[PATCH 20/26] timecounter: Lock the timecounter list
Sebastian Huber
Mon Nov 8 06:27:48 UTC 2021
Timecounter registration is dynamic, i.e., there is no requirement that
timecounters must be registered during single-threaded boot. Loadable
drivers may in principle register timecounters (which can be switched to
automatically). Timecounters cannot be unregistered, though this could
be implemented.
Registered timecounters belong to a global linked list. Add a mutex to
synchronize insertions and the traversals done by (mpsafe) sysctl
handlers. No functional change intended.
Reviewed by: imp, kib
MFC after: 2 weeks
Sponsored by: The FreeBSD Foundation
Differential Revision: https://reviews.freebsd.org/D32511
cpukit/score/src/kern_tc.c | 40 ++++++++++++++++++++++++++++----------
1 file changed, 30 insertions(+), 10 deletions(-)
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index e8c773a890..d8f92e11dd 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -199,6 +199,10 @@ static struct timehands *volatile timehands = &ths[0];
struct timecounter *timecounter = &dummy_timecounter;
static struct timecounter *timecounters = &dummy_timecounter;
+/* Mutex to protect the timecounter list. */
+static struct mtx tc_lock;
+MTX_SYSINIT(tc_lock, &tc_lock, "tc", MTX_DEF);
int tc_min_ticktock_freq = 1;
#else /* __rtems__ */
@@ -1373,8 +1377,6 @@ tc_init(struct timecounter *tc)
tc->tc_quality);
- tc->tc_next = timecounters;
- timecounters = tc;
* Set up sysctl tree for this counter.
@@ -1396,6 +1398,11 @@ tc_init(struct timecounter *tc)
SYSCTL_ADD_INT(NULL, SYSCTL_CHILDREN(tc_root), OID_AUTO,
"quality", CTLFLAG_RD, &(tc->tc_quality), 0,
"goodness of time counter");
+ mtx_lock(&tc_lock);
+ tc->tc_next = timecounters;
+ timecounters = tc;
* Do not automatically switch if the current tc was specifically
* chosen. Never automatically use a timecounter with negative quality.
@@ -1403,22 +1410,24 @@ tc_init(struct timecounter *tc)
* worse since this timecounter may not be monotonic.
if (tc_chosen)
- return;
+ goto unlock;
if (tc->tc_quality < 0)
- return;
+ goto unlock;
if (tc_from_tunable[0] != '\0' &&
strcmp(tc->tc_name, tc_from_tunable) == 0) {
tc_chosen = 1;
tc_from_tunable[0] = '\0';
} else {
if (tc->tc_quality < timecounter->tc_quality)
- return;
+ goto unlock;
if (tc->tc_quality == timecounter->tc_quality &&
tc->tc_frequency < timecounter->tc_frequency)
- return;
+ goto unlock;
(void)tc->tc_get_timecount(tc);
timecounter = tc;
+unlock:
+ mtx_unlock(&tc_lock);
return;
@@ -1722,16 +1731,22 @@ sysctl_kern_timecounter_hardware(SYSCTL_HANDLER_ARGS)
struct timecounter *newtc, *tc;
int error;
tc = timecounter;
strlcpy(newname, tc->tc_name, sizeof(newname));
error = sysctl_handle_string(oidp, &newname[0], sizeof(newname), req);
if (error != 0 || req->newptr == NULL)
return (error);
/* Record that the tc in use now was specifically chosen. */
tc_chosen = 1;
- if (strcmp(newname, tc->tc_name) == 0)
+ if (strcmp(newname, tc->tc_name) == 0) {
return (0);
for (newtc = timecounters; newtc != NULL; newtc = newtc->tc_next) {
if (strcmp(newname, newtc->tc_name) != 0)
continue;
@@ -1749,11 +1764,11 @@ sysctl_kern_timecounter_hardware(SYSCTL_HANDLER_ARGS)
* use any locking and that it can be called in hard interrupt
* context via 'tc_windup()'.
- return (0);
+ break;
- return (EINVAL);
+ return (newtc != NULL ? 0 : EINVAL);
SYSCTL_PROC(_kern_timecounter, OID_AUTO, hardware,
CTLTYPE_STRING | CTLFLAG_RWTUN | CTLFLAG_NOFETCH | CTLFLAG_MPSAFE, 0, 0,
sysctl_kern_timecounter_hardware, "A",
@@ -1767,12 +1782,17 @@ sysctl_kern_timecounter_choice(SYSCTL_HANDLER_ARGS)
struct timecounter *tc;
int error;
+ error = sysctl_wire_old_buffer(req, 0);
+ if (error != 0)
+ return (error);
sbuf_new_for_sysctl(&sb, NULL, 0, req);
for (tc = timecounters; tc != NULL; tc = tc->tc_next) {
if (tc != timecounters)
sbuf_putc(&sb, ' ');
sbuf_printf(&sb, "%s(%d)", tc->tc_name, tc->tc_quality);
error = sbuf_finish(&sb);
sbuf_delete(&sb);
return (error);
2.31.1
