ sizeof(*tc), sysctl_kern_timecounter_get, "IU",
+ "current timecounter value");
- "frequency", CTLTYPE_U64 | CTLFLAG_RD, tc, sizeof(*tc),
- sysctl_kern_timecounter_freq, "QU", "timecounter frequency");
+ "frequency", CTLTYPE_U64 | CTLFLAG_RD | CTLFLAG_MPSAFE, tc,
+ sizeof(*tc), sysctl_kern_timecounter_freq, "QU",
+ "timecounter frequency");
SYSCTL_ADD_INT(NULL, SYSCTL_CHILDREN(tc_root), OID_AUTO,
"quality", CTLFLAG_RD, &(tc->tc_quality), 0,
"goodness of time counter");
@@ -1718,8 +1726,9 @@ sysctl_kern_timecounter_hardware(SYSCTL_HANDLER_ARGS)
return (EINVAL);
-SYSCTL_PROC(_kern_timecounter, OID_AUTO, hardware, CTLTYPE_STRING | CTLFLAG_RW,
- 0, 0, sysctl_kern_timecounter_hardware, "A",
+SYSCTL_PROC(_kern_timecounter, OID_AUTO, hardware,
+ CTLTYPE_STRING | CTLFLAG_RWTUN | CTLFLAG_NOFETCH | CTLFLAG_MPSAFE, 0, 0,
+ sysctl_kern_timecounter_hardware, "A",
"Timecounter hardware selected");
/* Report the available timecounter hardware. */
@@ -1741,8 +1750,10 @@ sysctl_kern_timecounter_choice(SYSCTL_HANDLER_ARGS)
return (error);
-SYSCTL_PROC(_kern_timecounter, OID_AUTO, choice, CTLTYPE_STRING | CTLFLAG_RD,
- 0, 0, sysctl_kern_timecounter_choice, "A", "Timecounter hardware detected");
+SYSCTL_PROC(_kern_timecounter, OID_AUTO, choice,
+ CTLTYPE_STRING | CTLFLAG_RD | CTLFLAG_MPSAFE, 0, 0,
+ sysctl_kern_timecounter_choice, "A",
+ "Timecounter hardware detected");
#endif /* __rtems__ */
#ifndef __rtems__
2.31.1
