[PATCH 16/26] Make kern.timecounter.hardware tunable
Sebastian Huber
Mon Nov 8 06:27:44 UTC 2021
Noted and reviewed by: kevans
MFC after: 1 week
Sponsored by: The FreeBSD Foundation
Differential revision: https://reviews.freebsd.org/D29122
cpukit/score/src/kern_tc.c | 23 ++++++++++++++++++-----
1 file changed, 18 insertions(+), 5 deletions(-)
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index 51ef27744e..2e9de6e463 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -290,6 +290,7 @@ SYSCTL_PROC(_kern_timecounter, OID_AUTO, alloweddeviation,
volatile int rtc_generation = 1;
static int tc_chosen; /* Non-zero if a specific tc was chosen via sysctl. */
+static char tc_from_tunable[16];
#endif /* __rtems__ */
static void tc_windup(struct bintime *new_boottimebin);
@@ -1400,17 +1401,26 @@ tc_init(struct timecounter *tc)
return;
if (tc->tc_quality < 0)
return;
-#endif /* __rtems__ */
+ if (tc_from_tunable[0] != '\0' &&
+ strcmp(tc->tc_name, tc_from_tunable) == 0) {
+ tc_chosen = 1;
+ tc_from_tunable[0] = '\0';
+ } else {
+ if (tc->tc_quality < timecounter->tc_quality)
+ return;
+ if (tc->tc_quality == timecounter->tc_quality &&
+ tc->tc_frequency < timecounter->tc_frequency)
+ return;
+ (void)tc->tc_get_timecount(tc);
+ timecounter = tc;
+#else /* __rtems__ */
return;
return;
-#ifndef __rtems__
- (void)tc->tc_get_timecount(tc);
timecounter = tc;
-#ifdef __rtems__
tc_windup(NULL);
@@ -2241,6 +2251,9 @@ inittimehands(void *dummy)
for (i = 1, thp = &ths[0]; i < timehands_count; thp = &ths[i++])
thp->th_next = &ths[i];
thp->th_next = &ths[0];
+ TUNABLE_STR_FETCH("kern.timecounter.hardware", tc_from_tunable,
+ sizeof(tc_from_tunable));
SYSINIT(timehands, SI_SUB_TUNABLES, SI_ORDER_ANY, inittimehands, NULL);
2.31.1
